#26 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
Commmon problems:
Side seat belt has no holder, falls into door seam Clip for lap belt rubs on center console Seat height is different enough to cause uncomfortable driving (especially if you get non height adjust seats) Anyways, I swapped 97 Legacy GT seats into my 90 Legacy LS keeping the 97 rails. The rails bolted fine. I had some seat belt issues so I decided to use the 90 rails with 97 seats. The 90 rails where a little shorter so I dremmeled the front and was able to bolt them to the 97 seats. I then dremmeled out two holes on the outside of each seat to connect the lap belt holder to the side. If you need specifics please ask. I plan to take the 97 Legacy GT seats out and use 91 Legacy Turbo seats instead. The second generation Legacy seats aren't designed as well as the first generation units. Comfort is far higher with the older seats. I ESPECIALLY like that some first gens have Vertical AND Horizontal adjustable head rests cybin: Your overly worried. You dont mind driving a vehicle with 15 gallons of extremely flamable liquid but you want to take out the HEAVILY regulated air bags that have never just deployed for no reason?
#27 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
I'm still kicking myself for picking the V8 over the V7 to install on my MY00 - I should have been driving in the STi seats starting late September...
#28 |
Member#: 611
Vehicle:'05 E55 AMG GetADomTune.com |
I'm looking for info on swapping height adjusters on JDM seats from my drivers seat to the JDM passenger seat so I can keep my adjustments.
I looked for Imprezer info on it but that too long ago and i couldn't find anything. byron |
#29 | |
Member#: 48667
Not true. People have been hurt badly by airbags going off. The warning label even states that they can go off accidentally. Emergency workers have been hurt when they try to cut though the car and hit a side impact airbag. I drive with the gas becouse I have too, No sense driving around with airbags that are not hooked up.
Anyway heres one website with more info. http://www.airbaginstitute.com/page573219.htm Quote:
#30 |
Member#: 21581
Vehicle:2004 WRX Wagon WRB |
What about the Spec C Sti seats....I would love to put a set of those in my 2000 RS Coupe. Will those fit? I think those are '03...not sure though
#31 |
Member#: 172486
Vehicle:95 V4 STi-RA swap Stage 49.8 |
Hey lookie here.
A thread. Anyone know what seats can fit in a GC? Can STi seats fit in the stock L brackets? |
#32 |
Member#: 233965
Vehicle:2011 WRB WRX 2000 Impreza L |
Would it be possible to swap a 98 Outback rear seat into my 95 Impreza sedan? Ive never seen the inside of an Outback so I have no idea, if they wont fit, would the seat cover swap?
Thanks for any help! |
#33 |
Member#: 130968
Vehicle:09 Forester XT Red |
has anyone put 08-09 wrx seats in a 07 and older wrx?
#34 |
Member#: 41012
E. Canada
Vehicle:1998 Legacy L |
Bump from the dead. Might be common knowledge but...
2002/2003 WRX Sedan Front and Back seats will fit in a 95-99 Legacy Sedan. A couple of notes though: You have to use your Legacy seat belt clip and a spare nut/bolt. The lowest position of the WRX seat is only slightly lower than the highest position of the Legacy seat. Only 4 of 5 front seat bolts line up. The rear seats fit well although there is a slight gap so you can see the top of the strut from the rear triangle window. Despite this, it's worth it, the stock Legacy seats are crap! Now, which year WRX Wagon seats will fit a 2004 Impreza wagon? I assume: 2002-2007 Front will fit, 2002-2005 Rear will fit? Anything else? |
#35 |
Member#: 200436
Vehicle:2004 Forester XT Black |
Another bump from the dead.
I am looking to see what needs to be done to swap a 2003 WRX wagon REAR seat into my 1995 L Wagon. Does anyone have any experience with this? |
#36 |
Member#: 299654
Vehicle:2002 WRX WRB |
What year sti seats will fit in a 2002 wrx?
#37 |
Member#: 85932
Vehicle:2005 STi / 2013 STi 2005 Forester XTi |
#38 |
Member#: 302570
Vehicle:2012 Impreza Ice Silver Oil Burner |
So- my 2012 Impreza has seats that I just dont find comfortable. Plus I keep hearing a sqeaky spring sound from the backrest shoulder area. SOA is supposed to be fixing it but the noise is intermittent so its hard to replicate on command.
I really like this car other than the seats. I've driven Legacy's and find their seats to be much firmer and more supportive. Would Legacy seats fit/work in an Impreza? And also what to do about the side airbag?? Any help or suggestions would be great. Thanks. |
#39 |
Member#: 317671
can anyone advise is 2001 impreza rs seats will bolt in to my 1992 subaru loyale? Thanks
#40 |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
I beat all the 'it sits higher' complaints
02/03 seats Ver6 bottom foam Stock 98 rails And my harnesses remedy any seatbelt issue I have |
#41 |
Member#: 301690
bump from the dead yet again. I've been told 02 and 03 wrx seat belts may be different...although I'm having a hard time believing it. can anyone substantiate this claim? Can I use 02 buckles with 03 wrx belts?
#42 |
Member#: 338934
Vehicle:1998 Impreza L Wagon Red |
Will 2000 2.5rs coupe seats fit a 98 impreza wagon L?
#43 |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
| Thread Tools | |
| Display Modes | |
| Axle swap, what will fit? | tooocool49723 | Transmission (AT/MT) & Driveline | 0 | 07-19-2009 09:27 AM |
| What seat belts will fit in an 01 wagon? | imprzya | Interior & Exterior Modification | 1 | 05-12-2008 03:36 PM |
| what turbo is this? and what will fit in its place? | kaneda3 | Factory 2.5L Turbo Powertrain | 15 | 02-06-2007 12:23 AM |
| What will fit in a 92' Legacy? | CjHermsen | Subaru Conversions | 12 | 06-13-2003 04:16 PM |
| What speakers will fit in stock locations in WRX? | boo | Car Audio, Video & Security | 0 | 04-17-2001 08:59 PM |
