Old 10-19-2012, 08:44 AM   #1
Fusionf21
Member#: 335102
2008 wrx premium
grey
Default Correcting timing
Anyone have any advice on where to start? MY compression is good, leakdown is good except #4 has 10% cold. I gotta retry hot. Do you think a coil is faulty or just bad gas?
Fusionf21 is offline   Reply With Quote
Old 10-19-2012, 09:52 AM   #2
NoGraffix
Member#: 276209
I am Rub
Function>Form
what do you mean, "correcting timing" ?
NoGraffix is offline   Reply With Quote
Old 10-23-2012, 09:46 PM   #3
Fusionf21
Member#: 335102
2008 wrx premium
grey
i went to get a tune and he said my "timing was all over the map"
he said either bad gas or do a compression test
and its none of those than possibly weak coil
Old 10-23-2012, 11:14 PM   #4
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
who said this, what kind of car do you have, theres a ton of information you arent providing us. There's knowledgeable people bout cars here but were not psychics.
freddy121389 is offline   Reply With Quote
Old 10-24-2012, 01:50 AM   #5
BLUE STINGER2
Member#: 245434
Your tuner mentioned a bad tank of gas and compression test, so just base on that I'm guessing your ecu/car is not happy. I would venture on to say without getting to technical that your car is knocking enough to where your IAM/timing is dropping and you're tuner is trying to figure out the problem so he suggested a few things that maybe the culprit at hand so he can tune your car for power. I'm leaning towards a bad tank of gas because compression is not low and cylinder leakage test is somewhat decent for a cold motor.
Ron
BLUE STINGER2 is offline   Reply With Quote
Old 10-24-2012, 04:03 PM   #6
Fusionf21
Member#: 335102
2008 wrx premium
grey
I'm not looking for someone to pin point my problem. More looking for advise or if anyone has had this problem and can lead me in a direction to not loose more money. It may just be bad gas which I hope and I hope I get good gas for next time
08 wrx 67k miles
Perrin intake
Turbo xs bov
Borla muffler
Catless pipe
And I'm not sure if the car has other things on it.
Old 10-24-2012, 04:12 PM   #7
Tripintaz
Member#: 245218
2013 STI Limited
Could be bad gas, but it's certainly bad grammar.
