Old 10-25-2012, 12:31 AM   #1
DeM3n
Member#: 184692
2004 STI
Default Car won't start. Zero compression.
So on my lunch today my car died on me while driving. Popped the hood and saw the bottom a/c pulley shredded. Belt completely gone and the pulley itself gouged into the timing belt cover.
Took it to a local indy shop. Called me a bit again and said timing marks looked good. Replaced broken parts and car wouldn't start.
He saw crank sensor was the issue and replaced it. Still nothing. Did a compression test on the intake side and it read zero. He thought it might be his instrument but after trying it with a new one same results.
He says that he's gonna have to take the head off and check the valves. Any ideas?
DeM3n is offline   Reply With Quote
Old 10-25-2012, 12:46 AM   #2
ooooohhhhhh...that sounds like bad juju to me
if there is no compression on one side.....the 'timing marks' shouldnt look good
there is a deeper issue here
Old 10-25-2012, 12:53 AM   #3
rocketperson7
Member#: 283968
MBP
hole in piston?
Old 10-25-2012, 02:18 AM   #4
DeM3n
Member#: 184692
2004 STI
That's the strange thing. Guy says the timing marks matched up and that's why he put it back together the first time.
After trying to start it.... Nothing. With all the work entailed in the upper rebuild he estimates $1500!
Old 10-25-2012, 09:46 AM   #5
Tripintaz
Member#: 245218
2013 STI Limited
No compression means the valves could be open during the compression stroke(assuming you didnt put a hole in all 4 pistons which seems unlikely).
If the timing belt was not installed correctly that could cause the issue. Maybe he forgot he has to make sure the cams and crank are lined up properly before installing the belt?
Old 10-25-2012, 09:56 AM   #6
MRGierut013
Member#: 328260
2005 STi, 2004 RSX
i-Vtec just kicked in yo!
It sounds like he attempted to perform a cylinder leak-down test...on the intake side?
MRGierut013 is offline   Reply With Quote
Old 10-25-2012, 10:01 AM   #7
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
Is he using the correct timing mark on the crank pulley? It's not the arrow, it's the line on the backside of the pulley. The arrow should be pointing towards the 3 oclock position roughly.
berge56 is offline   Reply With Quote
Old 10-25-2012, 12:40 PM   #8
DeM3n
Member#: 184692
2004 STI
I'm going to talk to him here in just a bit and mention some of these things to him. Thanks for the input. I'll post back with more info later today.
Edit: just got off the phone with him. So I was mistaken ij thinking he said he retimed it. He says he didn't since all timing marks were still on.
No leak down test, just compression test. He thinks all the valves are bent. The crank pulley had the a/c belt wrapped completely around it. Says it took him much longer than it should have to take it off.
