Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 09-24-2012, 01:59 PM   #401
SPIWRXAK
Member#: 273795
2007 wrx tr
urban metallic grey
So I'm waiting on the shortblock. Should be done this week.
07 wrx tr
Ej255 bored 20 over
Wiseco coated hd pistons
Eagle h beam rods
Acl race bearings
Sti polished crank
Arp rod bolts
Arp head studs
07 wrx heads(stock)
Matched cosworth head gaskets
Phenolic spacers
Tgv deletes
Air pump delete
Fp red 8 cm hotside
APS 3" turbo inlet
Blitz huge short ram intake and big maf housing with custom intake piping
Air intake temp sensor relocate
Turbo xs front mount intercooler
920 cc injectors
Walbro 255lp fuel pump
Snow performance methanol injection
05 sti drivetrain with 04 brembo brakes
Act six puck clutch kit
All Samco hoses
Will be tuning at MPS in Arlington Washington
Dyno dynamics dyno
I live in Wenatchee, Wa
What do you think? Also more wondering what she's gonna do at the drag strip??
SPIWRXAK is offline   Reply With Quote
Old 09-24-2012, 02:02 PM   #402
SPIWRXAK
Member#: 273795
2007 wrx tr
urban metallic grey
Oh and 93 octane btw :-) and 780 ft elevation here in Wenatchee.
Old 10-06-2012, 07:42 AM   #403
greenbeast08
Member#: 325634
great thread.
greenbeast08 is offline   Reply With Quote
Old 10-16-2012, 03:13 AM   #404
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
1) 300whp.
2) Dyno Dynamics
3) Forged Performance, Atlanta, GA.
4) Cookeville, TN Elev. 1,200ft
5) 93 octane
6) Yes, I'm opposed to a FMIC.
I've been thinking about a 16gxt plus whatever else the tuner recommends for supporting mods. Would that get me close?
How is 300whp for reliability? I've got a new OEM exedy clutch and the stock 5spd, I don't plan on doing any drag racing or hard launches; mainly just a DD with some rallyx and autox tossed in.
MakuseruSukotto is offline   Reply With Quote
Old 10-21-2012, 12:50 AM   #405
atm0706
Member#: 279219
~300whp
Don't know the dyno..
COBB Surgeline Portland, OR
92 oct
tmic
2002 wrx wagon with 130k
cobb ots stage 2
invidia catless dp
hks hi power catback
ptp turbo blanket
atm0706 is offline   Reply With Quote
Old 11-19-2012, 01:30 AM   #406
rexblake
Member#: 178426
2010 Audi S4
Originally Posted by MakuseruSukotto View Post
1) 300whp.
2) Dyno Dynamics
5) 93 octane
The engine can blow at any point. Mine went with a 16g at 260whp. You just never know. Ask for a safe, conservative tune. Be happy with whatever the number is.
Old 11-19-2012, 01:31 AM   #407
rexblake
Member#: 178426
2010 Audi S4
Originally Posted by atm0706 View Post
~300whp
92 oct
tmic
cobb ots stage 2
invidia catless dp
ptp turbo blanket
If your goal is 300whp, you need a bigger turbo. Call them and ask what they would recommend. With that high of mileage, don't mod till you can afford an engine build, a new clutch, and prolly synchros at least for the tranny.
Old 12-11-2012, 12:26 PM   #408
tjmazz13
Member#: 291681
'04 PSM STi
Rotated Borg Warner s256
~320whp
Dynapack
TurboXS Gaithersburg, MD
93oct
FMIC
2004 STi
VF48
APS 650 FMIC
820cc injectors
Walbro 255lph pump
Turbo inlet
Short ram intake
TXS 4in downpipe
TXS RFL cbe
Tial 38mm ewg
Worx Tuning bov
ACT street/strip clutch
ACT streetlite flywheel
tjmazz13 is offline   Reply With Quote
Old 12-17-2012, 11:34 PM   #409
SlowTrackImpreza
Member#: 262692
1999 GC ej217 WRB
22b widebody built fp red
1. HP at the WHEELS- looking for around 350whp...ish, happy with 320whp
2. What type of dyno- dynojet
3. what shop it is- All Aspects , probably going to have a guy Shad tune it, he has always pulled great RELIABLE numbers out of our track cars.
4. Where do you live- Hampton Roads, sea level
5. octane level- Shell 93...always, and will drive 20 miles to get it over bp sludge, bp always tests out lower octane here by the local college ODU, shell typically tests out about 96 to 97 octane
6. Are you opposed to a FMIC? I have a front mount now.
some more info, its is a version 6 ej207 sti swap, no ac, fmic, 2.75" TBE, intake is fabbed. currently has vf28 turbo running 19psi
self tuned (i know what im doing somewhat it is running on an AEM EMS-4 standalone
i know i will have to upgrade turbo and the 440cc injectors, got a td05 turbo sitting on the shelf at the shop tight now, been debating if it is a waste of time.
I have a TON of experience modding cars, this is my first endeavor in subaru though, typically honda, nissan, cobras and toyota inlines (2j,1j,7m) you get the point. this boxer is harder to rebuild than my rotary was lol thanks for the input guys.
SlowTrackImpreza is offline   Reply With Quote
Old 12-18-2012, 10:13 AM   #410
Davenow
Member#: 23676
TD05-20G 8cm with a 44mm EWG, run about 19 maybe 20 PSI. Should put you where you want to be with reasonable spool up.
As for swapping from a vf28 to a td05, depends on a few things.
1. If you are good at swapping turbos and have gaskets (in other words if it wont take you long, like I can swap turbos in ~20 minutes) and can adjust your own tune, go for it. EVen a 16G will be minorly better. Not better peak, but a little more responsive. If you have to pay ANYTHING< then don;t bother if its a 16G
2. What Td05 is it? 16/18/20G all come in TD05 versions. If its an 18G or larger, then its worth doing if you can do it CHEAP. If its a 16G, see above. If its a 20g, yes, do it, its the turbo you want.
And it sounds like you have already figured this out, but take what you know about tuning on all those other cars, and basically throw it out the window. Subies are pretty unique in their tuning needs fuel/timing wise.
Davenow is offline   Reply With Quote
Old 12-27-2012, 02:24 PM   #411
J wrx11
Member#: 280177
2011 wrx
WHP Goal: 350+
EFI's Mustang dyno in CT.
93 oct.
TMIC
Mod List
Built Shortblock
wiseco pistons
turbo tuff rods
arp bolts
acl bearings
tgv deletes
process west tmic
ks tech 65mm intake.....thinking of upgrading to 73mm
cobb uppipe and downpipe
spt exhaust
invidia el headers
ebcs
850cc injectors
DW 65 fuel pump
1.5xt-r 8cm
So can this get me to 350+whp on 93 oct? Currently at 285hp/340tq. Thanks for your opinions and thoughts.
J wrx11 is offline   Reply With Quote
Old 01-08-2013, 05:52 PM   #412
PSBeachBum
Member#: 279870
2005 WRX Wagon
1. 280 hp at wheels
2. Dynojet 424x
3. Rads Motorsports in Hawaii
4. Honolulu Hawaii so sea level.
5. 91 Octane
6. Opposed to FMIC
2005 WRX Wagon 85xxxmi
My Mods
vf39 PLANNING ON A Bloush 16g-xt
wrx dark blue injectors
grimmspeed ebcs
aem cai
perrin light crank pulley
helix bellmouth downpipe
custom catless piping from downpipe to borla hush muffler
Megan Unequal headers/ uppipe combo
Godspeed TMIC
stock fuel pump
As far as i know Stock block and internals
5MT (how this is still alive I dunno)
OEM clutch
Street tuned by PDX
Havent dyno'd becaust ****s $140 out here
PSBeachBum is offline   Reply With Quote
Old 01-11-2013, 01:01 AM   #413
Agentm
Member#: 343242
Uh, what kind of car methodically?
Agentm is offline   Reply With Quote
Old 01-14-2013, 08:16 PM   #414
chrisfromalbany
Member#: 67181
Catless Up-pipe
Catless TBE
ProTune
180K
What would the HP/tQ be?
Chris
chrisfromalbany is offline   Reply With Quote
Old 02-18-2013, 10:21 PM   #415
JLD13
Member#: 330696
05 Saabaru V7ej207
Default JDM Saab
2005 Saabaru 9-2x
Engine Mods:
  • JDM EJ207 V7 (VF 30)
  • Cobb DP
  • Cobb exhaust
  • Cobb intake
  • Walbro 255
  • Perrin pully
What am I looking at on a conservative tune with 92 octane gas.
Thanks for your input!
Last edited by JLD13; 02-19-2013 at 12:40 PM. Reason: oops... changed from 91 to 92 octane
JLD13 is offline   Reply With Quote
Old 02-26-2013, 03:54 PM   #416
interestingsti
Member#: 330695
One of the best posts here on NASIOC
interestingsti is offline   Reply With Quote
Old 03-03-2013, 03:06 PM   #417
RM1Sepex
Member#: 348396
Factory 5 818
Looking for 220 HP at the rear wheels
05 2.0 WRX with 70,000 miles
power steering and AC delete
Ceramic coated unequal length header and catless up pipe
very short exhaust (mid engine)
AEM intake
lightened flywheel
Cobb or open source tune
longer term TGV delete
RM1Sepex is offline   Reply With Quote
Old 03-12-2013, 05:56 AM   #418
sillyjason
Member#: 345599
Great post Thanks!
sillyjason is offline   Reply With Quote
Old 03-12-2013, 11:37 AM   #419
rexblake
Member#: 178426
2010 Audi S4
Originally Posted by RM1Sepex View Post
Factory 5 818
AEM intake
lightened flywheel
You don't need tgv deletes with the stock turbo. You should be pretty close to your goal. The only real factor is the dyno it certainly helps that you have no AWD drivetrain, power steering, or ac sucking power.
Also, pics and a build thread need to be up for this. It sounds like a fun setup.
Old 03-13-2013, 06:12 PM   #420
IamWill
Member#: 350085
300 HP on dynojet
2002 WRX on 93 octane
Ported and polished heads
Brian crower titanium valves 1mm oversized
Brian crower copper valve guides
Super tech dual valves springs
Catless up pipe
Big 16g turbo
Big TMIC
Dw 750cc injectors
Dw 255lph fuel pump
4 ply silicon turbo inlet pipe
Cobb short ram intake
Invidia Catless dp
Straight piped Catless exhaust (will be coming off and switched for catback exhaust)
IamWill is offline   Reply With Quote
Old 03-19-2013, 10:29 PM   #421
TheRedStig
Member#: 339781
Default How correct does this sound?
About a year ago my WRX dyno'd at 306WHP and 316TQ.
This seems low to me.
I run E85 with a number of mods at 18 boost psi. My mods are
890cc Injectors
Walbro 255 Fuel Pump
Aftermarket (Brand unknown) Fuel Pressure regulator at 40-45 psi
Short Ram Intake w/K&N
OBX Headers and bell mouth downpipe
Unknown Brand Uppipe
SPT 3'' Exhaust w/High Flow Cat
TGV Deletes
Grimmspeed Phenelic Spacers
FP 68HTA Turbo
HKS SSQV BOV
Hallman Pro Boost Controller
Front Mounted SPT Vishnu Intercooler
Perrin 22mm Front Sway Bar
Open Source Tuned by Harvey at The Boost Creep Ltd - Dyno Tuning and Automotive Services in Longmont Colorado
Does 306 sound low to you?? I know running here in Colorado Springs saps my numbers a bit too but still....
Also what would you do next? Was considering a clutch kit but dont have the cash in hand to do that just yet. Anything i can do for $100-$200 for now?
Thanks in Advance!
TheRedStig is offline   Reply With Quote
Old 03-19-2013, 10:32 PM   #422
RossLH
Member#: 147839
2003 WRX
SRP
With no benchmark to work off of, that number means absolutely nothing. So, no, it doesn't sound low. It's between 200 and 400, sounds about right to me.
RossLH is offline   Reply With Quote
Old 03-19-2013, 10:35 PM   #423
TheRedStig
Member#: 339781
You mean without a previous number, before the mods...?
Old 03-19-2013, 10:36 PM   #424
RossLH
Member#: 147839
2003 WRX
SRP
Optimally, yes.
Old 03-19-2013, 10:38 PM   #425
TheRedStig
Member#: 339781
Gotcha. Well thats annoying
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 49 08-15-2009 04:04 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
