#1426 |
Member#: 323090
NWIC
Vehicle:2012 Impreza Sport Obsidian Black Pearl |
Looking for some second "educated" thoughts here on tire sizes. Im looking to get some winter tires on my 17" stock wheels and would like to size up a bit. The stock tires on '12 impreza sport premium are 205/50R17. I want to get a hint more height for the winter so I was thinking upwards of 215/55R17 or 215/60R17. I hit a lot of snow in the winter so even an inch or two extra clearance would make a world of difference.
I am aware there are wheel/tire threads and I looked through many. looked online at many posts and wheel comparisons. I also used this site to kinda help see the differences ( http://www.rimsntires.com/specs.jsp ) but it isnt telling me what I need to know. Anyone have experience with diff tire sizes on same wheels? I need to know if the tires will rub the wheel-well when i turn, corner, car is loaded with 5 passengers, just normal use i guess..any input is appreciated! ![]()
#1427 |
Member#: 315631
Vehicle:2012 Impreza |
yes there will be rubbing especially with the 215/60. 215/55 is pushing it, you could but i could see it rubbing if you were to hit a bump and were turning at full lock at the same time. you could just buy strut spacers. then you could run a taller tire and increase ground clearance.
#1428 |
Member#: 320291
Vehicle:2012 Impreza Sedan White |
#1429 | |
Member#: 314973
BAIC
Vehicle:2012 Impreza Sport Satin White |
#1430 | |
Member#: 330797
Vehicle:2012 Impreza 5dr Prm Satin White Pearl |
ROTFL |
#1431 |
Member#: 317244
Vehicle:12 Impreza White |
In changing my panel filter I came across what looked like a second filter that was facing into the air intake. It is held in place by 4 small rubber grommets and 2 plastic rivets. It appears to come off if you remove the rivets. Has anyone else removed this part. I don't plan to just curious as to what other people have done when replacing their filter.
![]() Uploaded with ImageShack.us |
#1432 | |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
#1433 |
Member#: 313093
VIC
#1434 | |
Member#: 315631
http://www.subarupartsamerica.com/pa...iagram=7595200 i dont see that part here. EDIT: there does seem to be two parts for "1" california and federal |
#1435 | |
Member#: 317244
#1436 |
Member#: 313093
VIC
So what happens when you remove it for your PZEV? It would improve airflow but will it throw a CEL?
#1437 | |
Member#: 299286
NESIC
Vehicle:2012 Sport 5MT Green/Silver |
Since it is white it should indicate if the Perrin is filtering! When you go to the dealer see if you can get the part number and price because I may change it occasionally. I just looked and that second panel is not in my eBay Subaru Service Manual (PDF). Last edited by Zeeper; 10-26-2012 at 07:34 AM. |
#1438 |
Member#: 73068
Vehicle:2008 STI Boost Wagon 2012 Impreza Limited ISM |
Does the filter touch the secondary filter? If so, then any oil-type drop in filter will probably transfer oil onto it?
#1439 |
Member#: 299286
NESIC
didn't happen to mine.
#1440 |
Member#: 334126
Tri-State
Vehicle:2013 5mt Sp Premium Venetian Red & Dark Gray |
#1441 |
Member#: 326540
BAIC
Vehicle:2012 Impreza MT SP DGM |
#1442 | |
Member#: 308742
Vehicle:2012 Impreza Sport Marine Blue Pearl |
#1443 |
Member#: 302570
Vehicle:2012 Impreza Ice Silver Oil Burner |
I was wondering what people were talking about!
#1444 | |
Member#: 315759
Vehicle:2012 Impreza 5 Door Obsidian Black Pearl |
#1445 | |
Member#: 196009
Vehicle:2012 Impreza Ltd 5DR White |
#1446 |
Member#: 136157
TXIC
Vehicle:2011 WRX SWP |
So what happened to the foot lights? I miss those from my 2011 wrx and forester.
#1447 |
Member#: 313093
VIC
I haven't had a chance to install it yet, been quite busy with work and also sound deadener installs best when its warm, which means I would have to warm my garage up prior to installation (which is kind of a pain). I've read that installing sound deadener (one layer) will reduce road noise by 3-7 decibels.
#1448 |
Member#: 318978
Has there been any Subaru Impreza aftermarket parts websites?
#1449 | |
Member#: 257754
NWIC
Vehicle:2012 Impreza Sport P Camilla Red Pearl |
#1450 |
Member#: 315643
South East
Vehicle:2012 Impreza Sedan DGM 5mt |
| Thread Tools | |
| Display Modes | |
| factory SS or aftermarket for 2012??? | Myth21 | Transmission (AT/MT) & Driveline | 8 | 01-07-2012 11:18 AM |
| Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? | somebody else | Southern California Impreza Club Forum -- SCIC | 1 | 12-29-2011 11:31 PM |
| Has anyone test drive a 2012 Impreza yet? | pRiMe DiReCtIvE | General Community | 25 | 11-28-2011 10:03 PM |
| Hybrid Impreza in the works for 2012? | rsholland | News & Rumors | 43 | 03-12-2010 10:58 PM |
