Old 10-24-2012, 01:29 PM   #3476
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by climbhigh09 View Post
...you're certainly right. I ran a FFT on the wave forms as well (at idle, so it shifts a bit at cruise), and the nameless was a bit higher tone (maybe 100-300Hz on average), but not enough that the Db levels couldn't be compared with each other.
I'd be interested in knowing how it looks throughout the rev range. Idle is rarely an issue for me. Cruising is where it becomes a problem. A plot of dB, frequency and engine RPM would be very nice to see!
That's certainly possible, though at first glance of the physical characteristics not very sensical. I'd love to go back to the Nameless. All I know... no CEL without it. I have a road-tune in the works, maybe that will correct everything to the degree that the Nameless is happy again.
Either way, I'd expect the WG to be sufficient for my run-of-the-mill setup.
Comparing a suitcase muffler of unknown internal design (Q300) vs. two tiny 5" cans on the Nameless? I think I'd guess that the Nameless would flow better. The pipes may be smaller with the Nameless setup, but I'd have to guess that the muffler is a much larger restriction.
And as for how it actually performs; if you see overboost with one and not the other, then I would hypothesize that the one that is overboosting is flowing better. A tune may be able to fix it.
The wastegate being "enough" for your setup is kind of backwards. The wastegate's job is to hold back the turbo from spinning out of control. The more "tame" your setup (ie. less boost), the harder the wastegate has to work. At 20psi your tiny internal wastegate is being required to flow much more air than my large 44mm EWG needs to flow (at 27psi).
Me too, they guys were great on the phone and 100% willing to support their product. I didn't know they outsourced the y's. too bad they don't look better, as Nameless is responsible for it at the end of the day.
Sorry for the (now) official thread jack, it's been a slow day at work.
Oh well. I don't mind. I had a bunch of stuff to post, but I don't want to interrupt this discussion...
Old 10-24-2012, 01:31 PM   #3477
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
That one looks really nice, but the price is a bit much.
I think the Nameless looks fine. I like the shiny tips.
as long as you aren't looking from a low angle. maybe you could cut a deal with RSD for a price break on the greddy
nameless is $974 with 5" mufflers (1124 with 3.5" tips) and greddy is $1300..possibly less if you shop around or find a coupon...its not a huge difference in price when you are already dropping $1000 for a catback (which is obsurd, but w/e)
Old 10-24-2012, 01:32 PM   #3478
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I would only be considering the Nameless with the Magnaflow muffler.
I'm not planning on spending $1,000 on an exhaust.
Old 10-24-2012, 01:34 PM   #3479
Celery GT-5
Member#: 98210
2002 WRX SRP
its still 924
you should do a virtual dyno with the stock midpipe and no muffler...maybe you could get away with just the nameless axleback. Nameless originally said the 3" midpipe didn't really change the power much, although your situation is a little different
Old 10-24-2012, 01:36 PM   #3480
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I meant that in regards to the "looks from a low angle".
And I'm not spending $1000 on an exhaust.
Old 10-24-2012, 01:43 PM   #3481
Celery GT-5
Member#: 98210
2002 WRX SRP
Old 10-24-2012, 01:51 PM   #3482
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Did you know that used exhaust systems are often sold at lower prices than new?
Old 10-24-2012, 02:15 PM   #3483
Celery GT-5
Member#: 98210
2002 WRX SRP
lol so why are you complaining about the price of greddy SE if you are going used? I'm sure you could find a deal on one
Old 10-24-2012, 02:28 PM   #3484
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Well it sounds so easy when you say it like that
If I could find a good deal on one, then I would have one.
My comment was based on the fact that is basically the most expensive cat back and there are relatively few of them out there, so they're not too common on the used market.
Oh well, I'll be swapping back to stock pretty soon.
Old 10-24-2012, 02:31 PM   #3485
Confucius37
Member#: 291094
why not just keep the stock exhaust? Is it a sound thing or does the stock exhaust (catback) actually have some performance drawbacks?
Confucius37 is offline   Reply With Quote
Old 10-24-2012, 02:37 PM   #3486
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think the performance difference is very minor, and I don't mind it being quiet. So it really just comes down to the stock exhaust looking pretty mediocre compared to some of the better quad tip offerings. But for looks I'm not interested in paying more than a couple hundred bucks or so. Which pretty much means I'll end up with the stock exhaust, lol.
Old 10-24-2012, 03:36 PM   #3487
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
aaaaannnnnd we've come full circle.
INKMAN is offline   Reply With Quote
Old 10-24-2012, 03:43 PM   #3488
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
But...
This plot shows great results from just changing the cat back! Above about 4.5k RPM's there are approx. 25WHP and 25WTQ gains all the way to redline! Minor fueling tweaks were made to the tune to make sure the AFR's were the same, but the boost and timing were left the untouched. For just changing a cat back, this is a very nice result to see. I don't know if the gains would translate to a lower powered setup, but on my car the exhaust really seemed to have freed up some top end power.
So... are you thinking that you might lose some of that power?
ofspunk7 is offline   Reply With Quote
Old 10-24-2012, 03:49 PM   #3489
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Earlier this week I realized it's been 2 whole years since I got my car! I figured I'd post a few photos showing how it's progressed over that time.
Stock (10/24/10):
Snow Tires, SPT Exhaust (11/12/10):
First Snow (11/13/10):
Stage 2, E85 Tune, BC Coilovers (05/29/11):
FMIC, Scoopless Hood (06/13/11):
Roof Rack, Invidia Q300 (07/22/11):
Old 10-24-2012, 03:49 PM   #3490
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Blouch 20G XTR (09/17/11):
Gold 04 STI BBS Wheels (09/29/11):
EWG, Back into Winter Mode (11/05/11):
New Motor (03/05/12):
BBS Wheels Back On (03/11/12):
Mach V Awesome Wheels (03/21/12):
Old 10-24-2012, 03:49 PM   #3491
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
RCE Black Springs and Koni Shocks (04/14/12):
PAR 5 Speed Gears (07/06/12):
Greddy Ti-C Exhaust (08/10/12):
Invidia EL Header (09/25/12):
PAR Straight Cut 2nd Gear (10/15/12):
Current!
Old 10-24-2012, 03:53 PM   #3492
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by ofspunk7 View Post
But...
Oh no. Internet detective. Lol. I meant little to no difference between all the quad tip offerings that use a full size muffler. I do think it will probably lose some power vs. the Greddy Ti-C. I'd like to do some more back to back logs to confirm what I saw before. But I really don't think losing 20HP over the winter is that big of a deal to me.
Old 10-24-2012, 03:56 PM   #3493
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
I called it about 12 pages back.....
smeerone is offline   Reply With Quote
Old 10-24-2012, 03:57 PM   #3494
Celery GT-5
Member#: 98210
2002 WRX SRP
http://forums.nasioc.com/forums/show....php?t=2362469
they do pop up every so often...
Old 10-24-2012, 04:01 PM   #3495
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If the only one you found in the last 6 months is the older (purple tip) version, then I think that proves my point of how infrequent it is.
Old 10-24-2012, 04:01 PM   #3496
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
Yeah I feel you. Once my winter wheels go on my driving gets very mellow (except in snow and ice). I just wasn't sure what you were saying and i knew that you had gains with your new exhaust. I am a fan of aftermarket on your car vs stock setup.
Dude, I really like the black and gold wheels on your car.
Old 10-24-2012, 04:05 PM   #3497
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I bought the Greddy knowing it wouldn't last. I'm kind of surprised it survived through the summer. I still might keep it and put it back on next summer, but if I can use it to fund a quad tip offering that I would rather have, then I'd probably let it go.
Fair enough. I do want to confirm that gains I saw at some point. They seemed pretty obvious, but more logs would be nice. I'm 100% sure I won't mind the slightly reduced power that comes with a very quiet stock exhaust. For putting around town I prefer being quiet.
The gold wheels were definitely the flashiest look I had. They were nice and light too. I just wish they were more than 7.5" wide and I probably would have kept them. Oh the memories...
Old 10-24-2012, 04:07 PM   #3498
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
You can always paint your new ones.
Old 10-24-2012, 04:32 PM   #3499
Celery GT-5
Member#: 98210
2002 WRX SRP
there was at least one other...what is your rush? you could always try a WTB thread
Old 10-24-2012, 06:01 PM   #3500
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
To this day i do not understand how your central differential is surviving so long. Lol.
moonrider_99 is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
