Old 10-26-2012, 12:30 PM   #1
Blownwagswag
Member#: 302044
2007 Frankstein
multi
Default Differential question WRX MT
I'm currently running 215/50/17's all around with same brand/model tires, my front tires needs to be replaced. I'm thinking about replacing them with 225/45/17, I will eventually replace the rears with the same size soon but since I'm a bit low on money since I've already dropped a lot of money on the car this month I can only get the other 2 in about 2 weeks. do you guys think it might create a conflict with the differential running different size tires like I mentioned above.
Blownwagswag is offline   Reply With Quote
Old 10-26-2012, 01:07 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Read you owners manual, there is a maximum tire size difference you need to obey. If you tires are very worn I'd bet you are beyond the limit. Just wait the two weeks if you can and put all four tires on at the same time.
Old 10-26-2012, 01:08 PM   #3
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Just wait the 2weeks and get all 4. Or wait and install all 4 at once. Don't forget to rotate new ones at specified intervals.
Old 10-26-2012, 01:10 PM   #4
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
225/xx will fit oem 16" wheels I'm sure he can fit up to 245
Old 10-26-2012, 01:26 PM   #5
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I wasn't talking about what size tire would fit on what size rim. There is a max tire circumference difference that must be observed if your not changing all 4 tires at the same time. If you don't your diffs will hate you and possibly go on strike.
Old 10-26-2012, 01:28 PM   #6
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
As these guys have said, don't risk it. The tread wear tolerance for replacement is 2/32" (IIRC). Wait until you have the money for all 4.
kellygnsd was making reference to the wear tolerance, not the fitment of the tires. That said though, I'd recommend not using 245's on an 8" rim.
MT_WRX is offline   Reply With Quote
Old 10-26-2012, 05:57 PM   #7
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
I was simply stating it can be done
Old 10-26-2012, 06:43 PM   #8
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Not a good idea to mix and match different tire sizes. Just wait 2 weeks and get all 4x.
Old 11-14-2012, 06:37 PM   #9
PSBeachBum
Member#: 279870
2005 WRX Wagon
Hey ill admit I am running mismatched for about a year now. No problems.......yet.
PSBeachBum is offline   Reply With Quote
Old 11-15-2012, 09:05 PM   #10
some dude
Member#: 100300
06 WRX
What sizes are you running? More detail please.
