#1 |
Member#: 311781
Vehicle:2003 WRX w STI V8 |
I put this in the tuning section but guess its more appropriate here.
Issue: During a cold start with no o2 sensor plugged in the car fires up at 1500rpm then makes its way down to 900rpm. Perfect, no issues! Now we do it again but this time install the o2 sensor. Fires up at 1500rpm then makes it way lower then jumps up, goes down, jumps up, rinse and repeat. When the rpms go up the car leans out, when the rpms drop the car richens. It does this until the car is warm. Once the car is warm you can start her up and it idles perfectly. o2 sensor is brand new. I was running without an o2 for 2 weeks until I received it today. Once I put it in/cleaned the codes the car would idle as described above. Also to note, this happened with the previous o2 until it crapped out on me. Can this be pointing to the MAF?
#2 |
Member#: 5810
Tri-State
Vehicle:2001 S366 2.5RS |
maf leak or air leak of some way.
#3 |
Member#: 311781
If it was you would see it in both situations would you not? After all a leak is a leak.
#4 |
Member#: 202804
MWSOC
Vehicle:2002 PSM Sedan 20g/ewg/Phattbotti Tuned |
Holy crap, you pointed out my cold start issue to a T. Only problem is that I have ID 1000cc injectors and I seem like i'm the only person who's having this issue with them. AFR/Idle swings when it's cold until the temperature needle starts to move then they both settle where they should be.
#5 | |
Member#: 311781
#6 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
3 people.
![]() I think few people notice because they touch the throttle shortly after starting, and the ECU only does this until you touch the throttle or until the engine is warm. |
#7 |
Member#: 311781
#8 |
Member#: 292996
MWSOC
Vehicle:02 wrx |
Try adjusting your closed loop target compensation (ECT) table to target richer when cold.
#9 |
Member#: 202804
MWSOC
#10 |
Member#: 311781
#11 |
Member#: 202804
MWSOC
#12 |
Member#: 311781
#13 |
Member#: 202804
MWSOC
I leave the throttle alone for a few minutes. Only until the temp needle starts to move when the idle/afr settles.
#14 |
Member#: 311781
#15 |
Member#: 202804
MWSOC
#16 |
Member#: 311781
Injector latency stay the same. I'll post them later on when I have my netbook.
#17 |
Member#: 311781
I changed my MAF as I had a spare. I can definitely say it doesn't swing as madly as it did before. My old MAF was dirty. Still swings but its a little more acceptable. Just an update.
#18 |
Member#: 311781
#19 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
if your unplugging your front 02 and this issue goes away then its a tuning issue.... FIC 1100 CC injectors idle like a stock motor when you get it right... MAF adjustments are not taken into consideration when you unplug the front O2... kinda like when you just unplug the MAF... I would be interested in seeing some logs with your front 02 and your rom... Maybe its something i can help with remotely... PM me.
#20 |
Member#: 311781
The car idles very nicely if its warm. It fires up quickly but after say 10 seconds it will run lean/rich until about 40-50c. Then it stabilizes. I'll take a video tomorrow and post it up. I'm sure its a tuning issue.
I had my system smoked today. No leaks. o2 Is new and MAF is cleaned. BTW, you have a PM thanks! |
#21 | |
Member#: 202804
MWSOC
This is the exact thing that happened when I tried a set of Bosch 1kcc injectors before switching to ID's. Didn't really change much after taking out 30% of cranking fueling. |
#22 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
All the warmup fueling is based on static compensations so if your injectors are big the numbers are off. After a min or so fueling correction begins so I usually find that it gets into a loop of overcorrecting because the initial starting point is off. The cranking is not the problem if the car turns over, it is the warmup fueling/decay tables.
Try bumping up your latency by 5-10% across the board I have found that helps out significantly on most cars. |
#23 | |
Member#: 202804
MWSOC
#24 |
Member#: 59837
SWIC
It is a complex mix of offsets and decays, It takes some trial and error to figure it out. Getting good E85 cold starts takes a bit of work on these tables in addition to cranking.
#25 |
Member#: 311781
I have messed with cranking and warm up enrichment as well as latency. I might not have played with decay (can't recall). Would you add or remove? I don't mind trying.
