Old 11-18-2011, 09:04 PM   #26
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Originally Posted by azn2nr View Post
See the raw data makes it look less dramatic
disagree - i see 80wtq & 90whp gains around 5000rpm, thats pretty dramatic.. look at it this way:
Originally Posted by PPhilthy View Post
you can digest the information anyway you want, but the fact is the BW S300SX FMW is a ridiculous good turbo and absolutely unmatched for the price point
agreed
The BW S300SX FMW, by far has out performed any of my previous setups... I have spent a lot of time and money trying to make this car a respectable fast daily driver, and had all but given up before Geoff told me about this new BW turbo...This turbo just flat out kicks butt - good boost threshold, makes great power all they way up to my 8000rpms rev limiter, and the boost recover between shifts is just flat out instantaneous...I admittedly was surprise to see the boost threshold of a 35r and the power of a much larger turbo.
i promise that if you listen to me for turbo advice you wont be disappointed
Originally Posted by Beetspeed View Post
Yeah, me too Geoff! I can understand it won't be a large difference, but I would still find it very interesting.
id like to see these.
here you guys go! this is the low boost run at 1.55 bar boost, red = flat tip blue = cupped tip. obviously the red tip is the winner at this flow rate. I can not find the high boost run on my laptop, its on the other computer. the blue had a slight advantage at the higher boost, but red still spooled faster obviously
Originally Posted by jkopinga View Post
Billet wheels are MUCH lighter than their cast counterparts. I believe it would be in the region of 30~35% weight saving of the comp. wheel. Looking forward for somebody to do a weight comparison between the 2 compressors. Geoff...??
that is 100% incorrect - the billet wheels are typically slightly heavier by a couple grams. I have not seen any single comparison where the billet compressor wheel was less weight. believe it or not many of BW's cast wheels like the S200SX 7670 and S300SX 9180 (66) are just as good as the EFR series' FMW counterparts, they just have a slightly different trim on the compressor side
does bw have plans on utilizing fmr technology in 57 and 66mm turbo sizes.
no this will not happen
is the s300sx3 66mm avaiable with both types of turbine wheel? i was under the impression from talking to someone using one that it was cupped tip but i cant find a turbine wheel style option when ordering the fmr on your site, and i didnt see the sx3-66 but maybe im just blind.
the FMW billet compressor wheels
the S300SX3 66 is an excellent turbo - and shares the same turbine blade aero as the EFR. the compressor wheel is also badass, in fact its almost as good as the efr, but way less cost and much better availability. That particular turbo is ONLY available with the cupped tip (the flat tip does not work well on that blade shape and size, so was never put on the market)
As you know, I have the cupped tip version of that 75mm turbine wheel and I think I haven't even made the turbo sweat much at 400 whp and 1.6 bar boost A little better spool is always welcomed though, but you know that Is the 83mm FMW any lighter in weight then the 83mm cast wheel?
your turbo is almost identical to this FMW turbo, its really a great unit!!
Full-Race Geoff is offline   Reply With Quote
Old 11-18-2011, 09:13 PM   #27
n2oiroc
Member#: 141952
03 11 wrx/13 brz
#1. i better not be!
#2. you forgot the graph.
n2oiroc is online now   Reply With Quote
Old 11-19-2011, 12:10 PM   #28
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm looking forward to having a little chat at PRI
Old 11-20-2011, 06:51 AM   #29
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Geoff,
I am not too familiar with the BW cast comp. wheels and FMW counterparts but I DO know for a fact that the weight savings on for example:
- Billet 16G
- Billet 18G
- Billet 20G
- Billet 30R
- Billet 35R
Are almost 30% savings compared to that of their cast comp. wheel counterparts. I can post the weight comparisons if you are interested. Perhaps BW takes a different approach then aftermarket manufacturers like Precision or Blouch for their Billet wheels.
Jasper.
jkopinga is offline   Reply With Quote
Old 11-22-2011, 09:22 AM   #30
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
OOPS sorry about that, here it is again:
using the old S300SX 8375 (not FMW) this is the low boost run at 1.55 bar boost, red = flat tip, blue = cupped tip. obviously the red tip is the winner at this flow rate. I suspect philthy would see the same on his subaru if he tried to test. however, his evo at 40psi boost might be a little different..
- Billet 16G
- Billet 18G
- Billet 20G
- Billet 30R
- Billet 35R
please post the weight comparisons, I have never seen anything like this re weight differences. Yes - BW definitely takes a different approach than the aftermarket guys - mainly becuase they *forge* the wheel first, and then machine it... its a forging not just a chunk of billet so it is MUCH stronger with better grain boundaries, but slightly heavier due to the higher density forged alu
fwiw i met the head of MHI's turbo division recently - he commented that the 16G was one of their highest performing compressor wheels, and was actually designed & shaped by hand originally - not done with CFD software. that blew my mind
Raffi and I will be there thurs and fri - stop by! He will be there on sat also, but I will not
Old 11-22-2011, 01:27 PM   #31
3MI Racing
Member#: 200987
^^Raffi already emailed me saying you guys will be at the Borg booth. I'll be stopping by.
-Micah/Homemade WRX
Old 11-22-2011, 01:27 PM   #32
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
That was indeed my interest as what approach they have choosen to go with: use the extra material strength to make a lighter but -as strong- wheel as the cast one, OR use the stronger material to just make a much stronger wheel with equal weight.
Question then is why this approach was chosen? BW (as Garrett if I'am not mistaken) obviously felt the wheel could use the extra strength, which is a little strange from my point of view as I have never seen or heard of a compressor wheel breaking other then from injesting foreign objects?
You've spoken a lot with BW's technicians Geoff, any idea why they did not use the forged billet material for making it lighter so even faster spool could be had?
Or is it that the better aero from the billet wheel is more 'aggressive' towards the forces it puts on the wheel, hence the need to make it stronger at the same time?
Thanks in advance,
Walter
Beetspeed is offline   Reply With Quote
Old 03-15-2012, 02:04 PM   #33
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
long term review?
bhhamblin is offline   Reply With Quote
Old 03-15-2012, 04:39 PM   #34
PPhilthy
Member#: 102948
2006 STI
Long term update - it still puts a silly grin on my face every time I drive it
I have only one issue, my wife is on my ass to scale back on the number of cars I own (currently 6) and I may need to part with it
To be 100% honest, I've tried so many different setups and turbo's on this car and have driven friends cars with all the other variants - there is no question that this is the perfect setup that's 100% daily driver friendly/fun and has the grunt to get up and go when needed... For the money, the SX300 FMW is in a class of its own! I honestly disliked this car with the 40R - Geoff can confirm such, we are very good friends and the first (and only) argument we EVER had was over that turbo lol... I fell in love with my STI with just switching turbos, I still can't believe it...
PPhilthy is offline   Reply With Quote
Old 03-16-2012, 02:45 AM   #35
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ sounds like late night TV advertising lol
Old 03-17-2012, 01:17 AM   #36
azn2nr
Member#: 35276
when does the car reach 20psi? in 3rd or 4th
azn2nr is offline   Reply With Quote
Old 03-22-2012, 04:35 AM   #37
mystilexzero
Member#: 154674
2007 wrx
ugm
damn and i just purchased the 83/75 a year ago. are the compressor and exhaust housings the same? is it worth upgrading to the fmw version?
mystilexzero is offline   Reply With Quote
Old 03-28-2012, 11:39 AM   #38
PPhilthy
Member#: 102948
2006 STI
Old 10-23-2012, 07:54 PM   #39
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
bump in case you didnt see it: http://forums.nasioc.com/forums/show....php?t=2420776
another great S300SX FMW result courtesy of Cam Tuning (Cameron) and InurSteye (timmy) on his 08 Sti
Old 10-23-2012, 09:54 PM   #40
TIGWERKS
Member#: 256615
Geoff have you had anyone run the s300sx fmw in a duramax yet and have good results?
TIGWERKS is offline   Reply With Quote
Old 10-24-2012, 02:25 AM   #41
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Is that 660hp Wheel hp or corrected for flywheel hp?
Thanks,
Walter
Old 10-24-2012, 06:07 PM   #42
masterw00t
Member#: 232294
2007 WRX STI
Out of all the turbos that you've tried what would you say is the most cost/power efficient?
masterw00t is offline   Reply With Quote
Old 10-24-2012, 06:28 PM   #43
inursteye
Member#: 271879
Thanks,
Walter
660 Corrected for altitude, I made 560 at the wheels uncorrected at 5400' elevation.
inursteye is offline   Reply With Quote
Old 10-24-2012, 07:49 PM   #44
stang352
Member#: 110089
2006 STI
Very nice! Can't wait to finish my build and install this kit. Good stuff!!
stang352 is offline   Reply With Quote
Old 10-25-2012, 06:56 PM   #45
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
WHP, feel free to contact cam directly with any questions - he's a competent and honest tuner
We've actually had a lot of customers using the S300SX FMW on diesel applications with great results. Most of them were cummins 6 cyls, but I will ask one of our distributors about the duramax they were working on
Old 10-30-2012, 07:32 PM   #46
TIGWERKS
Member#: 256615
[quote=Full-Race Geoff
We've actually had a lot of customers using the S300SX FMW on diesel applications with great results. Most of them were cummins 6 cyls, but I will ask one of our distributors about the duramax they were working on[/QUOTE]
Would appreciate it, thank you.
Old 10-30-2012, 10:43 PM   #47
dub kllr
Member#: 129996
97 RHD STi
Ghey
YES! Kudos to you guys for running a real man's turbo on these cars. BW builds some incredible turbos. I was infatuated with my S362.
dub kllr is offline   Reply With Quote
Old 12-31-2012, 06:44 PM   #48
WhatTurboLag?
Member#: 243992
2006 WRX TR
Now that pricing came down a LOT on these kits, I will be doing this exact setup.
Old 12-31-2012, 11:33 PM   #49
stang352
Member#: 110089
2006 STI
Hi Geoff - I sent you a PM regarding this particular kit. Can you please get back to me ASAP? Thanks! --Pete
Old 01-01-2013, 11:57 PM   #50
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
damn, that seems to be a nice turbo when cranked up
FS : BorgWarner S300SX 8875 Turbo vangstaboi86 Engine/Power/Exhaust 8 09-12-2011 09:18 AM
Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP alcoolaid Proven Power Bragging 61 10-22-2010 08:49 PM
Twinscroll Borgwarner vs Twinscroll GT35R Full-Race Geoff Proven Power Bragging 345 09-24-2010 12:14 PM
FS : BorgWarner S300SX 88-75 turbocharger $800 Full-Race Geoff Engine/Power/Exhaust 2 06-25-2010 03:42 AM
Buy this monster! Twinscroll Garrett GT4088R... bonzai Engine/Power/Exhaust 16 12-11-2009 03:56 PM
