#1 |
Member#: 193253
MWSOC
Vehicle:08 wrx 322/352 wrb |
I have owned this vehicle since December of 2011 from a local nasioc member, well 3k later the main bearing goes bye bye. So as a broke as student i decided just to do a small semi built motor just so i can drop in a little bigger turbo and have some fun auto crossing while finishing my degree. It took roughly three months for the motor build and shortly after install during break in period the transmission bearing decided to give out. This took another month in a half for the rebuild back to stock. Now after the rebuild of the transmission the car was finally dyno tuned with a tad bit bigger turbo and here are the results.
Event: First Dyno Tune Location: Franklin Park, IL Running Condition: 85F and 30%humidity Car: 2008 Wrx 4D Tuner: Jr Tuned Dyno: Dynojet Trans: Stock Gear: 3rd Peak Hp at RPM: 322.10 awhp @ 5700 rpm Peak Wtq at RPM: 351.17 awtq @ 3800 rpm Fuel: 93 octane Target boost: 20 psi Modification: Forged internals Manley piston ACL race bearing Heads resurfaced Unknown brand TD05-18g 7cm Mitsubishi internals and rebuilt by Pavel’s Racing Engines Stock Flywheel Exedy Clutch Grimmspeed Bcs IPR tmic Perrin short ram Perrin turbo inlet Megan racing catless downpipe Megan racing mid-pipe SPT dual tip catless ID 1000cc Walbro 255 fuel pump Tomei el headers AP up-pipe Stock bpv All exhaust pipes are heat wrapped Audio SONY XPLODE SPEAKERS FRONT AND REAR W/ TWEETERS KICKER AMP FOR SPEAKERS BOSS BASS1200 SUBWOOFER W/ AMP Lights HIDs for the headlights and fogs ![]() ![]() ![]() ![]() I would like to thank P&L Motorsports for the transmission rebuild, Six Star for the motor build, Jr for the nice tune, and Pavel's for the nice turbo. Thank for looking ![]()
#2 |
Member#: 48350
MAIC
Vehicle:04 WRX |
Nice. How much of the car did you disassemble to pull that motor? It looks like front fenders are off in the pics.
#3 |
Member#: 193253
MWSOC
i took the whole front end off so that way i wouldn't seem anything up cosmetically, but in all you only need to take the hood off and you can pull it out that way. I was just super paranoid
#4 |
Member#: 48350
MAIC
Vehicle:04 WRX |
Lol no problem. I didnt have to remove the hood on mine to pull the motor.
#5 |
Member#: 316278
TXIC
Vehicle:2010 WRX Sedan WRB |
Looks nice! Seems to spool kinda late for a 18g 7cm though, probably better on the street. Nice numbers regardless!
#6 |
Member#: 193253
MWSOC
i asked for a mild tune... but thank you it is fun on the streets.
#7 |
Member#: 155696
Tri-State
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
Seems like a nice conservative tune. Graph looks strong
#8 |
Member#: 64908
Tri-State
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
Glad your happy with the car.
Yea the tune was very soft on the car, it was his request. I usually keep the spool slow on the 5psd 2.5 cars. Last edited by Junior2JZ; 10-14-2012 at 11:13 PM. |
#9 |
Member#: 193253
MWSOC
Very happy with the work that you have done... Your reputation is truly as good as every person says it is. Great job once again, I will be coming back to you some time soon for e85 hopefully
#10 |
Member#: 277108
Vehicle:09 Wrx Hatch Grey |
nice numbers. Getting mine retuned next week for e85 at P&L
#11 |
Member#: 193253
MWSOC
#12 | |
Member#: 276209
MWSOC
Vehicle:I am Rub Function>Form |
E85 is a must! After driving my 08 wrx witha vf39 on E85 for the past 10 months I will never go back to pump gas with a subaru. The gains are just fantastic (especially the torque), the gas milage is a bit crappier, but for the price it still costs just about the same (if not a little cheaper) $/mile as pump gas, and I log regularly and find virtually no knock. ![]() |
#13 | |
Member#: 193253
MWSOC
#14 | |
Member#: 171948
Tri-State
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
#15 |
Member#: 193253
MWSOC
E85 would be run for auto crossing for sure.
#16 | |
Member#: 276209
MWSOC
understandable, but it's easy enough to have another map for 93. If I'm going to go on a long trip I'll just flash my 93 map, but living in chicago there are tons of e85 stations. I've got 3 that I use regularly (one by the house, on in between work and home, and one by work) so it's never an issue. I DD my car 60 miles a day to work and back without issue . |
#17 | |
Member#: 276209
MWSOC
Or you can just buy a tactrix cable for about $170 (cheaper if used). Not sure if Jr tuned you open source or not but I went this option because it's cheaper then the AP and can do anything an AP can do. |
#18 |
Member#: 277108
#19 |
Member#: 131787
Tri-State
Vehicle:06 STI,OB,OME XJs Merkur Junkyard |
But it does do the less exotic non-rub launch control
#20 | |
Member#: 64908
Tri-State
#21 | |
Member#: 193253
MWSOC
i have an ap from my 05 wrx and i love that device like no other... i use it all the time |
#22 |
Member#: 276209
MWSOC
#23 | |
Member#: 193253
MWSOC
#24 |
Member#: 276209
MWSOC
#25 | |
Member#: 193253
MWSOC
