South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-21-2012, 12:06 PM   #1
insany
Member#: 208652
2006 WRX STI
I was looking to see if someone with an 06 STi could do me a favor and let me use their dccd control module to check if my dccd module is the one causing the dccd to not work. I have tested the entire abs and dccd system, except for swapping out the module that is located behind our glove box. it's 500+ to get a new one and 120 for the dealership to just inspect it -.-, so I'm trying to avoid the dealership inspection.
insany is offline   Reply With Quote
Old 10-21-2012, 01:16 PM   #2
Evil Imports
Member#: 14732
+ 08 SG6 & 13 B8
Built not bought #0002
Do you have the part number? i am pretty sure i have one i will sell you for $20
Evil Imports is online now   Reply With Quote
Old 10-21-2012, 01:17 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Used ones are affordable since they hard to swap.
Old 10-21-2012, 02:59 PM   #4
insany
Member#: 208652
2006 WRX STI
Part number is 32520AA200
Old 10-21-2012, 03:43 PM   #5
Evil Imports
Member#: 14732
+ 08 SG6 & 13 B8
just checked, only have AA150 part numbers, (05 sti) i did have a 06 one somewhere, but don't know where it is
Old 10-21-2012, 03:47 PM   #6
insany
Member#: 208652
2006 WRX STI
If by any chance you find it, I'll buy it from you .
Old 10-24-2012, 11:47 AM   #7
Z0rr0
Member#: 23123
05 Legacy GT
13 Scion FR-S
@ Evil, do i have that one at my house? i'll check tonight.. i thought you had an 06 one too. maybe i have it from when i was troubleshooting Don's DCCD.
Z0rr0 is offline   Reply With Quote
Old 10-24-2012, 05:45 PM   #8
Evil Imports
Member#: 14732
+ 08 SG6 & 13 B8
I think you do have it, just let me know
Old 10-26-2012, 07:52 PM   #9
insany
Member#: 208652
2006 WRX STI
Did you guys happened to find the part for the 06 sti?
Old 11-08-2012, 11:51 PM   #10
insany
Member#: 208652
2006 WRX STI
Update on the issue: I was able to get a new dccd module and install it to test to see if it was the dccd module that was causing the issue. But it wasn't and my dccd still doesn't work properly. I'm hoping you guys can have some helpful feedback to fix this issue.
Symptoms:
The only time the DCCD works is if it's 75+ degrees outside and the car has been bathing in the sun for a good hour or more. It will also start working if I run the car for about 30 minutes and let the engine heat up, otherwise it will not work properly.
The codes that are constantly thrown when the DCCD is checked with the E-Brake method are 26, 33 and sometimes 37.
What has been done to try to resolve the issue?
- I have replaced the RR ABS Wheel speed sensor (The old ABS sensor was chipped at the tip.)
- I have replaced the dccd module
- I have tested the entire electrical system for the following issues "DCCD engine rpm signal system", "Brake Switch Circuit Range", and "Neutral position switch". Which are codes 26, 33, and 37.
Any feedback or suggestions would be greatly appreciated.
Message Board Statistics All times are GMT -4. The time now is 01:01 PM.
