Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 10-13-2012, 08:14 AM   #1
fastblueufo
Visiting NASIOC Timeout
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Default Head Gasket Failure Carnage
So I just went over the 2500 mile mark on my ej22t stroker build. Its been running great on e85 and 25 psi on a conservative tune. Did a quick pull mid way up in 3rd and bam, busted coolant hose. Towed car home and pulled the motor to find this
Do you think it would be worth repairing or just replace the ej22t shortblock? I was using a cometic head gasket and it looked as though the gasket failed between the second and bottom layer, then preceeded to melt through to the coolant passage. This carnage took about 2 seconds or less. Once the coolant hose blew I cut the engine.
fastblueufo is offline   Reply With Quote
Old 10-13-2012, 08:43 AM   #2
biodude
Member#: 271720
sucks, i wonder if welding and resurfacing an option
biodude is offline   Reply With Quote
Old 10-13-2012, 09:00 AM   #3
tibug
Member#: 273906
2003 Outback 2.5
1993 Dakota 3.9 4wd
I would use JB Weld because I am an idiot. But really, I did use JB Weld on a block, but not on a gouge that enters into the cylinder. Good luck whatever you decide to do.
tibug is offline   Reply With Quote
Old 10-13-2012, 12:06 PM   #4
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
That looks a lil longer than a 2 sec prob, it was prolly leakn a bit then finally pushed enough cyl gas into the water jacket to burst the hose.. just a guess tho.
If you have access to more 22t blocks then I'd scrap it, unless u have cheap connections to weld n fill that & then have it decked.
G/L
Old 10-13-2012, 02:29 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Time for sleeving!
Old 10-13-2012, 06:26 PM   #6
lavid2002
Member#: 226864
2005 PSM WRX
18.5lb. 93 oct, DP, UP
Really kinda hard to see exactly what's going on here. Hit it with a scotch brite pad and snap another pic??
Old 10-13-2012, 11:27 PM   #7
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I had that happen to an engine once and I welded it and had it surfaced and it worked for many years till I sold it. sleeving would be better though.
Old 10-14-2012, 01:15 AM   #8
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
It's junk you'll need to replaced it or maybe sleeving it might work?
woodys77 is offline   Reply With Quote
Old 10-19-2012, 10:55 PM   #9
gf8ftw
Member#: 273917
1993 Swaped waggy
0h wow! you weren't kidding thats bad. im afraid my Ej20k is going to look like this when I pull it out.
gf8ftw is offline   Reply With Quote
Old 10-22-2012, 05:13 PM   #10
Paidfor
Member#: 267815
Be in awe
dont hate .)
^Yep.....junk
Ill give you 50 bucks for it lol
It could turn into my treasure
