Welcome to the North American Subaru Impreza Owners Club Wednesday September 17, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 10-30-2012, 07:40 PM   #1
Alann314
Member#: 319350
2005 Impreza WRX
Default I want fireballs!!
Ok so I have always wanted to be able to shoot little flames from my exhaust and I can't manage to get it!! So I drive a 05 WRX with a full TBE exhaust no cats,resonators or mufflers. I have a short ram perrin intake and a cobb stage 2 ACN tune on it. I just purchased a Forge BOV and installed it. This BOV can either be set up for recirc or atmospheric. I made sure I disconnected the recirc hose and plugged it so that the BOV is atmospheric. Whenever I step on it and release you can hear the pressure being released but i get no fireballs . I know its not good to be shooting fire but I just want to try it for once. Any ideas?
Alann314 is offline   Reply With Quote
Old 10-30-2012, 07:44 PM   #2
WrxWrb
Member#: 287477
02 Wrx Wagon WRB
EVO III 16g=Fun
Oooh boy.
WrxWrb is offline   Reply With Quote
Old 10-30-2012, 07:50 PM   #3
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
If you want fireballs, you should try messing with all the fuel trims yourself, and whatever you do, don't let a qualified tuner touch your car, because they won't do it!
guroove is offline   Reply With Quote
Old 10-30-2012, 07:51 PM   #4
anonmassive
Member#: 158464
YER MOM
BLURPLE
:facepalm:
anonmassive is offline   Reply With Quote
Old 10-30-2012, 07:55 PM   #5
gsmith304
Member#: 302159
2003 WRX
Sonic Yellow
I think most people that do "shoot fireballs", its more accidental than on purpose. I could be wrong
gsmith304 is offline   Reply With Quote
Old 10-30-2012, 07:56 PM   #6
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Plenty of guys in OT do this with their cars.
Start this same thread there and you'll get a ton of assistance.
Spenk is offline   Reply With Quote
Old 10-30-2012, 07:56 PM   #7
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Aren't there kits that include a spark plug and all need equipment to do so?
Brother EddieJ. is offline   Reply With Quote
Old 10-30-2012, 08:00 PM   #8
meat_WRX
Member#: 96919
2004 sti
black
OMG.
is not likely to happen when your just cruising around, but beat on your car a little bit, do some pulls, get everything nice and hot. then see what happens.
meat_WRX is offline   Reply With Quote
Old 10-30-2012, 08:22 PM   #9
guroove
Member#: 129833
2005 Forester XT
FYI, my last post was a joke. This thread might be of interest to the OP:
http://www.iwsti.com/forums/2-5-lite...hifting-2.html
Try filming your exhaust in the dark and give it some revs over 3000 rpm, or have someone drive behind you at night and film your car shifting gears.
Old 10-30-2012, 08:25 PM   #10
meat_WRX
Member#: 96919
2004 sti
black
btw... my 300 whp, Automatic 05 forester Turbo pops fire balls. and all im running ia a vf39 with supporting mods, no cats, and a cobb OTS 91oct map.
Old 10-30-2012, 08:27 PM   #11
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Try unplugging a coil pack, maybe two. But get it good and warned up first.
Or get an OS tune with anti-lag.
bushflyr is offline   Reply With Quote
Old 10-30-2012, 08:36 PM   #12
Alann314
Member#: 319350
2005 Impreza WRX
So I think I might try this. I have a short ram perrin intake the big MAF and its always causing my CEL to come on saying im running lean. Im going to put the stock intake back in and clear codes and see what happens. But honestly comon everyone wants to see their subaru shoot just one little flame.
Old 10-30-2012, 09:00 PM   #13
CanadianImprezaSTi
Member#: 312159
2004 WRX
I'm shocked your car has not piled.
A lean code does not worry you? Especially on a boosted car? Put the stock intake back on, along with a recirculating bpv and leave your car stage 2.
Either that or get a tune for that intake.
Joel
CanadianImprezaSTi is offline   Reply With Quote
Old 10-31-2012, 09:50 AM   #14
rkramer
Member#: 118209
2002 WRX Sedan
How about an in-cabin toggle switch connected to the wires of a coil pack or two? (why, why, why would I even suggest that, someone might actually try it! )
rkramer is offline   Reply With Quote
Old 10-31-2012, 09:58 AM   #15
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
In for the flaming of the flamer asking about shooting flames. flame-ception
jayman4312 is offline   Reply With Quote
Old 10-31-2012, 10:03 AM   #16
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
u cant just throw a huge intake on and expect it to work. you got a lot of learning to do dude. classic example of someone who can put parts on and thnks the car is faster and then boom its blown!
get a vent to atmosphere bov and it will inject the fuel but release the air. about the easiest way to do so w/o breaking stuff. a spark plug in the exh near the tip will help.
WhiteBgeye02 is offline   Reply With Quote
Old 10-31-2012, 10:18 AM   #17
lastsnare
Member#: 169539
2004 WRX sedan JBP
2013 BRZ GBS, 2000 2.5RS
My experience is this:
Several years ago I had a blow off valve. It had an adjustable spring on it but it always was closed so tightly that letting off light throttle would surge a bit; or it was so loose that it was almost always on the verge of partially open, even at idle. Could never get it exactly right, but this is partly how I got some flames.
It was a GFB Stealth FX that you could vary between full VTA and full recirc, and the spring pressure was also continuously adjustable, as I mentioned.
I also was running an AccessPort with a Stage 2 off-the-shelf tune.
I used to get some flames occasionally.
If your BOV spring is setup on the loose side, you might be able to get it to happen.
For me it would pop a little if I would hold the throttle at a continuous point for a few seconds, maybe around 4k or 5k, and then let off completely. I know that it would happen on the street when under load, can't remember if it would when I was in neutral.
After revving like this a few times consecutively, I could almost predictably produce some flames out of the exhaust.
This was also running a 3" type loud-can straight-through turboback with no cats.
It was enough to be visible during daytime, I noticed this one day when I let someone else autocross my car.
Not like jet afterburners (not several feet or a prolonged flame), but enough to scare someone if they weren't expecting it.
As always, be careful, use utmost discretion, be considerate of pedestrians, other cars and neighbors, and I'm sure it's completely 105% illegal.
This is just for the sake of argument and how it could work.
lastsnare is offline   Reply With Quote
Old 10-31-2012, 01:05 PM   #18
ScoobySubyDoo
Member#: 329311
2003 WRX
Satin Black
So you are just looking for backfiring on your car? Doesn't that mean there is fuel somehow in your exhuast and is being ignited in there?
ScoobySubyDoo is offline   Reply With Quote
Old 10-31-2012, 04:29 PM   #19
hudsonvalleybugeye
Member#: 295068
2003 wrx
Sedona Red Pearl
Yeah, tell a tuner you want an overly rich tune...or go oldschool style and connect an in cabin switch to a spark plug mounted in the end of your exhaust path.
hudsonvalleybugeye is offline   Reply With Quote
Old 10-31-2012, 05:41 PM   #20
Extreme Turbo Systems
Member#: 194655
08 STI
Extreme Turbo Systems is offline   Reply With Quote
Old 10-31-2012, 09:27 PM   #21
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
flame suit on
Dirty_WRX is offline   Reply With Quote
Old 10-31-2012, 09:38 PM   #22
stretchnuts
Member#: 292991
04 derp mobile
blurrr
Ugh....I bet if you had a diesel truck you would tell your tuner to give you a silly rich tune so you could smoke everyone out. I personally wince whenever I get a pop or flame from my car.
stretchnuts is offline   Reply With Quote
Old 10-31-2012, 09:51 PM   #23
Alann314
Member#: 319350
2005 Impreza WRX
I didnt throw on a bigger intake i threw on my stock one...I also do have a vent to atmosphere BOV which i can switch to recirc also.
Old 11-01-2012, 12:41 PM   #24
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
i remember back when I had the stock inlet tube back on it had a small tear where it connects to the turbo side and I had constant popping with flames in every single gear. i let let off the gas at 3k in the rpms and all u hear is *POP* and not these little pops but loud ones with flames coming out. it was really fun driving around with that problem for months next to people. after a while the inlet tore more and had to be replaced. i was running a turbosmart dual port at the time. my experience lol
dumpstercrusher is offline   Reply With Quote
Old 11-01-2012, 02:10 PM   #25
dub kllr
Member#: 129996
97 RHD STi
Ghey
Buy an SRT-4. They shoot fire quite consistently.
dub kllr is offline   Reply With Quote
