#1 |
Member#: 292104
NESIC
Vehicle:2006 Jawny jawn Burple |
Alright guys I need some help. I am having issues with achieving boost in 1st and 2nd gears. The car is a 06 wrx with a VF22. In 1st gear at WOT I can only get ~10psi max where normally I can get 15 out of it. In 2nd gear I can only get it up to ~16psi where normally it will get to full boost which is 22psi. In 3rd - 5th it will hit full boost but it spools like a 40r. I just replaced the pre turbo exhaust gaskets as they were all leaking a bit but this did nothing. Any help would be greatly appreciated.
#2 |
Member#: 292104
NESIC
Also the turbo has ~20k on it and is not exhibiting the normal dentist drill signs of a bad turbo.
#3 |
Member#: 232986
Vehicle:07 Legacy GT OBP |
Plugged air filter?
Vacuum leak? BPV leak? Waste gate sticking open? |
#4 |
Member#: 140974
I did this smoke test I saw on youtube where the guy uses a cigar and blows into one of the vacuum lines on the intake pipe. He then looks for where the smoke is coming out of. I found a leak on my inlet pipe, small, but enough to throw off the ECU to go into safe mode.
#5 | |
Member#: 298231
MAIC
Vehicle:2011 Subaru WRX WRB |
#6 |
Member#: 292104
NESIC
Thanks for the help guys. I will get probing in the AM. how do you check to see if the wastegate is stuck open?
#7 |
Member#: 140974
Right by the sleeve of the inlet pipe that covers the turbo. If the clamp moves, it sucks in air and has the car run lean. I got a used AVO extended inlet pipe, solved the torque loss problem.
PS - I dont smoke tobacco, stay HERBAL! |
#8 |
Member#: 140974
Here's a pic of my wife's sti's inlet pipe
![]() This tiny hole made that boost fluctuation....i guess whenever it inched of the clamp. ![]() |
