Old 10-14-2012, 10:30 PM   #26
TheColorCute
Member#: 265589
2004 Slow 6466 STi
Originally Posted by Junior2JZ View Post
I already offered him my new ppg 6spd, now all we need are tires.
I'll take your PPG for my 6466 build if Adrian doesn't
Originally Posted by xdrian View Post
The missile has a 6262 iirc. I was just as surprised with the numbers that the car put down. I cant wait to see what we can do on E
Crazy numbers. Especially at 20psi! On 93 too!
TheColorCute is offline   Reply With Quote
Old 10-14-2012, 11:20 PM   #27
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Originally Posted by Zee Biker View Post
Why is this making the same power on 93 that the missile did on E?
So happy we finally have a car coming up with Evo-like numbers.
26psi on a turbo that can make 900+whp vs 30s on a turbo that will max around 700-750.. Also missile made over 670
This car is not making 600+ on 20psi
it creeps to 26psi
Either way it makes it so easy... e85 @ 30psi and I wont be shocked to see 750whp... Then we go to 40psi
Old 10-15-2012, 02:28 AM   #28
TheColorCute
Member#: 265589
2004 Slow 6466 STi
it creeps to 26psi
Ahhh, that makes more sense. 20psi seemed a little too good to be true for 630whp on a 4 cyl.
Old 10-15-2012, 05:12 PM   #29
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
it creeps to 26psi
your a ****ing animal bro. lol i can't wait for you know what why can't summer start next week
Old 10-15-2012, 06:34 PM   #30
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
ordered new wastegate today, should have it done and welded in by this weekend.
xdrian is offline   Reply With Quote
Old 10-15-2012, 07:36 PM   #31
Big_DeWeY
Member#: 37078
95 L
Blue-ish
In for the carnage. Warp speed ahead!
Big_DeWeY is offline   Reply With Quote
Old 10-16-2012, 11:52 PM   #32
AkumaMotorsports
Member#: 214570
Got to get the OP to change the boost to 26+ PSI. My applause for posting the real boost in bold. 20 PSI to achieve 600WHP is not mathematically possible with the displacement of this motor, turbo size, and airflow. How do you like the AEM V1 on the Subies? To be honest, I have not liked them at all. The AVCS(not needed here) control is not very good. Have you tried the VIPEC at all? I have heard good things there.
The OP stated he wanted to change the wastegate to hold boost better. I think he needs a different gate to control boost better. Sounds like it is creeping due to gate size or design.
Do you think is it the size of the gate or is the design favoring the turbo? Sometimes the gate positioning can lead to creep. If you are able to split the flow as equally as possible on the up-pipe you can get a little better response from the smaller gates.
Is this going to be a drag only car or is it going to see some street driving?
Keep up the good work, and enjoy the car. I hope the OP has some experience with high HP cars that come in late. This will be a bit to handle for an inexperienced driver. It will def. light up the tires in the early gears.
Cheers.
john
AkumaMotorsports is offline   Reply With Quote
Old 10-17-2012, 12:09 AM   #33
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
^^^john where have you been during xdrian's whole build---I thought you were familiar with him since you are kinda in the same area---this IS xdrians personal car and he and Jr. know waaayyy more than you do in this kind of build so quit being so critical on his build.Believe me Xdrian definitely knows how to drive high hp suby's and Jr is the tuning whiz when it comes to a drag set-up.
john 1badSTI is offline   Reply With Quote
Old 10-17-2012, 08:12 AM   #34
AkumaMotorsports
Member#: 214570
Actually, I am not sure if I know Xdrian. I may, I just did not know his username vs real name.
I suggested the OP be careful because we just has a massive tragedy here in the NY area. 4 teens were killed in an STI. I was actually looking out for Junior, since I did not know who the OP was. So, maybe you should think before swinging in to protect someone.
I assure you, my knowledge base is far more extensive than you have any idea. Junior will back that up, as I helped him out very early in the Subaru game when I was in Utah. He and I are on good terms and he does not need anyone trying to protect him.... there was no attack. Your ignorant statements were necessary and off base.
I was not being critical at all. I was not even bashing anyone. I was pointing out junior did the right thing correcting the boost numbers. I then asked about the design of the gate and what he thought the cause of the creep was. Nothing more nothing less.
The reason we have posts like this is to discuss the build, and that is what I was doing.
John
Old 10-17-2012, 08:40 AM   #35
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Graphs of creeping cars wig me out; they look like NA plots!
GIVE IT MORE PLATEAU!
Old 10-17-2012, 09:40 AM   #36
xdrian
Member#: 104200
828 WHP BUGEYE
Cheers.
john
I had a 38mm on here, The header design was a 4-2-1 so it has a 1.5 scroll up-pipe with the gate right at the top. The 38 is way too small for this setup, so we are replacing it with a 44mm.
I have some experience driving high HP cars, and I drive this car almost on a daily basis. Took it to school yesterday, and a spirited cruise around town. Im no newbie nor am I a reckless teen. This little 600hp car doesnt scare me. When this car makes 800 then ill need a diaper to drive it.
Old 10-17-2012, 01:37 PM   #37
xdrian
Member#: 104200
828 WHP BUGEYE
And the V1 is mint with this car, starts right up and runs the car well. We arent using avcs in the car at all, I would have to run a jdm harness or run wires for the avcs but its not necessary with my build.
Old 10-19-2012, 11:20 PM   #38
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Nice work xdrian Jr. Thanks for inviting me dicks! LOL I have my nitto dr's on stock bbs if you want I'll come to tt and will all cruise to the track. lmk
spoolinsti05 is offline   Reply With Quote
Old 10-20-2012, 03:55 AM   #39
wuuusaa
Member#: 92894
2015 Wrx
I've been following the build on facebook for a while, glad to hear it running and making some good power man.
wuuusaa is offline   Reply With Quote
Old 10-20-2012, 09:50 AM   #40
xdrian
Member#: 104200
828 WHP BUGEYE
might wanna some. ill let you know!
thank you!!
I took the car out yesterday with the 44mm wastegate on it. Turned out i had a small pre turbo exhaust leak which is now fixed, car feels like a completely different animal I kinda pooped myself when the wheels broke loose easing on the gas in 2nd
Old 10-20-2012, 10:05 PM   #41
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
car is dope. congrats!!!
take a step back for a moment and absorb its awesome-ness. i was so glad to have my car back that it took me a while to realize how far my car has come. as my car gets faster i think i have lost perspective, i admire akuma john for looking out.
wakes up the neighbors? oh wait...it wakes up the dead im sure. in car go-pro!!!
10 gallon fuel cell...cant go very far can you?
Old 10-21-2012, 12:07 AM   #42
AkumaMotorsports
Member#: 214570
The orientation of the gate in relation to the turbo is what I was referring to. It should look like a 'Y', where the two legs of the Y represent the turbo and gate, so they get equal flow. It sounds like you have that under control. Did you consider going twin scroll? It might be pretty easy to convert the Up Pipe and then you could do twin 38MM MVS, and go with a twin scroll turbine housing. That might be a pretty cool project. Just a thought though.
I knew you would not use the AVCS on the AEM V1, so I assume it works well for your application.
I see that you got the 44mm on there. Did it alleviate the creep?
What are you shooting for with this project? Low 10s...maybe 9s'? That would be pretty nice. Either way it looks like it is fun to drive.
Once you get it sorted out, why don't you and Junior bring the car to Akuma. We can do a few dyno pulls to compare the numbers...Mustang V DJ. Obviously, there will be no charge. I could then figure out what correction factor I should set the dyno at to get it reading more in line with the rest of the community. Just a thought.
Regards,
John
Old 10-21-2012, 01:26 PM   #43
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
How high will this thing rev when it's all said and done?
Old 10-21-2012, 01:29 PM   #44
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Love this car, who assembled the motor?
I know at one point you had a treadstone intercooler core, did you max it out or why did you change it?
C J is offline   Reply With Quote
Old 10-21-2012, 01:31 PM   #45
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
8500-8800 will be the safe limit.
Roman(NightShift Performance) assembled the block, Headgames assembled the heads and I believe Adrian/Vince put the longblock together.
Nightshift Performance baby!
Old 10-21-2012, 01:35 PM   #46
C J
Member#: 132587
2006 JrTuned STi
[email protected]
If you can't tell I am going to start putting a motor together for next year ha.
Old 10-21-2012, 02:23 PM   #47
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
No need for Dyno comparisons as this car will hit the strip and the power numbers will be obvious. Cars with this kind of power should not be on a dyno long. Not good for car/dyno or neighbors!
02WRX2.5 is offline   Reply With Quote
Old 10-22-2012, 11:53 AM   #48
xdrian
Member#: 104200
828 WHP BUGEYE
Regards,
John
I think the creep was alleviated since we put the new gate on the car. Gonna put the car back on the dyno to retune for pump again then put some e85 on turn it up a bit more.
If this car doesn't go 9's ill burn it, lol.
Still have the treadstone core. I doubt this car will max it out.
We can figure something out. I'll gladly bring the car by and do a pull or two. But track numbers first !
Old 10-28-2012, 07:32 AM   #49
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Regards,
John
What's wrong with the AVCS on the V1? the control is unstable or just limited?
Also I don't know for sure but wouldn't single scroll be the best option for a drag car at this displacement/turbo size. What a/r is you back housing 1.06? Not sure you could obtain a twin scroll housing for the 67mm that will flow as well around the turbine and out the down pipe. Not that this car has much of an exhaust system
Any update on the beast yet man? I'm like a little kid waiting for candy at someones door step lol.
Old 10-28-2012, 07:38 AM   #50
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
opps double post
