Old 10-26-2012, 02:28 PM   #1
RussSTI
Member#: 334177
2007 STI
Default Installing Cobb Catback
So i should be recieving my catback exhaust today,
Ive done them before on hondas and i would assume it shouldnt be no different but i wanted to ask you
the level of difficulty was on installing a catback system was on my 07 sti.
Also, would i have to unbolt the axle back first? or can i just take the whole catback off in one piece.
thanks
RussSTI is offline   Reply With Quote
Old 10-26-2012, 03:40 PM   #2
tgtrefz
Member#: 255232
2011 WRX Sedan Ltd
Spark Silver Metallic
Difficulty: 0-2. Get a can of PB Blaster and soak those bolts. No need to undo the axel back.
tgtrefz is offline   Reply With Quote
Old 10-26-2012, 03:42 PM   #3
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Don't forget a few brewskiis too
Old 10-26-2012, 03:47 PM   #4
GrumpyPitbull
Member#: 313311
thanks
Same process as the honda .. easy job.
I personally like to disconnect the axleback from the midpipe .. I find it makes getting the exhaust off the hangers easier.
Old 10-26-2012, 04:26 PM   #5
leecea
Member#: 37359
Does the 07 STi have the spring loaded bolts and donut gasket? My bolts broke and the gasket was pretty bad, but my car's older. Copper RTV can help seal a bad donut gasket.
leecea is offline   Reply With Quote
Old 10-26-2012, 06:30 PM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Disconnect bolts, remove pipe, add pipe, replace bolts. Google was hard.
Old 10-26-2012, 06:48 PM   #7
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
I took my stock exhaust off as one peice. Keep in mind, I had a quad tip, if my hand wasnt on my chest, damn thing could've killed me lmao. ( It fell >_> )
I find it easier to put everything on as one peice u less it's too heavy. Should be easy as a moooofugguh on a single outlet car like yours.
Its all preference. Have some WD-40 or so for those annoying hangers and bolts.
Navendra94 is offline   Reply With Quote
Old 10-26-2012, 07:47 PM   #8
RussSTI
Member#: 334177
2007 STI
sounds easy enough, working on it tonight right after work =)
Old 10-27-2012, 07:32 AM   #9
the_truth
Member#: 332140
Chapter/Region: HIIC
2013 WRX
Were you able to get the mid pipe to align perfectly with the down pipe? The reason I ask is because I just installed my Cobb CBE yesterday and the mid pipe did not want to perfectly line up with the down pipe. The angle is not that bad and it did create a good seal against the doughnut gasket but it doesn't look right. I took it to my local exhaust shop for them take a look at it and they said it looks good. It is really bugging the crap out of me knowing that it doesn't line up perfectly but it's not leaking so I guess it's good.
the_truth is offline   Reply With Quote
Old 10-27-2012, 12:08 PM   #10
RussSTI
Member#: 334177
2007 STI
yeah everything was a breeze and lined up fine. maybe you can post up a photo and i can compare it.
