Old 10-24-2012, 02:53 PM   #426
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Just updating
VD Dyno jet
458/441
Actual Dyno jet
461/449
Thanks Brad
renosubby is offline   Reply With Quote
Old 10-24-2012, 03:05 PM   #427
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You make 460WHP and trap 129MPH?
xluben is online now   Reply With Quote
Old 10-24-2012, 03:38 PM   #428
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Originally Posted by renosubby View Post
Just updating
VD Dyno jet
458/441
Actual Dyno jet
461/449
Thanks Brad
Who's Dynojet? Is there an AWD Dynojet in Reno?
Boosted Tuning is offline   Reply With Quote
Old 10-24-2012, 06:58 PM   #429
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
yea Reno just got one about 2 months ago... the 129 trap was at 515 whp on race gas
Old 10-24-2012, 07:01 PM   #430
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
460-475 whp I trapped 126 on 91 oct
515-525 whp is 128-130 trap on 110 oct
Old 10-24-2012, 07:18 PM   #431
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Nice. What shop is it at?
Old 10-24-2012, 07:20 PM   #432
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
street 2 sand
Old 10-24-2012, 09:39 PM   #433
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks!
I want to get to the track badly. Too bad the season's over
Old 10-25-2012, 11:20 AM   #434
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Thanks!
Yea I went 11.02-and 11.04 on 91 oct... I wanted a 10 second pass so bad. The track prepped sucked soooo bad I couldn't get under a 1.78 60 ft.. usually on street tires I can hit 1.58-1.63
Old 10-27-2012, 06:34 AM   #435
RubbleDTD
Member#: 155997
2004 PSM WRX wagon
18Gxt
Wow. This is awesome. Just awesome.
This makes it sooooooo much easier to compare data versus what I was used to before.
This has been a huge help in dialing in my timing & AFR targets during spool for the 18G.
Kudos to you sir! I wish I had discovered it sooner!
RubbleDTD is offline   Reply With Quote
Old 10-27-2012, 01:05 PM   #436
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
RubbleDTD ... just trying to help out. Thats why its free
bbarnhill is offline   Reply With Quote
Old 11-08-2012, 07:17 PM   #437
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
Well, Mr. Barnhill, with the auto update to v1.2.0 of VD I'm a FAR happier camper. I can finally save my profile, which makes using the program Soooo much easier.
Thank you! Sincerely.
I owe you money now.
EDIT:
Done
SeeeeeYa is offline   Reply With Quote
Old 11-11-2012, 11:49 AM   #438
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
EDIT:
Done
awesome!!! I appreciate the support!! Glad it works so much better for ya. I will keep trying to make it better with every release.
Old 11-24-2012, 11:56 PM   #439
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I decided to do some boost vs. power comparisons tonight (just for fun). First I started with a few logs with the MBC backed out all the way. The car was hitting about 20psi and was basically flat to redline. Pulling them up in Virtual Dyno showed nice consistent results!
Because that looked good, I decided to turn the MBC up halfway to where it normally is at. I did a couple logs and it peaked close to 24psi, with a little taper down to around 22psi. Then to finish it off I turned the MBC up to my normal spot and it was just barely touching 27psi and then tapering down close to 24-25psi.
Looking at the boost and torque (for the 24psi and 27psi graphs especially) you can see that I probably did have a slight uphill for run 1 and slight downhill for run 2 of each set. This slightly affected spool and peak torque. But overall the results are very consistent.
And here is the plot with just one run from each boost setting. Solid, incremental gains with each change in boost. This is a nice, easy way to see how increasing the boost can really bump up the power (assuming the turbo is still able to flow enough air). It is great that Brad's software makes it so easy to do a comparison like this!
Old 11-25-2012, 09:42 AM   #440
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
xluben ... good write up man. Wish people would look at the consistency you show here and rethink what they are about to say before they say its Virtual Dynos fault their runs are all over the chart (Garbage in garbage out)
Thanks for sharing that with us.
Old 11-25-2012, 10:54 AM   #441
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
Great exposť of data once again, xluben. And further, great accompanying explanations, especially about the effects of the logging road.
While I lack your vertical numbers, this is the VD-enabled process that has allowed me to flesh out my own Stg2+ tune. By using the same road and VD to first create my tune's consistency, I'm then able to incrementally evaluate the often subtle effects of different variations within my tune. In other words, fine tune. AVCS work is almost impossible without VD, for me.
Interestingly, and again a tribute to VD, somehow all the "numbers" correlate when looking for triangulating data, such as bhp, whp, g/sec, various dyno results etc.
Old 11-25-2012, 11:07 AM   #442
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, if you have a nice smooth road you can definitely use it for fine tuning. Using the exact same stretch of road I'd crucial for consistency.
I posted this in the 50-100mph thread. It is another metric to back up the VD numbers.
I took speedo videos for these runs and the 50-100mph times were as follows:
20psi (400WHP Dynojet): 5.4 seconds
24psi (440WHP Dynojet): 4.9 seconds
27psi (480WHP Dynojet): 4.4 seconds
All of the runs were done twice (once in each direction) and the results were identical (peak numbers within 2WHP in Virtual Dyno and 50-100mph times within 0.05 seconds in the videos), so I think the results are pretty solid.
Of course this is just my car, with my powerband, and the runs were done all in 3rd gear. There will be different results once you add in one (or two) shifts, as well as many other factors. So take it with a grain of salt, but I'm just glad to see the VD numbers do seem to go up inline with the 50-100mph times going down.
Old 01-09-2013, 10:20 PM   #443
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
is there a profile limit? I have 13 profiles saved and saving a 14th, it doesnt appear in the drop down menu.
Old 01-09-2013, 10:50 PM   #444
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
^ Shouldnt be. I have more then that.
Old 01-09-2013, 11:00 PM   #445
Phatron
Member#: 36033
CEO PhatBottiTuning
shut it down, reopened still didnt work. shut it down again...now it works.
im probably just retarded lol
Old 01-11-2013, 12:50 AM   #446
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
hum ... havent tested it with that many profiles. Anyone got a profiles.xml that I can have to test with that has that many profiles in it?
Old 01-11-2013, 12:20 PM   #447
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
I tried this out. This is a nice piece of software man. Thanks for your hard work!
saabarupp is offline   Reply With Quote
Old 01-11-2013, 12:57 PM   #448
Phatron
Member#: 36033
CEO PhatBottiTuning
its fine now. probably just something on my stupid computer.
once i restarted the program twice it started working again and I have added more profiles without issue.
premature postulation on my part.
Old 01-13-2013, 12:58 AM   #449
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
saabarupp: no problem my friend ... just trying to give back to the community and help out where I can.
Phatron: ohhh no worries ... we all are a little premature sometimes hahaha
Old 01-16-2013, 08:19 AM   #450
veel86
Member#: 308550
2006 Wrx STi
Is this showing the whp or hp?
veel86 is offline   Reply With Quote
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
