Old 02-12-2012, 09:52 AM   #1
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Default forge iwg on vf52
Ok so i bought a forge internal wastegate for a td04/05 and it will bolt up just fine to my vf52 but there is one problem. The wastegate arm on the forge unit attaches to the flapper differnt then the vf52 arm. The forge is female at the end and the vf52 is male at the end. I was wondering if i can attach the forge unit with just a nut and bolt as long as i leave it a little loose for travel. Sorry if my terminolagy and spelling are not on point.
nate_fisher is offline   Reply With Quote
Old 02-12-2012, 05:40 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
whats wrong with the oem vf52 wastegate actuator? ive seen no one change their stock unit out. im running 22 psi on my vf52 with the stocker.
Old 08-22-2012, 04:27 PM   #3
kevinmfb
Member#: 206579
2009 WRX
Obsidean Black Pearl
I'm looking to change my actuator out as well but am having a hard time finding concrete evidence that justifies buying one.
My car will hit peak boost (21psi) then immediately fall off quickly from there down to around 12 psi IIRC. My tuner thinks the wastegate is weak and staying open.
Was on Forge's site and didn't see an actuator specifically for the VF52. Did you get your problem solved? I know this is an older thread just didn't see any responses or updates.
kevinmfb is offline   Reply With Quote
Old 08-22-2012, 04:36 PM   #4
Wicked Performance
Member#: 265606
The IWG actuator is likely not the problem. boost leak?
Wicked Performance is offline   Reply With Quote
Old 08-22-2012, 04:41 PM   #5
nate_fisher
Member#: 270482
2011 turbotek fxt
Forge iwg wont fit but yes i switched to e85 and my tuner made a great tune i am hitting 23psi tapering to around 18psi by my 6k redline with the stock iwg. If you want avo makes a iwg for the vf52 if your interested.
Old 08-29-2012, 01:55 PM   #6
kevinmfb
Member#: 206579
2009 WRX
Did not know that AVO made one for the VF52.
I emailed them directly and they stated that they didn't make one specifically for the VF52 turbo. Do you have a model number for the one you got?
Old 08-29-2012, 01:56 PM   #7
kevinmfb
Member#: 206579
2009 WRX
Tested and no leaks. Wish it was that easy of a fix.
I hate how something so easy to fix becomes a chore.
Oh well, it's part of the learning game I guess.
Old 08-30-2012, 09:03 AM   #8
nate_fisher
Member#: 270482
2011 turbotek fxt
I dont have one but the 08+ avo p# s2d08g08a002. Also kinugawa makes one directly for the vf52 and is cheaper.
Old 08-30-2012, 09:22 AM   #9
NoGraffix
Member#: 276209
I am Rub
Function>Form
Not sure changing the acuator would really be worthwhile on a vf turbo. A better investment would be an EWG hands down.
NoGraffix is offline   Reply With Quote
Old 10-30-2012, 03:12 PM   #10
kevinmfb
Member#: 206579
2009 WRX
Got a 15lb Kinugawa for $96 (with shipping) and it's too stiff. I peek at 24psi and tapers down to about 22psi. Which means I don't push the pedal down or go past 3000 rpms
Looking into TurboSmart 10lb actuator.
In the meantime I'm going to see if my stock unit will hold as it turns out one of the rubber ends was ripped on my factory throttle body hose. Have since replaced the hose with a silicone hose and t-bolt clamps.
Hopefully the stock unit will work and I can quit stewing over this crap not working correct.
Old 10-30-2012, 06:14 PM   #11
nate_fisher
Member#: 270482
2011 turbotek fxt
I will buy it if you cant use it
Old 10-31-2012, 09:11 AM   #12
Leafy
Member#: 330625
2006 WRX
Sounds like your tune needs to be adjusted. You should be able to make that just hold a solid 15psi if you wanted to.
Old 10-31-2012, 11:14 AM   #13
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
Yeah what are your WDCs? You should have them turned down to 0 for 15psi and alittle more for more. If you kept them the same and just swapped out the wastegate actuator I'd guess you'd be boosting almost double your targets. On the stock unit with a stage 1, I"m getting [email protected] with only 60%WDC.
tunertype is offline   Reply With Quote
FS : 20g Tdo6sl-2 8cm With Forge Iwg (PRICE REDUCED) SOLD SOLD SOLD bilt2run Engine/Power/Exhaust 42 02-11-2012 03:24 PM
FS : APS SR55 turbo w/ adjustable Forge IWG **ceramic coated LOW MILES** **PICS** phlegmon Engine/Power/Exhaust 12 09-07-2010 11:19 PM
FS: (PA) new/open box 15-18psi spring option Forge IWG Wastegate Actuator SOLD sutter2k Engine/Power/Exhaust 3 05-11-2010 11:02 AM
FS:Cusco heatshield w/ fmic bracket,Forge IWG act.,Carbing catch can. obsti2 Engine/Power/Exhaust 1 09-19-2009 06:08 PM
closing IWG on 16g? 04blckwrx Newbies & FAQs 21 03-28-2008 06:33 PM
