#201 | |
Member#: 321715
Tri-State
Vehicle:03 WRX PSM |
#202 | |
Member#: 331064
Vehicle:06 Impreza wrx sti WRB |
@jthatch: I had no issue with logging even when WOT with the wch cable ... (baud rate unchanged) |
#203 |
Member#: 321715
Tri-State
Strange, I'll try changing the baud rate back. I've never had issues with a real tatrix cable, Just this. Everything works great until WOT, it just craps out. I'll figure it out hopefully
#204 | |
Member#: 41762
International
Vehicle:04 STi CT-DE-FL rinse+repeat |
Unconnected for logging and Learning View. |
#205 |
Member#: 331064
#206 |
Member#: 331064
Connected the green plug (i was like wtf with the fans kicking on/off constantly) didn't expect that
![]() But no good couldn't read the ROM. Still no idea wether the software on the laptop is at fault or the ECUTEK tune ... i'm thinking it's the latter since i got pretty much everything to work like "Z" has but it won't read the ROM. Looks like this is a far as it'l go ditching the tune is not something i'm eager on. I'd just like to able to completely shut off DTC's but i need to flash the rom to get that done. (for example for airpump delete)But hey ... i'm happy with the romraider logger and learning view so far ![]() |
#207 | |
Member#: 321715
Tri-State
#208 |
Member#: 41762
International
^ yeah, i kind of glazed over the ecutek part...
http://forums.nasioc.com/forums/show....php?t=1027462 |
#209 | |
Member#: 331064
Even though i knew i was going in a dead end street with this i still wanted to try and learn as much as possible. Nonetheless i can now use learning view aswell which is great for me to see how much the engine knocks ... i was concerned after some logs where it knocked during 3rd and 4th gear WOT redline pulls (-4 degrees correction at 5-6k rpm) So far i only drove the car for about 50km's at not so fast speeds/high boost since the battery disconnect. IAM is back to 1 and showing no learned knock anywhere ... however i am afraid that it will show learned knock correction after i've really "given it the beans" ... not sure as to how i can adress this apart from seeing my tuner. This was a 3rd gear pull from a few weeks ago where i first saw the knock https://docs.google.com/spreadsheet/...0ajVBSkE#gid=0 check the 5-6k rpm range ... i highlighted the tables. You can also see my stock injectors are nearly maxed out when power is at it's max. From now on i'm keeping a close eye on things. I really wish i didn't disconnect the battery last weekend ... the day after the cable dropped in the mail but my learned knock correction was all gone. I'll upload the learning view pic in this post later (still on laptop) I know it's going a bit offtopic therefore i'll keep my "knock" stories to this post only. Last edited by Guardian-X-; 10-25-2012 at 05:33 PM. |
#210 | |
Member#: 321715
Tri-State
#211 | |
Member#: 122451
NESIC
Vehicle:01 RSTI w/07 EJ257 6MT Brembos BBSs Interior |
#212 | |
Member#: 274499
NESIC
Vehicle:2007 CGM VF'd WRX 12.9 @ 105mph |
16 bit ECU's run 1-16. |
#213 | |
Member#: 321715
Tri-State
#214 | |
Member#: 122451
NESIC
didn't know if you we're just trolling him haha |
#215 | |
Member#: 321715
Tri-State
#216 | |
Member#: 242246
RMIC
Vehicle:2002 Impreza WRX WRB |
Front ![]() Back ![]() |
#217 |
Member#: 331408
Vehicle:2004 Impreza Wrx Laguna Seca Blue |
You can actually just jump the flashblock with, standard 18G wire from autozone, jump pin 1-2,3-4, then just run a 12V to pin 1 and bam! it works great, currently flashing my 2004 WRX with this method. May need to turn on headlights so you dont get voltage too high error.
AC |
#218 | |
Member#: 242246
RMIC
#219 |
Member#: 331408
whats your issue? i got my vagcom working with no issues after the voltage error.
AC |
#220 | |
Member#: 41762
International
Which chip do you have? If WCH, you were able to read/flash the ecu with it? |
#221 |
Member#: 331408
not completly sure which chip i have but this is the cable i ordered, im able to read/reflash and log, also works with learning view.
http://www.ebay.com/itm/170925617455...84.m1497.l2649 |
#222 | ||
Member#: 242246
RMIC
#223 |
Member#: 321715
Tri-State
Question, my FTDI cable from that website that z recommended, will it work directly out of box?
Boy is the shipping slow... Its just leaving Hong Kong today... I ordered it on the 23rd Last edited by jthatch12; 11-06-2012 at 09:23 AM. |
#224 | ||
Member#: 331064
Expect at least 3 weeks shipping. Quote:
#225 |
Member#: 290592
TXIC
Vehicle:2006 WRX Wagon 2004 WRX Wagon |
I just ordered this cable:
...with the intention of doing some logging. This cable is dirt cheap and like the others seems to be hit or miss with FTDI vs WCH chips. We shall see- i'll report back later this week. |
| Thread Tools | |
| Display Modes | |
| I Got VAG-COM cable and I need help!!!!! | subi-bartimioli02 | Open Source Reflashes | 147 | 06-23-2011 12:45 AM |
| WTB Service: Get my Vag Com cable to work | el dude | MAIC Private Classifieds | 3 | 10-04-2009 08:25 PM |
| Anyone in Phila. willing to share their Tactrix or vag-com cable? | eek1 | Tri-State Area Forum | 4 | 09-12-2009 04:32 PM |
| Cant get Vag-com cable to flash my 04 FXT | andy87t2 | Open Source Reflashes | 6 | 06-13-2009 12:35 AM |
| VAG-COM cable | btlegacy | Open Source Reflashes | 4 | 05-31-2009 07:10 PM |
