Old 10-24-2012, 10:16 AM   #1
AVANTI R5
Member#: 73805
Default GM Turns to Magnesium Sheet Metal to Lighten Vehicles
General Motors is pioneering the use of magnesium sheet metal on its vehicles with the possibility of double-digit fuel economy gains.
Other automakers are turning to carbon fiber to help lighten the load on their vehicles, but the General is going another direction. It’s currently testing an industry-first thermal-forming process and proprietary corrosion resistance treatment for lightweight magnesium sheet metal as an alternative to steel and aluminum.
According to GM, other automakers have struggled to reliably make strong and non-corroding magnesium sheet metal panels using traditional panel-forming methods. GM, on the other hand, is working on a patented process that can heat magnesium to 842 degrees Fahrenheit to allow the magnesium to be molded into precise, rigid shapes.
Magnesium weighs in at 33 percent less than aluminum, 60 percent less than titanium, and 75 percent less than steel helping lighten vehicles and in turn, increasing fuel economy.
The American automaker is showing off a production-ready magnesium rear deck lid inner panel that has been tested to withstand 77,000 robotic slams and 250-kilogram impact drops without any problems.
Old 10-24-2012, 10:22 AM   #2
SCRAPPYDO
Member#: 873
2013 Golf R
1971 240Z
Well it is a good thing magnesium is not highly flammable or anything
SCRAPPYDO is offline   Reply With Quote
Old 10-24-2012, 10:41 AM   #3
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
nor expensive...
Old 10-24-2012, 10:46 AM   #4
SCRAPPYDO
Member#: 873
2013 Golf R
1971 240Z
fast forward to about the 1 minute mark when the magnesium transmission case gets hit with the water...
Old 10-24-2012, 10:49 AM   #5
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Originally Posted by SCRAPPYDO
Video Link: http://www.youtube.com/watch?v=KY9ri-UOoLo
Whoa!!!!!!!!
Navendra94 is online now   Reply With Quote
Old 10-24-2012, 10:55 AM   #6
Rootus
Member#: 89821
2013 WRB WRX Sedan
2011 Outback
Stupid GM, why the hell didn't they remember to come to NASIOC first to make sure this wasn't a horrible idea?
Rootus is offline   Reply With Quote
Old 10-24-2012, 11:04 AM   #7
White out
Member#: 46277
** Ring Time of
7:43.5
Great idea and alternative to carbon, plastic, or fiberglass
Based on the Viper community, I have a feeling that a lot of GM body panels are going to be melted accidentally in the future.
White out is online now   Reply With Quote
Old 10-24-2012, 12:02 PM   #8
poorlilpoop
Member#: 54666
2005 WRX
I can't remember where I read it. But the article talks about how car companies are trying to make lighter cars, but it get's cancelled out because americans are getting fatter. we are nation of fatties
Also, not too keen on magnesium. They burn hot as hell. Their burning temp is off the chart. I'm sure the GM knows properties of magnesium.
Hopefully, it will turn out well. If not, there will be crap load of people ready to sue.
poorlilpoop is offline   Reply With Quote
Old 10-24-2012, 12:13 PM   #9
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
If only GM had the existing technology to build vehicles with plastic or fibreglass bodies.
Old 10-24-2012, 12:29 PM   #10
lark6
Member#: 2715
05 FXT
70 911T
I was expecting footage of LeMans 1955 but this will do.
lark6 is offline   Reply With Quote
Old 10-24-2012, 12:32 PM   #11
Rootus
Member#: 89821
2013 WRB WRX Sedan
2011 Outback
That's silly, unless you believe car companies can only figure out how to shed 25 pounds of weight.
It's not just the U.S. Any place that has easy access to calories tends to see an increase in average weight. Biology is a bitch.
Old 10-24-2012, 12:38 PM   #12
hughjass5976
Member#: 226004
2004 sti
+1234
hughjass5976 is offline   Reply With Quote
Old 10-24-2012, 12:47 PM   #13
left footed whooten
Member#: 44652
06 Eastern Sierra
Assault Wagon
Why not stop pumping weight into the damn thing in the first place? Make your engineers work and work with them.
left footed whooten is offline   Reply With Quote
Old 10-24-2012, 01:06 PM   #14
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
Is it 100% magnesium or is it some hybrid mix like with aluminum or something?
--kC
KC is offline   Reply With Quote
Old 10-24-2012, 02:27 PM   #15
sxotty
Member#: 95600
2003 WRX wagon
Maybe they can make a battery case for their PHEVs from this A match made in heaven... or wait was that hell
sxotty is offline   Reply With Quote
Old 10-25-2012, 11:16 PM   #16
TwinscrollGT35R
Member#: 256810
Mag also hates oxygen. And I do not think that was water causing that explosion of white light.
Flames will cause mag to ignite and explode.
TwinscrollGT35R is offline   Reply With Quote
Old 10-26-2012, 09:52 AM   #17
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Once mag is ignited it will burn and keep burning. Road flairs are basically magnesium. Light a flair and through it in water, it will get brighter and keep going. The water is what caused the accelerated burning. The burning will separate the oxygen from the hydrogen and they will both burn.
Never put of a mag fire with water. Any firemen want to chime in?
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 10-26-2012, 10:18 AM   #18
daveyboy
Member#: 35419
GM knows what they are doing and going green at the same time.
A friend of friend told me that they are going to coat the magnesium with a white phosphorus impregnated shellac... .
daveyboy is offline   Reply With Quote
Old 10-26-2012, 11:04 AM   #19
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
Well, it's a good thing I've invested heavily into GM stock paid my taxes.
Old 10-26-2012, 11:12 AM   #20
ADaughen
Member#: 333348
2000 Forester S
Silverthorn/Slate
It's all the federal safety requirements. Crumple zones, ABS required, DSC required, traction control required, air bags required. Add on six speed auto trans, leather, coffee maker, panoramic sunroof, 18 cup holders, quad DVD entertainment systems...
We are just now getting back to MPG numbers we had in the early to mid 80s in gas burners.
My roommate in college got 44mpg with his '85 Honda CRX. I wouldn't want to get hit by anything in that little tub, but it got good mileage and was fun to drive.
My '87 Honda Prelude, in college, got mid-30s mpg, I got as high as 37mpg on a highway run to FL. No ABS, air bags, etc. It was quick and fun to drive because there was nothing to it (2300lbs). If I could find another 1st or 2nd gen in decent condition, I'd probably snatch it up for a DD when I'm not hauling the kids (no room for car seats + >6' driver ).
ADaughen is offline   Reply With Quote
Old 10-26-2012, 11:18 AM   #21
Brahmzy
Member#: 3293
'14 FXT-T
135i..gone > '15 STi?
If this goes into production, it'll be interesting to see insurance rates for those vehicles. I would imagine this would add to the cost of a wreck or simple fender bender, depending on how much of the car is mag. I bet there will be cheap, steel non-oem panels for these cars being made just like every other car. Might behoove the owner to make sure they're getting genuine oem mag replacement panels.
Old 10-26-2012, 11:23 AM   #22
ShadowIMg
Member#: 31519
2009 Legacy spec.B
2001 2.5RS Coupe
Is this a new mil-spec design?
Strangely a decent amount of it comes from safety towards what you hit. The ever-raising body lines and such in cars (which means more body in general also) comes from someone who decided it's safer for pedestrians when they are struck by cars.
ShadowIMg is offline   Reply With Quote
Old 10-26-2012, 11:30 AM   #23
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Magnesium is lighter and therefore will cost less to ship back and forth to China.
nottofast is offline   Reply With Quote
Old 10-26-2012, 11:34 AM   #24
Brahmzy
Member#: 3293
'14 FXT-T
LOL!!!
Old 10-26-2012, 11:39 AM   #25
industrial
Member#: 7250
2013 BRZ
What the hell man?!
industrial is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 09:36 PM.
