Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 10-23-2012, 04:59 PM   #26
MRF22
Member#: 210516
2005 Sti
AW
Originally Posted by Wicked Innovation
Tripintaz, its the same for all 32 bit.
MRF22. Well he is wrong, so if he doesnt know how the rear o2 works, how did he tune it to not influence anything? lol.
If you have logging ability log AF Correction 3 (32 bit) and see if it has a value other than 0.
M@
I don't have logging ability.
MRF22 is offline   Reply With Quote
Old 10-23-2012, 05:54 PM   #27
Tripintaz
Member#: 245218
2013 STI Limited
Originally Posted by MRF22 View Post
Ok so my tuner said he tuned it so the rear O2 sensor wasn't at play. He seems to believe that the only thing the rear is used for is making sure the cat works. I'm so confused.
So should I put the rear O2 sensor in?
Your tuner is wrong at least in this scenario. Many of the newer cars with OBD2 only use the rear O2 for catalyst efficiency monitoring. However, Subaru decided to also allow the rear O2 to influence your fuel trims. he probably thinks disabling the CEL for rear O2 was all that needs to be done. However, that only tells the ECU to not throw a code for poor catalytic converter efficiency.
You should put the rear O2 back in.
I just checked the newest version of ATR and you can tune the Rear O2's short term fuel corrections to equal 0%. I do not see anywhere that you can adjust how it affects the long term fuel trims. However, logically if there are no short term fuel trims then the ECU cannot learn any long term fuel trims from the Rear O2. It seems that changing this will eliminate the need for a rear O2. Not sure if any other tuning solutions can do this.
Old 10-23-2012, 06:03 PM   #28
Wicked Performance
Member#: 265606
As I stated above you can do this in opensource as well by hex editing the binary directly, and it works exactly as you concluded.
Leafy says this is included in some experimental OS definitions.
This is a great topic.
M@
Wicked Performance is offline   Reply With Quote
Old 10-23-2012, 07:00 PM   #29
MRF22
Member#: 210516
2005 Sti
AW
Thank you all for the advice.
