Old 10-24-2012, 04:29 PM   #176
TravTagz
Member#: 326310
2012 WRX Premium
Anyone recommend a brand and model for brightest and whitest look?
TravTagz is offline   Reply With Quote
Old 10-24-2012, 11:47 PM   #177
Dova
Member#: 315989
2012 WRX
Satin Pearl White
I went from H9 white bulbs from headlightbulbs .com to Philips H9 German made. The Philips one are much better. The light cutoff is sharper n output is much better.
Dova is offline   Reply With Quote
Old 10-25-2012, 01:59 AM   #178
gtowni3
Member#: 297689
As I was about to place my order I saw your post. Honestly, how much better is output w/the H9 German Philips as compared to the Platinum Bulb from HLB.com if you were to rate it?
gtowni3 is offline   Reply With Quote
Old 10-25-2012, 10:14 AM   #179
Angelus911
Member#: 89967
2012 Impreza Sport
I just upgraded my H11 to H9 on my '12 Impreza, what a difference! Will definitely come in handy this winter driving home at night
Old 10-25-2012, 08:41 PM   #180
Dova
Member#: 315989
2012 WRX
Satin Pearl White
I can see further which was a plus. I really wanted to stay with the white bulbs because of the looks on the car but visibility wins.
Old 10-25-2012, 09:09 PM   #181
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
I can see further which was a plus. I really wanted to stay with the white bulbs because of the looks on the car but visibility is wins.
hello, the website "head light bulbs dot com" has some "Moar" white lights.
ChesterWRX is online now   Reply With Quote
Old 10-25-2012, 09:44 PM   #182
Dova
Member#: 315989
2012 WRX
Satin Pearl White
Hello.
Old 10-31-2012, 11:26 PM   #183
Scooby207
Member#: 255687
11 WRX DGM
Finally decided to throw down for h9 and 9011 combo
Can't wait for them to come in
Scooby207 is offline   Reply With Quote
Old 11-01-2012, 09:16 AM   #184
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
do post pics when you get em. i've been wanting to see the 9010/9011 on a subie
Old 11-08-2012, 09:38 PM   #185
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
So is there any replacement high beam bulbs other than the HIR? I put some sylvania H9s in the lows, and now my highs are lacking
ColeBerkenbile is offline   Reply With Quote
Old 11-10-2012, 07:21 AM   #186
Tack762
Member#: 261845
Silver EFI logics stg 2
The only option I can think of is to just upgrade your existing 9005 bulbs in your highs to some Narva or phillips offerings. I'm doing HIR1 in my highs today but also doing the fog light DRL mod also. Not sure how long the HIR1's will last being that they will always be on as DRL's without the mod.
Tack762 is offline   Reply With Quote
Old 11-10-2012, 08:02 PM   #187
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
HIR's don't like to be the DRL so just disable that function and you'll be good to go.
aerosaaber is offline   Reply With Quote
Old 11-18-2012, 05:06 PM   #188
2subiesinyard
Member#: 139562
Originally Posted by veener79 View Post
I have read about being able to change the headlights to a H9 bulb with just simply removing a tab in the H9 socket. Some people did it. Others have not because they were worried about their wires or head lights getting to warm. I did a 10min bench mark test without the car running. That way it would show the temps before and after the test.
Thanks for the info, and the temps. It made the upgrade easy, and worry free !!!
2subiesinyard is offline   Reply With Quote
Old 11-18-2012, 07:22 PM   #189
veener79
Member#: 204304
2008 WRX 4D Stage 2
No problem. Just glad this thread has helped out so many.
veener79 is offline   Reply With Quote
Old 11-18-2012, 08:59 PM   #190
J.biz
Member#: 191825
2009 WRX
I think this is my next mod.. Time to lose the pnp hid kit..
J.biz is offline   Reply With Quote
Old 11-20-2012, 11:13 AM   #191
Syndr78
Member#: 336966
2013 WRX
Just ordered the PIAA extreme white H9's from Amazon. Kinda Pricey, but if they last a year, I'll be happy. I'm sure they will blow the stockers away. I wonder how much better they are than the MUCH cheaper Phillips.
Will post back once installed with review/results...
Syndr78 is offline   Reply With Quote
Old 11-20-2012, 03:08 PM   #192
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
I've cross-referenced the H9 mod on other car forums and the life span average seems to be 18-24 months. YMMV of course.
i'm still to early with mine to even worry about having back ups ready.
Old 11-20-2012, 08:20 PM   #193
Syndr78
Member#: 336966
2013 WRX
Chester.
How do you like the PIAA's? They are way more expensive than the Phillips. Do you have any other H9 exeprience to which you can compare the PIAA's to. Are they "worth it"?
Old 11-22-2012, 08:19 AM   #194
Aikawa
Member#: 338208
'13 bulbs same as '12?
Aikawa is offline   Reply With Quote
Old 11-22-2012, 07:10 PM   #195
2subiesinyard
Member#: 139562
Probably, look in your owners manual.
The wifies 2012 Impreza Sport uses H11's from the factory, so I'll be upgrading her Scoobie to H9's as well.
Old 11-22-2012, 07:38 PM   #196
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Chester.
i think you have me mixed up with another reply in this thread. i don't own the PIAA's but may try those next.
i have H9 hyper-whites
Old 11-22-2012, 08:19 PM   #197
Syndr78
Member#: 336966
2013 WRX
Yup--my mistake. Guess I'll let YOU know how they turn out.
Old 11-23-2012, 04:47 PM   #198
trife86
Member#: 301368
2012 WRX
PBP
I did this mod and i wanted to take a look at my bulbs so i pulled out the bulb and i had a connector piece stuck in the bulb end, Green piece that is now in the bulb housing when it was in the connector housing before, I just shoved it back into the socket and it works right but when this bulb dies I am unsure what to do after that, Do they sell more of these connecting pieces? Will take pics if needed
Kind of like this, where the blue part is, Its stuck in my BULB housing, So if i replace bulbs i will be missing this part in the wiring connecter
trife86 is offline   Reply With Quote
Old 11-25-2012, 05:17 PM   #199
trife86
Member#: 301368
2012 WRX
PBP
Anybody?
Old 11-25-2012, 06:37 PM   #200
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
huh? .........
ETA, take a screw driver and fish it out. if you're talking about the sleeve that makes the plugs seal tight.
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain 17 07-21-2001 01:01 AM
Message Board Statistics All times are GMT -4. The time now is 12:53 PM.
