Welcome to the North American Subaru Impreza Owners Club Saturday October 25, 2014
Old 10-02-2012, 02:32 PM   #1
cconwing
Member#: 333519
Default EJ22 Replacement
ok so I've searched and read all around and haven't really been able to find anything...maybe I'm not good at searching or maybe there's not much support for the ej22 I don't know but here's my question:
I have a 98/99 Impreza Outback Sport with an EJ22 in it. Recently I spun a bearing and I've read that its more cost effective to just replace the engine rather than doing the bearing (which personally I'd rather do anyways). So I'm in the market for a new engine but don't know what will fit in my car.
Now I know there are phase I and phase II engines and they switch over between 98 and 99...so there in lies the problem. I'm not 100% sure which mine is. My title says its a 99 but the badge on the door jam says 98. Which should I go by? Theres a couple of engines on eBay that say "6th digit 4" in the title which I'm guessing is for the VIN number...which my VIN also has 4 for the 6th digit. Is that enough to go off of, or is there another determining factor?
Also, I was just curious on how difficult the replacement would be? I've done swaps in the past but never worked on my Outback like this. I've seen the write up on the removal but not too sure about the whole process...I would think its straightforward but with cars you never know. I'm also going to have to replace the clutch and flywheel while I'm in there.
Any advice, suggestions, opinions or anything you want to provide or even yell at me or whatever would be appreciated haha. I'm totally lost as of right now and have to try to get this done within a few weeks.
cconwing is offline   Reply With Quote
Old 10-05-2012, 04:11 PM   #2
cconwing
Member#: 333519
Bump please guys any help would be greatly appreciated.
Old 10-06-2012, 01:26 AM   #3
subi400
Member#: 216984
1996 Impreza outback
Green
Does your engine have the valve covers of the ej18? Or the valve covers from the 99 2.5 rs ej251?
Old 10-07-2012, 02:08 PM   #4
cconwing
Member#: 333519
I'm not sure...how do I tell? I just thought it was an ej22 I had no idea about the valve covers being different...let me know and ill check as soon as I get home
Old 10-07-2012, 03:06 PM   #5
KennyKaozII
Member#: 333257
I also have a 1999 obs with the ej22. And i wanted to know the removal bc i want a wrx swap
KennyKaozII is offline   Reply With Quote
Old 10-11-2012, 01:14 AM   #6
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
What month is the door jamb sticker showing in addition to the year?
bangedlegacywagon97 is offline   Reply With Quote
Old 10-11-2012, 12:50 PM   #7
cconwing
Member#: 333519
Old 10-11-2012, 10:54 PM   #8
dead
Member#: 334848
i have not posted my pictures but i just tackled this.. sorta.
i had to remove the engine to get to the oil/separator plate (yes thats what its called!)
i acquired a means to lift the motor
watched http://www.youtube.com/user/briansmobile1?feature=watch
his video channel is informative and he answers all my questions accurately
went at it. took me all weekend and a little bit more. buy rubber gloves!
two jacks helped
ps. im 23 and have been working on cars since i was 20. did it all with dads tools.
may i also recommend craigslist.. but careful dont get mugged.
you have a 22E (i think) look on block between alternator and steering pump. they have slightly better performance due to piston coating (less friction) but they are the same. plug and play.
dead is offline   Reply With Quote
Old 10-12-2012, 05:05 PM   #9
cconwing
Member#: 333519
Sounds good. I've done swaps before so I have all the necessary tools. Should be straightforward I think, its just about getting out there in the cold :/
So I'm looking at an 97 automatic impreza outback sport, would the engine out of that work with my 09/98 (door jam month and year) standard impreza outback sport. I don't think the transmissions matter right? Should still bolt up if I'm not mistaken...just making sure the phase 1 to phase 2 thing is all good?
Any ideas would be extremely helpful since I'm supposed to go pick it up Tuesday
Thanks for the help so far!
PS if I do end up doing it I'll try my best to put together a write up.
Old 10-14-2012, 04:24 PM   #10
cconwing
Member#: 333519
Anyone with some definitive thoughts on this?
Old 10-19-2012, 03:52 PM   #11
cconwing
Member#: 333519
Ok well I didn't pick up the other impreza since the person never came through. But there's another engine for sale with transmission for 500 obo. I'm interested in getting it however once again its a phase 1 from a 94-95 impreza and I'm still unsure if it would work with my 98/99 obs...
Any ideas? I'm just looking for a sure answer before I invest the time and money :/
Old 10-25-2012, 04:27 PM   #12
dead
Member#: 334848
theres gota be info on here somewhere. the difference that i can think of is one is non interference and the other isnt. this is a mechanical difference that shouldnt make a difference in plug and play
Old 10-25-2012, 04:39 PM   #13
avionator
Member#: 210482
FWIW i just swapped my busted EJ253 in my manual trans car with one from an auto trans. I've no idea about the older phase one phase two stuff, but i can say that it was simple as beans to swap a clutch onto the auto engine. Also, there were some other minor differences, you can always read my thread about it (it's in this sub-forum).
my only concern for you would be that the engine plays well with the ECU. I think a dealer should be able to answer that question.
this was my first ever engine pull and my brother and i found that pulling a subie engine was crazy easy and so was putting it back in. It took us 8 hours total, but some of that time was cleaning, and we also changed the t-belt on the new engine. also there was time lost due to me needing to help out with my 10mo old. Don't fear the mechanical work.
avionator is offline   Reply With Quote
Old 10-25-2012, 04:50 PM   #14
cal_look_zero
Member#: 294461
1997 Outback Sport
383hp/345tq
Buy any ol EJ22, swap over your heads and manifolds, reinstall it, done.
I rarely see 22s spin bearings, but I'm in the middle of a complete rebuild on one. Internals (save for piston dish) are the same as every other one I've torn down; 90 up through 99.
cal_look_zero is online now   Reply With Quote
Old 10-28-2012, 04:11 PM   #15
Pablopakman
Member#: 336372
97 impreza wagon
red
Have you researched/considered a JDM ej25? They can be found just about anywhere.
Pablopakman is offline   Reply With Quote
