Old 10-18-2012, 05:52 PM   #1
matigas_TT
Member#: 322775
2012 WRX-4Dr
Default Fluid Leak *please help*
Guys I have an 2012 wrx and did my oil change today DIY
While doing the oil change I notice a fluid leaking..
I can't seem to figure where this is.. Please help. Im really nervous
Car only has 4300k miles on it
Saw this on the driver side area
matigas_TT is offline   Reply With Quote
Old 10-18-2012, 06:26 PM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
valve cover gasket leak?
*powertrain warranty*
z is offline   Reply With Quote
Old 10-18-2012, 06:32 PM   #3
matigas_TT
Member#: 322775
2012 WRX-4Dr
Wow how is this possible?
Old 10-18-2012, 06:33 PM   #4
holyjoetart
Member#: 232986
07 Legacy GT
Looks like fresh oil to me. How big was the puddle underneath the car?
holyjoetart is offline   Reply With Quote
Old 10-18-2012, 07:33 PM   #5
matigas_TT
Member#: 322775
2012 WRX-4Dr
This was the leak when I changed it.
There was no puddle. Just that on the hose
Old 10-18-2012, 09:16 PM   #6
holyjoetart
Member#: 232986
07 Legacy GT
Wipe it off. Run it until its warm. Let it set for a moment. See if it comes back.
You could also pull off your intercooler and check from above.
Old 10-18-2012, 09:18 PM   #7
matigas_TT
Member#: 322775
2012 WRX-4Dr
I'll do this. THANKS!
Old 10-18-2012, 09:29 PM   #8
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Dude, you have a BRAND NEW CAR with a SHINY NEW WARRANTY. Why not use it? Instead of taking all this time to find it, you can get it done for free.
Old 10-19-2012, 11:38 AM   #9
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Looks like maybe you spilled some down the filler neck when refilling? It looks fresh.
Hoon Goon is offline   Reply With Quote
Old 10-23-2012, 09:27 AM   #10
matigas_TT
Member#: 322775
2012 WRX-4Dr
at the dealership.. for some reason they said the hose on the intercooler was loose and needed to get changed.. they are replacing it now.. not sure how it became loose... hmmmm..
anyway thanks for all your help!
Old 10-23-2012, 09:42 AM   #11
Tripintaz
Member#: 245218
2013 STI Limited
Throttle Body to Intercooler hose. Common issue that fails on the 08+ cars but usually at higher than stock boost levels. Basically the hose design is crap and it fails. I suspect a small amount of oil gets in the hose overtime and starts to break down the glue that holds the "endcaps" onto the hoses. Then the glue fails, creates a boost leak, etc etc etc....
Old 10-23-2012, 09:47 AM   #12
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
Bring it into the dealer.
berge56 is offline   Reply With Quote
Old 10-23-2012, 09:50 AM   #13
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Looks like brake fluid to me.
bhhamblin is offline   Reply With Quote
Old 10-23-2012, 10:08 AM   #14
matigas_TT
Member#: 322775
2012 WRX-4Dr
damn... issue since 08+?? im all stock ... i guess i need to check this every month now..
Old 10-23-2012, 09:36 PM   #15
holyjoetart
Member#: 232986
07 Legacy GT
Issue since '05+ on the LGT. Have them pull off the stupid rubber ends on the hose. Or do it yourself.
Old 10-23-2012, 10:44 PM   #16
matigas_TT
Member#: 322775
2012 WRX-4Dr
You have a DIY for this ?
Old 10-23-2012, 11:24 PM   #17
garudatwo
Member#: 322385
Remove the intercooler, remove the hose, remove the rubber condoms on both tips.
I'd take a sharpie or something and mark which side of the hose is up and which end goes to the intercooler. The hose its shaped like a pancreas and I spent a good 20 mins figuring out the orientation when reassembling.
garudatwo is offline   Reply With Quote
Old 10-24-2012, 10:59 AM   #18
Tripintaz
Member#: 245218
2013 STI Limited
I heard rumors that Subaru changed the design in this hose for the 2012 model year because they were tired of replacing it under warranty. But I have never seen one of of a 2012. Mine didn't pop until I was at stage 2 boost levels.
