Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 09-25-2012, 11:02 PM   #676
GEE-OTTO
Member#: 201277
2009 Legacy GT
Originally Posted by Moore Performance View Post
any other suggestions on n/a designs before we go into production?
We value your opinion on this!
Are you going forward with a design that only bolts to your CBE or mid-pipe ? If so
GEE-OTTO is offline   Reply With Quote
Old 09-26-2012, 04:55 PM   #677
Moore Performance
Member#: 231489
Originally Posted by spyrule View Post
Nope... FFS START MANUFACTURING ALREADY!
hahahaha. Noted! We just want to produce the right part for the community, and one that works! We take pride in r&d, so it's sometimes tough for us to sign off on projects like this
Originally Posted by Counterfit View Post
So I take it the EL version is a no-go at this point?
No, simply because the current design is *very* easy to make equal length. it will mean a change in the CNC bending data, but that's no biggie. The problem is that batches of tubing bends will have to be different for each header, thereby making it a little harder for us to pass the savings onto the customer.
No. Honestly, this is one of the main internal debates of this project. Half of us want a true bolt-on, while others deplore what the header has to do to bolt to a sideways mid-pipe flange. Suggestions are welcomed
Moore Performance is offline   Reply With Quote
Old 09-26-2012, 09:51 PM   #678
subi400
Member#: 216984
1996 Impreza outback
Green
I think that the collector design going straight back is a better design compared to the sideways collector and flange that bolts to the stock location cat section. The reason is the less bends the better for exhaust gases which leads to faster velocity given the right diameter piping is used for the application.
However, like some people on here have pointed out, if this header is used with the straight back collector then the cat section either has to be made up or get the header and cat section together from Moore Performance. On the other hand, getting the whole combo would still be nice because these two pieces of the exhaust will be worth it because of the craftsmanship that goes into each header and cat section.
If I remember reading right, any catback will be able to bolt up like a 2.25 or 2.5" and then a 3" if so desired with an adapter.
If I build the engine I am thinking then I would definitely like to buy one of these headers and most likely the cat section as well. It won't be for higher end power just low and mid so it would be perfect
subi400 is online now   Reply With Quote
Old 09-27-2012, 05:36 PM   #679
Moore Performance
Member#: 231489
some well thought-out feedback there. Thanks!
What if we were able to drop the price of the header/midpipe/cat combo to something close to the better headers on the market? Yes, the header won't just "bolt up" to a stock cat section, but as mentioned, the flow will be vastly improved.
other pluses:
- no heat shield rattles from the mid pipe section
- no wafer thin/rusty donut gasket flanges.
- high-flow vs. low-flow cat
- stock cat section can be sold for its platinum to recoup some $
Old 09-27-2012, 06:57 PM   #680
klaus_b2
Member#: 318411
so how much are these gonna go for?
klaus_b2 is offline   Reply With Quote
Old 09-27-2012, 07:10 PM   #681
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
I know you are currently working out the final design and pricing for the 2.5 motor and I hope eventually the design will lead to a FB20 variant. As long as it doesn't trip CEL codes and is quality I don't mind paying a little more...
uspopo is offline   Reply With Quote
Old 10-02-2012, 05:11 PM   #682
Moore Performance
Member#: 231489
We havent decided on a price, but we're leaning toward doing the header and the mid-pipe as a package that will be competitive with buying say, a Borla and an aftermarket mid-pipe with high-flow cat. We're leaning toward offering it as a package only, as both will work with one another.
I'm sure we will. We're doing a one-off exhaust on an FB this week, so we'll have some solid inspiration!
Old 10-02-2012, 05:39 PM   #683
uspopo
Member#: 317014
ISM
Sweet..ftw!
Old 10-02-2012, 06:59 PM   #684
GEE-OTTO
Member#: 201277
2009 Legacy GT
other pluses:
Oh yeah I like that direction: broad swath!!!! With the combo header/mid-piep bolt to the stock axleback section ??
Old 10-03-2012, 04:51 PM   #685
Moore Performance
Member#: 231489
yes!
Making it bolt to a stock axle back makes sense for those wanting to keep things a bit more stealthy - it's just really hard justifying making the header bolt up to a factory mid-pipe due to its quirky design.
Old 10-04-2012, 12:11 AM   #686
GEE-OTTO
Member#: 201277
2009 Legacy GT
yes!
Oh yeah that near 90 degree connection is perpendicular to the path of exhaust flow, not so good for efficiency. Well we all look forward to your design rollout.
Old 10-04-2012, 09:38 PM   #687
Moore Performance
Member#: 231489
thanks! we shall do our best for y'all!
Old 10-20-2012, 10:30 PM   #688
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Agreed with uspopo. Would be great to see something for the FB motors. Through reading the forums, there is a want for it.
gregorz4 is online now   Reply With Quote
Old 10-22-2012, 05:43 PM   #689
Moore Performance
Member#: 231489
There's a pretty good header on there to begin with. I'm not ruling it out, but it's not first on the list. We are however doing a group buy on FB exhausts for Imprezas here in a few short weeks.
Old 10-22-2012, 06:22 PM   #690
alexinvancouver
Member#: 251482
2000 2.5RS,
2014 2.0i, 1990 all-trac
installed brullen headers with their hi-flow cat
much much better performance compared to what was before
they claim 21hp increase and probably that's what it is
alexinvancouver is offline   Reply With Quote
Old 10-22-2012, 09:30 PM   #691
Moore Performance
Member#: 231489
high-flow cat might be the key to that combination.
21 HP sounds like a lot though. Are there any dyno plots?
Old 10-27-2012, 11:35 AM   #692
BlobEyeRS
Member#: 336270
2011 Wrx limited
Bump for this -
If I have to I'll drive straight to your shop. As of right now I have the stupid p0420 code and rear flange on my cat is slowing rusting away (awesome exhaust leak). Very interested in 304 header and cat section that gets rid of that stupid donut gasket.
Any option for a wideband o2 bung? I have a AEM UEGO laying around from an old project that never got used I'd like to put to use.
Only 2hrs away from your shop and 40 from the fab place.
BlobEyeRS is offline   Reply With Quote
Old 10-27-2012, 03:30 PM   #693
Moore Performance
Member#: 231489
Originally Posted by BlobEyeRS View Post
Bump for this -
Cuyahoga isn't far at all! Quaker City was where Moore Performance was inadvertently born (long story worth discussing over beers lol).
Give us a ring to discuss some options!
Moore Performance
(412) 951-6493
Old 10-27-2012, 04:20 PM   #694
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Did someone forget to wear a condom?
Counterfit is online now   Reply With Quote
Old 10-27-2012, 05:19 PM   #695
BlobEyeRS
Member#: 336270
2011 Wrx limited
Moore Performance
(412) 951-6493
Will do in the next week or so.
Quaker City...I haven't been there in years...
Old 11-02-2012, 08:57 PM   #696
joltdudeuc
Member#: 6119
1999 GM6
RBP
I'm swapping, so I'm no longer a potential customer, however here is something to compare to (OBX EL):
My 1999 (MAF) RS had intake, catback and was catless. This is fairly low reading mustangs dyno (GST Motorsports).
If your header can produce power like that, it's definitely going to be a good header. But do note that the OBX header can be had for about $300 shipped. So if your design is truly superior, I think it would have to produce the best dyno results of any NA header out there. Can't wait to see the finished project!
joltdudeuc is offline   Reply With Quote
Old 11-04-2012, 03:13 PM   #697
Moore Performance
Member#: 231489
Oh man. I guess that should have been worded a bit more delicately. hahahaha
Great. And yeah it was bought out, but it was a pretty great place to drag race for years.
Great info. Thanks for sharing! And you're right on point with what you said about power vs. dollar spent. This is one of the reasons why we decided to look into a more price-competitive bolt-on option. it's tough to compete with the price, so the power (and the reliability/liftetime warranty) will have to be the key!
Old 02-01-2013, 06:44 PM   #698
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
any updates?
doubledribble is offline   Reply With Quote
Old 02-02-2013, 03:01 PM   #699
Moore Performance
Member#: 231489
Originally Posted by doubledribble View Post
any updates?
No solid updates at this time unfortunately. We had to ramp up production on some transmission and turbo components, which has left us short-staffed for the n/a project. It's in the queue so it will happen - just not as quickly as we had hoped
Old 07-13-2014, 07:10 PM   #700
Richard A.
Member#: 79
1999 2.5 RS
RBP
I'm mainly looking for a reasonably priced High Flow Cat pipe to go with my TWE headers and 2.25 inch mid pipe but could use a good axle back as well. I'm wondering if you have or can make a metallic HFC pipe and or axle back and where your header project has ended up? I have a 99 RS.
By the way, ST class rules have changed since this thread was started and the cat location has been freed up as well as some of the issues associated with the dreaded CEL.
Richard A. is offline   Reply With Quote
Moore Performance Axleback for 93-05 impreza.....feedback wanted! Moore Performance Normally Aspirated Powertrain 181 03-21-2011 11:11 AM
Moore Performance 08+ wrx/sti divorced wastegate DP ready for production! Moore Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-25-2010 10:57 PM
Moore Performance 08+ sti downpipe/catback.....what do you want?? Moore Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-26-2009 07:30 PM
Moore Performance Divorced Wastegate Downpipe and Catback Exhaust Group Buy!! Spun Autosports Vendor 'Group Buy' Classifieds 27 12-03-2009 08:48 PM
