Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 10-09-2012, 10:58 PM   #126
Paradis
Member#: 334647
2012 POS Impreza
Originally Posted by Cogito8888 View Post
I'll continue looking, however in the thread I first linked they mentioned two defeat options. One option that resulted in a CEL and one that did not. I update if I ever find anything...
Did you find something ?
Paradis is offline   Reply With Quote
Old 10-15-2012, 06:15 PM   #127
Paradis
Member#: 334647
2012 POS Impreza
Old 10-15-2012, 06:39 PM   #128
kenny doggins
Member#: 326540
2012 Impreza MT SP
Hey after reading through this thread, I wonder if I haven't felt the abs/vdc stop me from sliding because I have the hill assist turned off, possibly a side effect of that is disabled gyro? Does that even make sense? I have jammed around some on dirt roads and did some high speed drifting turns with no problem, but i wasn't super sideways either. But other times it gets loose when I want it to, come to think of it. I've spun her around pretty good with and without the e-brake on loose dirt.
Either way I don't have an issue with how it works yet. I'll find out in the snow this winter. Couple more months...
kenny doggins is offline   Reply With Quote
Old 10-15-2012, 08:44 PM   #129
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Without disabling iti can do all you described in my 5sp
Old 10-16-2012, 11:25 PM   #130
ScoobyCO
Member#: 236205
2013 ImprezaSport5MT
Ice Silver Metallic
Checked the factory service manual and it states that the VDC Control Module and Hydraulic Control Module (ABS) are the same unit. In fact, this is the official name of the ABS module "VDC Control Module and Hydraulic Control Unit (VDCCM&H/U)".
It sounds like everyone was pretty much at that realization already, but this confirms the relationship. Wonder if the VDCCM part can be disabled separately.
ScoobyCO is offline   Reply With Quote
Old 10-16-2012, 11:48 PM   #131
ScoobyCO
Member#: 236205
Ice Silver Metallic
Found a bit more.... Regarding the Yaw & G Sensors, the FSM says, "Yaw rate & longitudinal G and lateral G sensor are integrated with the VDC control module&hydraulic control module (VDCCM&H/U)." So you won't find them in the console or dash. They are within the VDCCM itself which is the box hanging off the back of the Hydraulic Control Unit.
Old 10-19-2012, 10:44 AM   #132
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
So is this confirmation that the 5spd is fun and the CVT is not allowed to be fun?
foghelmut is offline   Reply With Quote
Old 10-19-2012, 11:05 AM   #133
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I thought the cvt was ungodly boring to drive so my vote is yes
Old 10-19-2012, 11:58 AM   #134
foghelmut
Member#: 328414
2012 Impreza SP 5MT
Well aside from that, I just want to be able to state that this thread has definitively determined that:
1. The CVT does not allow you to disable stability control, and therefore will not allow you to slide sideways on demand.
2. The 5spd is not subordinate to such forces.
Old 10-19-2012, 12:22 PM   #135
ScoobyCO
Member#: 236205
Ice Silver Metallic
I hope that's right about the 5sp (because that's what I have ) but that was not the case with my 2011 Outback 6MT. VDC kicked in very effectively when ever I tried to have some sideways fun in the snow. I don't have a comparison to the CVT, though, so maybe the MT with viscous center diff does allow more freedom.
Old 10-19-2012, 12:47 PM   #136
M45
Member#: 333446
2013 Impreza SL CVT
that's not what I read. it sounded like in order to actually disable everything you get some not so nice side-effects to go along with it (engine put into a mode where it goes limp after 4k rpm??). is this not true?
M45 is offline   Reply With Quote
Old 10-19-2012, 12:59 PM   #137
foghelmut
Member#: 328414
2012 Impreza SP 5MT
You could also disable it by cutting you brake lines. I would say it doesn't count as being disabled if the whole car is disabled.
Old 10-19-2012, 01:03 PM   #138
M45
Member#: 333446
2013 Impreza SL CVT
aren't you the guy that just said you could disable all of the "non-fun" features on the MT? The only thing I saw in the thread with regards to actually doing this was removing a fuse or something. Otherwise it appears some of them are always on and there is some disagreement over how big of a deal this is.
eta: I'm off the opinion that while it would be more fun to have it all turned off I'm guessing it's not a huge deal for most. I'm just trying to understand the truth of the matter here as to what the differences are in the diff AWD systems and what everyone can and can't disable. I know they are mechanically different but I'm more referring to the "real world" differences in terms of user experience.
Old 10-19-2012, 02:37 PM   #139
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Well in the 5sp since the diff is mechanical rather than electrical (controlled) i don't see how vdc would do much other than through wheel braking or cutting engine power.
The few times i have tried to do donuts on gravel or whatever they are called in your post of the world, i have been able too. It is my understanding than vdc shouldn't allow this to happen.
Old 10-19-2012, 02:50 PM   #140
M45
Member#: 333446
2013 Impreza SL CVT
not everyone uses the terminology "donuts"?
so you are saying you were able to do some "fun stuff" - have you turned anything off to do this? just the traction control button? something else? I'm curious what I should expect once I find myself on snowy surfaces this winter.
Old 10-19-2012, 02:53 PM   #141
79letour
Member#: 302570
2013 XV
DGM!
I can speak for my experience with my 5mt and the cvt loaners I've had.
The manual is WAY more fun on dirt/clay/sandy roads. Gravel is where the abs, vdc, etc really ruin the fun. But I need RA flaps before I take any gravel or ROUGH roads too hard.
Sure is fun on graded dirt roads out in the ocala national forest. Did some "rally cross" of my own last weekend. Just spent two hours washing, although love bugs and blind mosquitos are mostly to blame.
When someone figures out a good way of eliminating all the "anti-fun" elements of the car, I'm sure there will be more go-fast goodies to help increase the fun-factor as well.
79letour is offline   Reply With Quote
Old 10-19-2012, 03:11 PM   #142
M45
Member#: 333446
2013 Impreza SL CVT
Well yeah - having more control of the rpms and a clutch is going to certainly help a lot. So you don't think the abs/vdc doesn't affect you much under the non-gravel conditions? I'm not planning on doing the stuff that you do - I'll just be driving on roads under winter conditions.
Old 10-19-2012, 03:32 PM   #143
kenny doggins
Member#: 326540
2012 Impreza MT SP
brodies
Old 10-19-2012, 03:53 PM   #144
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Just traction control
Old 10-19-2012, 03:54 PM   #145
M45
Member#: 333446
2013 Impreza SL CVT
got it!
Old 10-19-2012, 04:07 PM   #146
kenny doggins
Member#: 326540
2012 Impreza MT SP
by the way...
MT FTW
Old 10-19-2012, 04:14 PM   #147
foghelmut
Member#: 328414
2012 Impreza SP 5MT
I didn't make any claims. I was just trying to get some takeaway points from the thread.
Old 10-19-2012, 04:45 PM   #148
79letour
Member#: 302570
2013 XV
DGM!
You'll be fine M45.
I flogged a cvt loaner fairly hard on some dirt roads, and traction is good, but the rear doesn't feel as *predictable* on the cvt when going 70mph on dirt. For all intents and purposes, it does just fine.
But yeah MT forever!!!
Old 10-27-2012, 11:45 PM   #149
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
tonight in my 5sp, just turned the traction control off and made 2 full circles(passes) then took the pic so much fun!
Old 10-28-2012, 12:53 PM   #150
Paradis
Member#: 334647
2012 POS Impreza
Need a Video !!!
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 03:54 PM
