Old 10-29-2010, 09:54 PM   #51
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
What about an outback H6 with 4EAT? not sure on year.
Tbird Man is offline   Reply With Quote
Old 11-02-2010, 01:16 PM   #52
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
NVM, found my answer
Old 11-03-2010, 12:25 AM   #53
Tbird Man
Member#: 71991
1999 Legacy GT Ltd.
Ok, it is my understanding that all outbacks 2001+ have a rear LSD, right? or at least all that have the cold weather package? cause there is an '01 OB H6 LL Bean in my JY that should have a 4.11 ratio to match the 5mt i want to swap into my GT.
Old 10-23-2012, 08:53 PM   #54
twinturbosubaru
Member#: 54781
1986 subaru xt
white
Ok I found the right place I think for my question.... Currently I have a 2003 wrx manual in my 1995 legacy L and I ruined my manual transmission and I was looking around at rear diff ratios and is the 04 STi really the only other transmission I can find to work with my diff? Can someone else please tell me there is like a TS or RS transmission I can use? these stock trans are so expensive...
twinturbosubaru is offline   Reply With Quote
Old 10-24-2012, 01:24 AM   #55
91legacyawdturbo
Member#: 177706
Can anyone tell me what rear cv's I can use on a Japan spec 02 sti r180 diff to a 97 legacy outback hubs. The legacy outback has smaller spline count? But still has a r180 rear diff.
Thanks.
91legacyawdturbo is offline   Reply With Quote
Old 02-15-2013, 01:33 PM   #56
sapperd06
Member#: 347135
Default 2002 Forester LSD swap
Since I can't post a New Topic and its not covered here. I have a 2002 forester a/t 4.44 open diff and i found a 2001 4.44 LSD, I would like to put the LSD in the 02. My question is are the axles different and would there be and other mods i would have to do to swap it. All the parts look ups i do only list 1 cv axle not 1 for the open and 1 for the lsd. But thats where i need the help, please
Thank you
Don
sapperd06 is offline   Reply With Quote
Old 02-23-2013, 12:21 AM   #57
sapperd06
Member#: 347135
Default 02 forester lsd swap
Hi,
I have a 2002 forester 2.5l, a/t, Rear Drum Brakes, 4.44 open diff, and i found a 2001 4.44 LSD, I would like to put the LSD in the 02. My goal is for better traction in the snow/icy conditions in Buffalo, NY. This is not for off roading or racing, just a daily driver. I ask because my 04 Forester has a LSD rear end and it is so much better in the snow.
So My questions are:
1. Are the axles different between the open and lsd All the parts look ups i do only list 1 cv axle, not 1 for the open diff and a different 1 for the lsd.
2. Is there any difference in the driveshaft length or ujoint size from the tranny to the rear end
3. Would there be and other mods i would have to do to swap it.
4. I have done a search but couldn't find a write up on this, if you know of a write up please let me know.
5. and last, instead of the doing the carrier swap, would it be better to replace the internals with an aftermarket LSD, (money is the concern with this option)
Thank you
Old 02-23-2013, 06:15 AM   #58
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
'01 diff should be a direct replacement.
slow03 is offline   Reply With Quote
Old 10-24-2013, 12:28 PM   #59
nosajh9
Member#: 85435
02 Impreza RS 2.5L
I have an 02 RS 2.5 4EAT made in Canada. Does this car have limited slip differential?
nosajh9 is offline   Reply With Quote
Old 10-24-2013, 12:43 PM   #60
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Did you use the 03 wrx rear diff when you swaped? 02-03 wrx 5 speeds are 3.90 front but the rear is 3.543 due to the 1:1.1 transfer gears.
AFBeefcake is offline   Reply With Quote
Old 07-20-2014, 08:59 PM   #61
tjscoobs91
Member#: 391516
.Quick question. I have an '02 wrx wagon. Auto transmissio˝
Is this equipped with rear lsd?
tjscoobs91 is offline   Reply With Quote
Old 07-20-2014, 09:32 PM   #62
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it has a viscous coupled lsd in the rear end
Sent from my SCH-I545 using NASIOC mobile app
Old 07-20-2014, 09:39 PM   #63
tjscoobs91
Member#: 391516
Great. Thanks for that clarification. I recently replaced the diff with an identical from the salvage yard. I put 75w90 gear oil in it. Should i have used an additive? Or should i just drain it and use a genuine subie product?
Old 07-20-2014, 09:48 PM   #64
d00000000000000d
viscous units are sealed....you use regular lube in rear ends with them
Old 10-14-2015, 04:30 PM   #65
vascorama
Member#: 429701
2002 Impreza WRX
Grey
I have a 2002 wrx, is there a way that, by looking at th housing, to tell if it has or has not lsd? By the way the car behaves i don't think it has...just need to be certain before planning a possible upgrade. Thank you.
vascorama is offline   Reply With Quote
Old 10-14-2015, 04:37 PM   #66
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
02 usdm definitely had a viscous rear LSD, but it is weak. not sure about foreign market.
'02 WRX 6 spd STI Conversion with r180 rear LSD & DSS (Drive Shaft Shop) Rear CVs nissaneng Transmission (AT/MT) & Driveline 16 03-17-2010 01:39 AM
Car came with intake, what AP options do I have? ST3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-02-2006 12:25 AM
4.11 Tranny with Matching Rear LSD Diff JoeT Private 'For Sale' Classifieds 17 02-10-2005 04:31 PM
Are the painted side skirts the same size as the plastic ones that my car came with? RyanRock Interior & Exterior Modification 5 05-13-2004 06:33 PM
I wish my car came with a hand gun accessory Stroke Off-Topic 9 09-05-2003 12:55 PM
