Old 10-26-2012, 06:18 PM   #51
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Lexan is ready to rock n roll
mtcs is offline   Reply With Quote
Old 10-27-2012, 12:22 PM   #52
Andymsr1
Member#: 336254
2005 RSX Type S
Nighthawk Black Pearl
Wow this is an incredible build. In for updates!
Andymsr1 is offline   Reply With Quote
Old 10-28-2012, 12:26 PM   #53
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
You forgot one major thing! A ROLLCAGE. Not fun when you get kicked out for no rollcage and you gotta tear the car back apart.
Also did you have the cosworth manifold machined out to match your throttle body, as cosworth is setup for stock body. There will be a huge ristriction there if not machined. Build is looking great and keep it up.
02WRX2.5 is offline   Reply With Quote
Old 10-28-2012, 01:30 PM   #54
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Roll cage was the first thing I thought of when I began the drag build 3 years ago. I bought 60ft of moly last January in preparation for the cage. It’s going to be run pretty local strip, Toronto dragway and at a ton of events in the north east. Most of which are NHRA. So cage is a must for sure.
Austin spoke to Skunk, it looks like their TB is a direct drop in for the cosy manifold. Time will tell if there is any truth to that or not. Don’t know many people running DBW TBs on a drag car. Kinda stupid if you ask me. But it does make my life easier wiring/custom fabrication-wise. So we’ll just have to see if im going to regret going dbw.
Hoping to have this thing finished for march next year for opening day.
Old 10-28-2012, 01:41 PM   #55
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Next few steps for winter:
Finish stripping the bottom of the car.
Few pics from yesterday afternoon.
Coat the bottom of the car.
Wait for the arrival of the TSSFAB front/rear subframes and trailing arms (2-3 weeks)
Mockup motor, trans, awic and wiring
Pull it all out
Spray the engine bay.
Hack the roof off in prep for the carbon roof
Mock up the cage
Weld everything in.
Lexan Lexan
Spray interior
Hope to be at the end of January 2013 by this point. Then comes the fun parts :P
Old 10-28-2012, 04:37 PM   #56
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
looks awesome! one question why are you not doing any seam welding... since you are caging it why not seam weld?
bugeyesubie is offline   Reply With Quote
Old 12-09-2012, 06:14 AM   #57
vicious_fishes
Member#: 158864
2003 SOHC destroker
definitely gotta get a weight of this bad boy when it's done!
Old 12-10-2012, 05:27 PM   #58
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Its funny, I just got done grinding and smoothing my water manifold and then just saw yours. Nice. I also did the AN-20 route and now think I need the black powder coat. My turbo is low front and centered so we are close there too. But my engine is in the back Jack...
RSti_Spyder is offline   Reply With Quote
Old 12-22-2012, 10:30 PM   #59
Hellchaser
Member#: 278263
Good build so far. I would love to see vids from every possible angle (in car, out of car, from the stands, fly byes, security cam) because this will be awesome
Hellchaser is offline   Reply With Quote
Old 12-23-2012, 12:17 PM   #60
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
what are you using to strip the under coat with? Just heat and a scrapper or a chemical? Looks great.
Old 12-24-2012, 02:48 PM   #61
25rsti
Member#: 166324
Looks like he's using an air tool of some sort.
Old 12-24-2012, 07:30 PM   #62
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Scraper, wire brush and solvent. Coated with self-etching primer and flat black overtop.
Should be light enough.
Old 12-24-2012, 07:32 PM   #63
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
New moly transmission cradle
-9 lbs over stock
Old 12-26-2012, 12:13 PM   #64
68Cadillac
Member#: 95901
Solid mounted. You monster.
Old 12-26-2012, 02:02 PM   #65
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Little end tank mockup.
Cory does magic.
Pics of the fabrication of the endtanks to come.
Old 12-27-2012, 12:41 PM   #66
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Almost done...
Old 12-27-2012, 03:17 PM   #67
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Old 12-27-2012, 06:13 PM   #68
fobiawrx
Member#: 91074
04 sti
white
looks really good. you weld the inside of your end tanks? i try to mock up everything including the pipe on the end tanks so i can weld it on the inside as well as the out side. super pumped on your build.
fobiawrx is offline   Reply With Quote
Old 12-27-2012, 07:10 PM   #69
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Looks pretty good so far...
Old 12-28-2012, 01:02 PM   #70
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Very nice!
Old 12-28-2012, 07:22 PM   #71
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Exhaust done.
Just need to add some sheetmetal to protect the bumper.
Old 12-28-2012, 09:35 PM   #72
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Sweet
Old 12-29-2012, 11:53 AM   #73
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
no playing games here! keep up the work!
xdrian is offline   Reply With Quote
Old 12-29-2012, 12:47 PM   #74
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
wow...one off kit?
Old 12-29-2012, 12:51 PM   #75
207STi
Member#: 197062
1998 Swapped Impreza
black
absolutely amazing work! Can't wait to see this thing finished.
FS : FS : Forward facing, remote mount turbo, exhaust manifold Dipp Engine/Power/Exhaust 8 06-07-2011 06:33 PM
WTB: forward facing carseat MiCaHSTi RMIC Private Classifieds 7 07-06-2009 01:24 PM
WTB: Seibon Type CW STi forward facing scoop Shifty Eyes Private 'Wanted' Classifieds 4 11-07-2004 12:01 PM
Law regarding # of forward facing lights? NeoteriX Newbies & FAQs 15 12-30-2002 10:36 PM
forward facing front strut tower brace and intake urbanwhitetrash Brakes, Steering & Suspension 0 09-07-2001 02:22 PM
