Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 10-31-2012, 08:59 AM   #1
abacall
Member#: 132025
06 WRX Spec-C Swap
Default shaky idle at startup, not like the rest
I've read tons of thread about the shaky idle, this isn't like those.
My 06 STI has a super shaky idle at start up, regardless of temperature. It idles like it has super lopey cams, until I blip the throttle.
After a quick short stab at the throttle, it returns to the normal high smooth idle. Only does it on cold start.
Stage 2 power mods (catless), tuned by a reputable tuner.
abacall is offline   Reply With Quote
Old 10-31-2012, 09:40 AM   #2
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Try cleaning the IAC passage on the TB?
http://forums.nasioc.com/forums/showthread.php?t=781242
darkstarmoto is offline   Reply With Quote
Old 10-31-2012, 09:48 AM   #3
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
It's DBW...
mechatricity is offline   Reply With Quote
Old 10-31-2012, 12:06 PM   #4
abacall
Member#: 132025
06 WRX Spec-C Swap
Here's a video. I also have a Odyssey lightweight battery, wonder if it has to do with voltage?
After the end of the video, the car idles totally normal. Sits at about 1,500 for a few, then back to ~800. Smooth all the way after that.
Old 02-04-2013, 04:50 PM   #5
RussSTI
Member#: 334177
2007 STI
did you ever fix the problem? im having the issue.
RussSTI is offline   Reply With Quote
Old 11-10-2013, 11:08 AM   #6
abacall
Member#: 132025
06 WRX Spec-C Swap
Start-up problem was tune related. Tune touchup on cold-start solved the problem.
