Old 10-26-2012, 09:10 AM   #1
tanz1983
Member#: 131047
Default cam slipage
I recently changed my timing belt with great results. the car ran fine for a while. Now, with the weather change, while driving, the engine will squeak for a second and and go back to normal. I don't feel too much. I cant tell if its the road or a minute loss of power. I am getting a P006, P007, P009 code. i can't even find this code. Any have any ideas?
2006 wrx tr with mostly suspension mods and some minor engine upgrades. Just a new turbo and full exhaust and tuning.
tanz1983 is offline   Reply With Quote
Old 10-26-2012, 12:50 PM   #2
some dude
Member#: 100300
06 WRX
A quick check tells me there should be 4 digits in any code, not 3. That could be the raisin you can't find the code.
Old 10-26-2012, 01:15 PM   #3
stevejones19
Member#: 275250
2006 WRX
Minute loss of power? How do you know? Do you have any control to check it against? could be that you are just getting used to it and it doesn't have the same effect anymore. And the squeak could be your power steering belt. Have you used any engine bay cleaners at all? I've personally found that those are prone to making your belt go out sooner.
stevejones19 is offline   Reply With Quote
Old 10-29-2012, 11:40 AM   #4
tanz1983
Member#: 131047
no belt cleaners. brand new belts all around. the first digit is a 2 which is for electrical issues. I thought it was power steering until I could feel a momentary loss of power. while in 5th gear at a steady speed, the car will squeak and lose power and regain it very quickly.
Old 10-29-2012, 12:11 PM   #5
holyjoetart
Member#: 232986
07 Legacy GT
Sounds like it could be your a/c clutch engaging, causing the power problem. It happens on my buddy's '03. Unplug your compressor clutch and take it on a drive and see if it helps.
holyjoetart is offline   Reply With Quote
Old 10-29-2012, 04:27 PM   #6
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^If the ac comp kickin in causes a noticable loss of power...........its time for a V8
Old 10-30-2012, 10:10 AM   #7
tanz1983
Member#: 131047
For some reason the problem fixed itself. Thanks for the input guys. I wish I could afford the V8 conversion
