Old 10-14-2010, 12:10 PM   #4251
MY EJ20T
Member#: 133324
2002 MBP Stg 2 Rally
MBP
Yall are just a bunch of goo bags sitting there yapping about a danggun air radiator for yer ricer cars. TMIC FTW
MY EJ20T is offline   Reply With Quote
Old 10-14-2010, 01:03 PM   #4252
vms150
Member#: 172917
2004 WRX
and heat soak ftl
vms150 is offline   Reply With Quote
Old 01-04-2011, 07:57 PM   #4253
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
Any 07 wrx installed pics or problems? Since ther is only one threaded hole on the bottom. Just wondering wht the option is for the core to bolt up to on the bottom?
breezeby is offline   Reply With Quote
Old 01-13-2011, 02:48 PM   #4254
BlaKKStaRR
Member#: 133325
2007 WRX TR
I just installed this on my car about a week ago.
2007 WRX TR
Fitment was great!! Since there was only one hole on the bottom for the IC, i just grabbed another bolt and threaded it into the non threaded hole, and all is well!
BlaKKStaRR is online now   Reply With Quote
Old 01-13-2011, 04:14 PM   #4255
breezeby
Member#: 132658
07 TR vf39ed
how big was the bolt
Old 01-14-2011, 04:27 PM   #4256
BlaKKStaRR
Member#: 133325
2007 WRX TR
Idk thread pitch and all, but it really didn't matter since it wasn't threaded lol it was about an inch and a half long
Old 01-25-2011, 04:55 PM   #4257
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
problem taken care of..
801_STi is offline   Reply With Quote
Old 01-27-2011, 12:41 AM   #4258
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
also taken care of.
Old 01-27-2011, 09:10 PM   #4259
cpunlamd
Member#: 151360
2007 STI RIP
2010 EvoX-sold / 2010 GTR
Wow! The Ebay FMIC is going on strong!
cpunlamd is offline   Reply With Quote
Old 01-28-2011, 12:07 PM   #4260
BlaKKStaRR
Member#: 133325
2007 WRX TR
Hell yeah it is.
Still doing good over here after about three weeks!
No leaks, great fitment.
Also did some logging, and for some reason after going to the FMIC my MAF is reading that its pulling in about 60 g/s more than before, injector duty cycle went up a good amount, but also that I'm running a tad leaner.
Just assuming from the dense as cold air that was going on, causing the ECU to dump more fuel (Higher Injector Duty Cycle), but it still not being enough since I'm getting in about 290 g/s of air lol so its still bit leaner.
Tune is next on the menu, after larger injectors - looks like theyre maxed!
Old 02-02-2011, 05:33 PM   #4261
chlnOrSlpn?
Member#: 97785
2005 WRX Stg 2
EFI Logics/CTSUBIE
Well I own a WRX now and this is probably my 3rd or 4th SSAC type FMIC. it's a GMS FMIC, with Aluminum piping but same basic design. I made it work with my APS 65 intake...
Getting tuned soon, well see how this performs. My SSAC intercoolers always performed well on my 30R STi.
chlnOrSlpn? is offline   Reply With Quote
Old 02-14-2011, 03:42 PM   #4262
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
just installed mine with the perrin blow thru. awesome kit. went in with no problems. it was really easy. had to cut a lil more outta an 07 bumper than i wouldve like but its all good.
sidenote: if you use the perrin blo thru you'll most likely lose your fogs. im sure you could make something work but as of right now i had to take my fogs out.
Old 02-14-2011, 05:29 PM   #4263
ZAG_WRX
Member#: 243614
2010 m3
Le mans blue
What did you have to do in order to make it work with the APS intake?
ZAG_WRX is offline   Reply With Quote
Old 10-19-2012, 03:34 PM   #4264
badmammajamma
Member#: 84419
2005 WRX STi
380whp ATP 35r
Originally Posted by aboothman View Post
Wow, I am amazed that people are still buying this garbage. Some people never learn...
2 years an not a complaint here runs good.
badmammajamma is offline   Reply With Quote
Old 10-19-2012, 03:39 PM   #4265
jackansi
Member#: 23894
'07 3.2L Audi A4
Mine's been on since early 2006.. without a single issue... Even came with 2 extra couplers and 3 extra t-bolt clamps. I have yet to find higher quality couplers than what came with my SSAC kit for use with other projects.
jackansi is offline   Reply With Quote
Old 10-22-2012, 09:27 AM   #4266
Rene2.5RS
Member#: 4574
2011 Legacy 2.5i LMT
My WRX has been running this setup for years and I have since sold the car and it is still running it. Only had one t-bolt clamp break on me the entire time, which was likely because I used a pneumatic ratchet to tighten all of them
Rene2.5RS is offline   Reply With Quote
Old 10-30-2012, 02:06 PM   #4267
MMY MSL
Member#: 335135
2002 Forester S
Blue Ridge Pearl
Where are people buying these FMICs these days? I'm not finding any crazy ebay deals anymore...
MMY MSL is offline   Reply With Quote
Old 10-30-2012, 04:16 PM   #4268
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
just an FYI to all... my friend recently got in an accident and since he had a FMIC which required the removal of his crash bar, the damage was much more significant than it should have been.
Long story short, insurance covered the repairs but little did anyone know, the crash damaged the water pump causing the car to overheat and warp the heads/block. The insurance co found out about the removed bumper beam and told him to screw off when he asked to have the engine rebuilt. He had to cover the entire engine rebuild out of pocket.
So, let this be a lesson to anyone here thinking about getting a fmic... KEEP YOUR CRASH BAR or have a nice solid/sturdy one fabricated because not having one will cost you... and that aluminum bracket holding the intercooler is NOT a solid bracket.
the end
All4bSpinnin is offline   Reply With Quote
Old 10-30-2012, 04:21 PM   #4269
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
I've installed a few of these things despite my disapproval. Each time they fit like ****
Old 10-30-2012, 04:45 PM   #4270
funk32
Member#: 245787
2004 STi
when I installed mine 3 years ago, I had no issues at all. I no longe have it due to going rotated.
funk32 is offline   Reply With Quote
Old 10-31-2012, 12:01 PM   #4271
MMY MSL
Member#: 335135
2002 Forester S
Blue Ridge Pearl
I'm looking to put this on a salvage title 2002 forester S with bull bars, hopefully those would soak up most of the front end damage in the event of a gnarly crash.
Old 10-31-2012, 11:22 PM   #4272
WRXSteye20008
Member#: 175565
2005 STI CGM
Built 351whp/368tq
If you look at the first post you will see a link to the website they are still being sold at. Also fill out your profile.
WRXSteye20008 is offline   Reply With Quote
Old 11-01-2012, 12:10 PM   #4273
MMY MSL
Member#: 335135
2002 Forester S
Blue Ridge Pearl
Already got contact from XS power about pricing, and will likely be buying from them. SSAC lists them for $550 + 50 shipped on their website now, and their ebay store doesn't have any shown. Thanks for the input, I will fill out my profile.
Old 11-16-2012, 06:26 PM   #4274
xspj
Member#: 336571
Wow, great thread! We are still offering these kits for WRX/STI's. If you have any questions or would like pricing or to place an order, the fastest way to get ahold of us is by email - xspowerj@gmail.com
xspj is offline   Reply With Quote
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
Message Board Statistics All times are GMT -4. The time now is 01:01 AM.
