Old 10-18-2012, 09:03 PM   #1726
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
Originally Posted by thrasher View Post
Sorry, but this makes me think of this:
shaggin' wagon
garudatwo is offline   Reply With Quote
Old 10-18-2012, 09:48 PM   #1727
kevinnz
Member#: 327921
Does this count?
For those that are gonna say "You lost your highbeams" I have bixenons
kevinnz is offline   Reply With Quote
Old 10-18-2012, 10:37 PM   #1728
easterbran
Member#: 307359
'05 STi Stage II
Originally Posted by kevinnz
Does this count?
Sweeet
Old 10-19-2012, 12:47 AM   #1729
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Originally Posted by atf78
Sorry, I know it's not the best write up.
Gonna do this now. very helpful in helping someone in the right direction
Edit...
Hey was wondering if anyone know how or has changed the coloring of their clock/temp/mpg display.
krzywhtboi82 is offline   Reply With Quote
Old 10-19-2012, 12:39 PM   #1730
alt14
Member#: 271928
2007 Impreza 2.5i SE
Does this count?
You stole my lights! Lol they look exactly like mine except I kept my high beams with the bi-xenons, looks awesome to see it on a newer style
alt14 is offline   Reply With Quote
Old 10-19-2012, 07:05 PM   #1731
sfk1412
Member#: 290974
2005 WRX Wagon
Tired the emblem mod came out alright but not like I wanted. I also snapped a chunk off them emblem off during removal :-( and I messed up sanding it so I ended up sanding it all and painting the background black. I had some stage gels left from my cluster color change so I threw that behind it for fun. All in all good write up atf78. Easy to follow and gave me something to do!
Untitled by sfk 1412, on Flickr
sfk1412 is offline   Reply With Quote
Old 10-20-2012, 01:02 PM   #1732
kolten493
Member#: 222633
05 WRX R.I.P :(
02 race car bugeye
not anything super crazy but i got bored the other day and built an aluminum cover for my ABS pump.
The "R" sticker is just temporary, it was part of another sticker i had laying in my toolbox.
also not seen from the pic are the secondary bends on the right side to aid in rigidity
will have installed pics later
kolten493 is offline   Reply With Quote
Old 10-20-2012, 11:10 PM   #1733
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Stupid question probably here. Has anyone rewired their fogs so you retain factory on/off switch but also have them come on for drl or when u turn parking lights on. I'd like to do this haven't decided if I want em one as parking or drl. But either way I do want to still be able to turn em on(drl option) or off
Old 10-20-2012, 11:17 PM   #1734
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
I do.
When the headlights are on, I can turn the fogs on/off via the switch.
When the headlights are off, I can turn the fogs on/off via the handbrake lever (one click, doesn't actuate the brake, do correct me if I'm wrong).
Old 10-20-2012, 11:20 PM   #1735
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Originally Posted by garudatwo
I do.
Yea but then I have the stupid brake light on lol. Good idea but might wear down brakes at first
Old 10-20-2012, 11:26 PM   #1736
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
TBH I don't know if the brakes will wear at one click or not, better ask someone more experienced.
I have my fogs on all the time.
Before someone tells me I'm a [insert insult here], let's face it, these aren't really functional fogs, they're just for aesthetics. So, there shouldn't be a problem with having them on simply 'cause the car looks cooler that way right?
Old 10-20-2012, 11:58 PM   #1737
HoboBob
Member#: 253560
03 VW Golf
Slow
Unless your handbrake is out of control tight it shouldn't wear out at one click. And even if it is if you drive around for 30 seconds it'll wear down to where it would not be a problem anymore.
Also I think in certain states it is illegal to drive around with your fog lights on? Don't quote me on that, I may be very wrong Also many states prohibit more then 4 forward facing lights, so if your state is one of them you should be careful of that.
HoboBob is offline   Reply With Quote
Old 10-21-2012, 12:20 AM   #1738
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
Thank you Sir Hobo, that's what I figured.
Now here's another question: are they still considered fogs if they're wired up as DRL's, such that the the regular DRL's are off and the fogs replace their function?
That said, My understanding is that you can't have more than 4 lights ON at the same time, and the fogs will still turn off automatically when the high beams are on.
Old 10-21-2012, 01:03 AM   #1739
emazz104
Member#: 281811
04 WRX
I was looking for this a while ago, and couldn't find anything.
Basically what I wanted (and I think this is what you mean) is a separate fog light switch. So the fog lights would act completely normal, using the original switch and come on and off with the headlights, but then have a separate switch so if the headlights are off you can turn on that switch and turn on just the fog lights.
It seems that it can't be (simply) done, unless I overlooked something.
I would really like the answer to this as well.
emazz104 is offline   Reply With Quote
Old 10-21-2012, 01:48 PM   #1740
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Yea that's what I want I relocated my to behind the grill slapped some Sylvania zxe bulbs in and now they are deff more functional. But want as fog option and drl. Still debating though if I want em as drl or when I turn parking on.
Edit
I think drl would be easiest. Just find how it's wired to high beams and the just reroute it to the fogs
Old 10-21-2012, 02:26 PM   #1741
emazz104
Member#: 281811
04 WRX
Edit
But then they wouldn't function normal as well. You could always just do the independent mod.
Old 10-21-2012, 06:20 PM   #1742
TeamBAMF
Member#: 333337
2004 Forester XT
Red
Originally Posted by HoboBob
Been meaning to do this for a while just to see how it looks. I don't think its so bad. Cheaper then an aftermarket steering wheel and I get to keep my airbag!
Also never mind all the dust. I just got it back from a body shop and its rather dusty now
What did you use? If this is electrical tape I doubt it will last long if you live in the southern states
TeamBAMF is offline   Reply With Quote
Old 10-21-2012, 08:57 PM   #1743
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Why not? Factory drl is through high beams but to still can use them. Just askin bc I don't know. And I haven't looked to see good It's wired yet
Also fyi for those that don't kno you fwb adjust the fog lights up and down. Didn't fig this out till after I took em out.
Old 10-21-2012, 10:48 PM   #1744
kevinnz
Member#: 327921
nice dude! post up a picture i want to see
Old 10-22-2012, 11:07 PM   #1745
unlucky2267
Member#: 256778
2002 wrx
modded sti axle back:
finished product:
rotated manifold:
led headlights:
modded grill and fmic cover up:
unlucky2267 is offline   Reply With Quote
Old 10-23-2012, 06:36 PM   #1746
hoofhearted
Member#: 293554
I know this has been done before but just thought i would share. Suede headliner.
hoofhearted is offline   Reply With Quote
Old 10-23-2012, 07:28 PM   #1747
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
mmmm that looks terrific. did you take out the original mouse-fur headliner or can you put the suede over it? did you do it yourself?
burkart is offline   Reply With Quote
Old 10-23-2012, 07:57 PM   #1748
hoofhearted
Member#: 293554
I paid to have the headliner done because I didn't want to deal with it sagging in the future. I did everything else my self. I removed the headliner and dropped it off to have the suede wrapped over it. Total cost for everything was $120. They charged $60 to wrap it for me.
Old 10-23-2012, 08:05 PM   #1749
burkart
Member#: 305000
2005 Legacy GT 5MT
that seems pretty reasonable actually. so you mean, you did the pillar trims and stuff while they did the large roof-lining piece? also, where did you go? i feel like a good tailor might be able to take on a job like this? i dislike car custom stores.
impressive, regardless. taking that thing out [without becoming enraged and ripping it] is really hard, and installing it has got to be worse...
lets get them sunvisors next =]
Old 10-23-2012, 08:13 PM   #1750
burkart
Member#: 305000
2005 Legacy GT 5MT
$120 for materials and labor? i am five clicks away from ordering a ream of hypersuede
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
Message Board Statistics All times are GMT -4. The time now is 06:39 AM.
