Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 03-31-2009, 04:49 AM   #1
thepigsti
Member#: 166215
Default Another STi won't start after intake mani removal
Sorry create my own post for this but I am running out of time before my tuning appointment.
This past weekend I installed a bunch of stuff (see below) and now the car won't stay running. It is turning over then revs up for a second and then dies. Subsequent attempts to start will rev up for a second then die. If I give it a little gas it will rev and run a bit rough perhaps, but sputters and dies quickly if I don't. This leads me to believe it is at least getting fuel and spark. Car ran fine previously, and the following are new as of this weekend:
APS turbo inlet
Blouch Dom 3
DW 740 injectors
Prodrive BCS
Grimspeed TGV deletes and phenolic spacers
Perrin EL header
Grimspeed up
Perrin FMIC
KSTech 73mm big MAF CAI
Checked my grounds twice; no luck. Reversed the fuel lines at the stock regulator and the pump got louder and it still didn't start. No codes either. Made sure the MAF is not reversed (wires toward front of car), all the coilpacks are in their right spots, checked all electrical connectors and vacuum lines for proper placement. No fuel leaks that I can see or smell, the area around all 4 injectors is bone dry. I checked all the post MAF couplers but I guess I will try that again.
I have a tuning appointment tomorrow, so I will be up all night until this is working. Any help is much appreciated, I am going to keep digging. By the way the custom map I am running is from Surgeline, not some brotune cooked up on a Speak-and-Spell. Thank you for looking.
Full mod list
Cobb AP V2 with custom safe map (for all mods below)
DW 740cc injectors
Walboro 255lph fuel pump
NGK one step colder plugs
Prodrive 3 port BCS
KStech 73mm CAI
APS turbo inlet
Blouch Dom 3 turbo (2.4" inlet)
Perrin FMIC
APS 50/50 BPV
Grimspeed TGV deletes and Phelolic spacers
Perrin EL header
Grimmspeed up
iNvidia V3 DP
thepigsti is offline   Reply With Quote
Old 03-31-2009, 05:35 AM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
were u tuned for that 73mm cai?
Nuke209 is offline   Reply With Quote
Old 03-31-2009, 09:01 AM   #3
thepigsti
Member#: 166215
Yes, I was told the map accounted for the 73mm CAI as well as the DW740 injectors.
Old 03-31-2009, 09:10 AM   #4
WeldingHank
Member#: 98645
2002 WRX Wagon
make sure your fuel feed and return lines aren't reversed.
WeldingHank is offline   Reply With Quote
Old 03-31-2009, 09:59 AM   #5
thepigsti
Member#: 166215
Yea I tried that after reading another thread, the pump priming noise got a lot louder and it wouldn't start either. I have the relocated stock FPR that matches the APS inlet install instructions exactly. Thanks though.
Old 03-31-2009, 10:04 AM   #6
STIBungy
Member#: 51684
Check for any leaks in the intake manifold. You may have forgotten to tighten it down or left a vaccuum line undone. Make sure all your sensors and injectors are plugged in. Are there any CELs?
STIBungy is offline   Reply With Quote
Old 03-31-2009, 10:17 AM   #7
thepigsti
Member#: 166215
No codes unfortunately, I am checking all vacuum lines and sensors yet again but only because I am out of other things to check that I know about.
It does the same thing no matter what I do, turn the key and it fires revs up to about 3k and dies. Trying to start after that without re-priming the fuel pump it will rev up to maybe 1k before dying. I can keep it running if I give it a little gas, but it sputters out at lower RPM; seems be pretty rough however.
Old 03-31-2009, 10:39 AM   #8
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Try unplugging the MAF, then starting it. That will tell you if the issue is around the manifold and not some other part that may be leaking (like a turbo hose).
gabedude is offline   Reply With Quote
Old 03-31-2009, 10:58 AM   #9
thepigsti
Member#: 166215
Finally a change! I unplugged the MAF connector and it revs up to around 4k and holds steady. What does this mean? I am scrubbing through the manual as we speak.
Old 03-31-2009, 11:52 AM   #10
gabedude
Member#: 10108
07 STI
There is some leak before the TB or the tune is off. Just contact your tuner and tell him what is going on.
Old 03-31-2009, 02:41 PM   #11
thepigsti
Member#: 166215
I just rigged up something so I could attach the MAF housing directly to the TB and eliminate the turbo inlet, turbo and all the intercooler piping. Same exact behavior. The only other places for leaks (to my knowledge) is the TB, manifold to TGV and TGV to head.
I guess I will start tearing everything apart again.
Old 04-01-2009, 03:05 AM   #12
stock06sti
Member#: 190559
2006 STI
Dark Gray Metallic
i had this same problem after doing tgv deletes and injectors it turns out we stretched out and tore the o ring that sealed to fuel rail to the tgv NOT on the injector itself i had to replace it and it fixed it
stock06sti is offline   Reply With Quote
Old 04-01-2009, 04:06 AM   #13
methaddict
Member#: 159738
2004 WRB STi
OFCD V3, FR TS, BW8374EFR
Check all around the phenolic spacer, tgv's, and gaskets to make sure they are seated flat. If the hard inlet isn't orientated just so it might have obstructed you from seating the manifold to the tgv's or the tgv's to the head. If there's the slightest gap, you'll have a huge vacum leak. It's a tight fit with factory fuel lines and bov recirculating hose and vacum lines. Make sure your vacum lines or fuel lines aren't pinched. Be very careful of the routing of the fuel lines. Some of my stock fuel lines actually got cut from being to close to sharp edges from hard pipe brackets that had to be cut.
methaddict is offline   Reply With Quote
Old 04-01-2009, 05:03 AM   #14
drmichael
Member#: 68340
2006 WRX
SMG
I've had the same problem a while back, and it turned out to be a bad fuel pump. Hope you get it running soon.
drmichael is offline   Reply With Quote
Old 10-29-2012, 05:38 PM   #15
Quiksmith
Member#: 266230
2006 WRX STI
What was the verdict on this issue?
Quiksmith is offline   Reply With Quote
Old 10-29-2012, 11:19 PM   #16
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Check that you plugged in the crank and cam sensors!
Old 11-17-2015, 12:25 PM   #17
kevin11sti
Member#: 279787
2011 STI Hatch
white
Any verdict? I am having an identical issue
kevin11sti is offline   Reply With Quote
Old 11-17-2015, 03:04 PM   #18
mbtech764
Member#: 429111
2016 sti
This screams vacuum leak to me
mbtech764 is offline   Reply With Quote
Car won't start after flashing until power removed/replaced silentt Open Source Reflashes 9 04-17-2009 11:11 PM
problem starting after intake manifold removal Le Saboteur Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 03-31-2009 12:54 PM
car won't run after intake manifold removal sti_vr4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 04-22-2007 12:41 PM
Car won't start after first start plaines Service & Maintenance 0 01-17-2007 06:55 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-12-2001 12:35 AM
