South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-21-2012, 12:06 PM   #1
insany
Member#: 208652
2006 WRX STI
I was looking to see if someone with an 06 STi could do me a favor and let me use their dccd control module to check if my dccd module is the one causing the dccd to not work. I have tested the entire abs and dccd system, except for swapping out the module that is located behind our glove box. it's 500+ to get a new one and 120 for the dealership to just inspect it -.-, so I'm trying to avoid the dealership inspection.
insany is offline   Reply With Quote
Old 10-21-2012, 01:16 PM   #2
Evil Imports
Member#: 14732
+ 13 B8
Do you have the part number? i am pretty sure i have one i will sell you for $20
Evil Imports is offline   Reply With Quote
Old 10-21-2012, 01:17 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Used ones are affordable since they hard to swap.
Old 10-21-2012, 02:59 PM   #4
insany
Member#: 208652
2006 WRX STI
Part number is 32520AA200
Old 10-21-2012, 03:43 PM   #5
Evil Imports
Member#: 14732
+ 13 B8
just checked, only have AA150 part numbers, (05 sti) i did have a 06 one somewhere, but don't know where it is
Old 10-21-2012, 03:47 PM   #6
insany
Member#: 208652
2006 WRX STI
If by any chance you find it, I'll buy it from you .
Old 10-24-2012, 11:47 AM   #7
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
@ Evil, do i have that one at my house? i'll check tonight.. i thought you had an 06 one too. maybe i have it from when i was troubleshooting Don's DCCD.
Z0rr0 is offline   Reply With Quote
Old 10-24-2012, 05:45 PM   #8
Evil Imports
Member#: 14732
+ 13 B8
I think you do have it, just let me know
Old 10-26-2012, 07:52 PM   #9
insany
Member#: 208652
2006 WRX STI
Did you guys happened to find the part for the 06 sti?
Old 11-08-2012, 11:51 PM   #10
insany
Member#: 208652
2006 WRX STI
Update on the issue: I was able to get a new dccd module and install it to test to see if it was the dccd module that was causing the issue. But it wasn't and my dccd still doesn't work properly. I'm hoping you guys can have some helpful feedback to fix this issue.
Symptoms:
The only time the DCCD works is if it's 75+ degrees outside and the car has been bathing in the sun for a good hour or more. It will also start working if I run the car for about 30 minutes and let the engine heat up, otherwise it will not work properly.
The codes that are constantly thrown when the DCCD is checked with the E-Brake method are 26, 33 and sometimes 37.
What has been done to try to resolve the issue?
- I have replaced the RR ABS Wheel speed sensor (The old ABS sensor was chipped at the tip.)
- I have replaced the dccd module
- I have tested the entire electrical system for the following issues "DCCD engine rpm signal system", "Brake Switch Circuit Range", and "Neutral position switch". Which are codes 26, 33, and 37.
Any feedback or suggestions would be greatly appreciated.
Old 02-04-2015, 02:48 PM   #11
drifte
Member#: 209749
06 STI
Aspen white
Symptoms:
I have this exact same problems and only see code 33. Did you ever find a resolution? Im hoping so since this thread is 3 years old.
I also cant find anything conclusive for clearing the codes for dccd.
drifte is online now   Reply With Quote
Old 03-17-2015, 04:35 PM   #12
skep18
Member#: 214971
2014 WRX
Symptoms:
Ironically enough I also have the same issue. Blinking "O" and codes 26, 33, 37.
I am awaiting a new Nuetral Position Switch from the dealer as mine tested out of range when in neutral.
Any feedback from the OP would be great.
skep18 is offline   Reply With Quote
Old 03-17-2015, 05:11 PM   #13
k3ogh_sti
Member#: 415968
2005 widetrack sti
48w
Yep I'm in the same boat here.... flight flashing etc, I'm getting codes 33 and 37, checked again today and 33 is the only one coming up ! So frustrating
k3ogh_sti is offline   Reply With Quote
Old 03-17-2015, 06:16 PM   #14
kos
Member#: 118334
2005 AW RS + 2006
Time Attack WRX
OP's last log on was September of 2014. Might not get a reply for a bit. Unless anyone locally here knows him personally and could ask?
kos is offline   Reply With Quote
Old 03-17-2015, 06:27 PM   #15
k3ogh_sti
Member#: 415968
2005 widetrack sti
48w
Yea I did notice that dude, hopefully someone can pipe up with a more up to date solution though
