Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 10-24-2012, 04:06 PM   #201
jthatch12
Member#: 321715
03 Big 16G WRX
Originally Posted by z
I didn't have an issue logging at all with the wch cable. But that was all I was able to do. Did you change your baud rate to 4800 on that com port that it's using?
I did, could it be interference with the tatrix drivers?
Old 10-24-2012, 04:15 PM   #202
Guardian-X-
Member#: 331064
06 Impreza wrx sti
Originally Posted by z View Post
yep, flashed the updated map with no mods to the cable whatsoever.
*just have to connect the green connectors under the dash
The only change I made to the updated map was to set the initial IAM value to 1 so I didn't have to wait for it to relearn.
On ecuflash 1.32now. Are you able to read the rom without connecting the green connector? Can't read the ROM atm but i wonder if this is due to the ECUTEK tune because this is going to stop me at least somewhere or due to the green connector being unplugged. (06 STi btw) it's getting late so won't go back to the car and fiddle arround under the dash so i might aswell ask.
@jthatch: I had no issue with logging even when WOT with the wch cable ... (baud rate unchanged)
Guardian-X- is offline   Reply With Quote
Old 10-24-2012, 04:20 PM   #203
jthatch12
Member#: 321715
03 Big 16G WRX
Strange, I'll try changing the baud rate back. I've never had issues with a real tatrix cable, Just this. Everything works great until WOT, it just craps out. I'll figure it out hopefully
Old 10-24-2012, 04:42 PM   #204
z
Member#: 41762
04 STi
in ur Floriduh
Green connectors need to be connected to read the ROM and/or write to it.
Unconnected for logging and Learning View.
z is offline   Reply With Quote
Old 10-24-2012, 05:14 PM   #205
Guardian-X-
Member#: 331064
06 Impreza wrx sti
I see. I'll try it out tomorrow. Thx!
Old 10-25-2012, 12:54 PM   #206
Guardian-X-
Member#: 331064
06 Impreza wrx sti
Connected the green plug (i was like wtf with the fans kicking on/off constantly) didn't expect that
But no good couldn't read the ROM. Still no idea wether the software on the laptop is at fault or the ECUTEK tune ... i'm thinking it's the latter since i got pretty much everything to work like "Z" has but it won't read the ROM.
Looks like this is a far as it'l go ditching the tune is not something i'm eager on. I'd just like to able to completely shut off DTC's but i need to flash the rom to get that done. (for example for airpump delete)
But hey ... i'm happy with the romraider logger and learning view so far
Old 10-25-2012, 01:34 PM   #207
jthatch12
Member#: 321715
03 Big 16G WRX
I had this issue, you won't be able to read the rom with the ecutek tune :-(. A way to fix this is remove the ecutek tune by marrying and unmarrying an accessport to your car.
Old 10-25-2012, 04:13 PM   #208
z
Member#: 41762
04 STi
in ur Floriduh
^ yeah, i kind of glazed over the ecutek part...
http://forums.nasioc.com/forums/show....php?t=1027462
Old 10-25-2012, 06:27 PM   #209
Guardian-X-
Member#: 331064
06 Impreza wrx sti
Yeah i've read through it a couple of times. There's a similar thread (if not the same) on IWSTI where i posted some questions about it but no one could answer.
Even though i knew i was going in a dead end street with this i still wanted to try and learn as much as possible. Nonetheless i can now use learning view aswell which is great for me to see how much the engine knocks ... i was concerned after some logs where it knocked during 3rd and 4th gear WOT redline pulls (-4 degrees correction at 5-6k rpm) So far i only drove the car for about 50km's at not so fast speeds/high boost since the battery disconnect. IAM is back to 1 and showing no learned knock anywhere ... however i am afraid that it will show learned knock correction after i've really "given it the beans" ... not sure as to how i can adress this apart from seeing my tuner.
This was a 3rd gear pull from a few weeks ago where i first saw the knock
https://docs.google.com/spreadsheet/...0ajVBSkE#gid=0
check the 5-6k rpm range ... i highlighted the tables. You can also see my stock injectors are nearly maxed out when power is at it's max. From now on i'm keeping a close eye on things.
I really wish i didn't disconnect the battery last weekend ... the day after the cable dropped in the mail but my learned knock correction was all gone.
I'll upload the learning view pic in this post later (still on laptop)
I know it's going a bit offtopic therefore i'll keep my "knock" stories to this post only.
Old 10-26-2012, 10:00 AM   #210
jthatch12
Member#: 321715
03 Big 16G WRX
IAM of 1? Your car must be pulling a lot of timing!
Old 10-26-2012, 10:55 AM   #211
MykuL
Member#: 122451
01 RSTI w/07 EJ257
6MT Brembos BBSs Interior
Not sure if serious. IAM of 1 is the highest on 32 bit ecus, it's 16 on 16 bit ones.
MykuL is offline   Reply With Quote
Old 10-26-2012, 10:59 AM   #212
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Lmfao... 32 bit ecu's run a 0-1 IAM value.
16 bit ECU's run 1-16.
Old 10-26-2012, 11:11 AM   #213
jthatch12
Member#: 321715
03 Big 16G WRX
Lol okay, I didn't know that :-P. Learn something new everyday
Old 10-26-2012, 11:18 AM   #214
MykuL
Member#: 122451
01 RSTI w/07 EJ257
didn't know if you we're just trolling him haha
Old 10-26-2012, 11:25 AM   #215
jthatch12
Member#: 321715
03 Big 16G WRX
Nahh, my WRX is pulling some timing in the open loop(-2.11 tapering back ) so my IAM is 13 now. Haven't had a chance to see my brother in law to tune again. Long story short I saw his IAM was 1 and I was like! Dafuq. But now I know 32bits are different
Old 11-03-2012, 09:15 PM   #216
Viral E
Member#: 242246
2002 Impreza WRX
Just tried ecuflash 1.29a and no luck. Changing the baud rate to 4800 to get learning view to work also didn't work.
I'm going to have to do the voltage mod and see if it that makes any difference. But i'm having trouble finding a pic of my pcd with the mod on it.
This is my cable
I have this EXACT same chip. I know how to do the voltage mod (from the BFM cable thread) but I'm having trouble figuring out the K/L line mod that madjax posted. Does anyone know how I'd go about doing that? Here's a picture of the front and backs of mine if that helps any.
Front
Back
Viral E is offline   Reply With Quote
Old 11-05-2012, 03:41 PM   #217
04WRX_Boost
Member#: 331408
2005 WRX STi
You can actually just jump the flashblock with, standard 18G wire from autozone, jump pin 1-2,3-4, then just run a 12V to pin 1 and bam! it works great, currently flashing my 2004 WRX with this method. May need to turn on headlights so you dont get voltage too high error.
AC
04WRX_Boost is offline   Reply With Quote
Old 11-05-2012, 04:21 PM   #218
Viral E
Member#: 242246
2002 Impreza WRX
AC
I assume you are talking about the voltage mod, which is not my issue. Unless you weren't talking to me in which case... er... sorry
Old 11-05-2012, 04:25 PM   #219
04WRX_Boost
Member#: 331408
2005 WRX STi
whats your issue? i got my vagcom working with no issues after the voltage error.
AC
Old 11-05-2012, 04:34 PM   #220
z
Member#: 41762
04 STi
in ur Floriduh
AC
The issue is he has the one with the WCH chip and not the FTDI. (and he's wondering which lines to cut and which lines to jump to mod the circuit board. (in addition to the voltage mod on the obd2 pins)
Which chip do you have? If WCH, you were able to read/flash the ecu with it?
Old 11-05-2012, 04:52 PM   #221
04WRX_Boost
Member#: 331408
2005 WRX STi
not completly sure which chip i have but this is the cable i ordered, im able to read/reflash and log, also works with learning view.
http://www.ebay.com/itm/170925617455...84.m1497.l2649
Old 11-05-2012, 05:26 PM   #222
Viral E
Member#: 242246
2002 Impreza WRX
I honestly could not tell you which chip I have, but I can tell you it's not the same used by any others I've seen on this forum. My car is an 02 WRX, which if the stories are to be believed, are the ones that absolutely require the modifications to the circuit board AND the voltage modifications to the pins.
Not the same as mine. Also, you own an 04, which didn't have the timing/cable issues the 02-03's had. Or so I assume based on a LONG list of anecdotal evidence on this forum.
Old 11-05-2012, 06:46 PM   #223
jthatch12
Member#: 321715
03 Big 16G WRX
Question, my FTDI cable from that website that z recommended, will it work directly out of box?
Boy is the shipping slow... Its just leaving Hong Kong today... I ordered it on the 23rd
Old 11-06-2012, 12:45 PM   #224
Guardian-X-
Member#: 331064
06 Impreza wrx sti
Worked flawlessly for me right out the box (06sti). Haven't gotten to flashing but everything else works flawlessy (romraider,learning view etc) only reason i can't read my rom is due to the ecutek tune (lockout) on it so i presume you can do about anything with this cable without modification. I presume Z has already flashed with this cable without mods (have to check previous pages).
Expect at least 3 weeks shipping.
Can't help mate sorry ... i gave up on the WCH cable after the voltage mods and bought the FTDI one which has no problems straight out of the box. I don't really know if the WCH cable is of more use on the older ecu's or if the mod's actually make it work.
Old 11-12-2012, 02:45 PM   #225
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I just ordered this cable:
Amazon.com: OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409: Camera & PhotoAmazon.com: OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409: Camera & Photo
...with the intention of doing some logging. This cable is dirt cheap and like the others seems to be hit or miss with FTDI vs WCH chips. We shall see- i'll report back later this week.
mechatricity is offline   Reply With Quote
I Got VAG-COM cable and I need help!!!!! subi-bartimioli02 Open Source Reflashes 148 06-24-2015 09:36 PM
WTB Service: Get my Vag Com cable to work el dude MAIC Private Classifieds 3 10-04-2009 09:25 PM
Anyone in Phila. willing to share their Tactrix or vag-com cable? eek1 Tri-State Area Forum 4 09-12-2009 05:32 PM
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 01:35 AM
VAG-COM cable btlegacy Open Source Reflashes 4 05-31-2009 08:10 PM
