#1 |
Member#: 314722
SWIC
Vehicle:2006 STi |
Okay soo heres the deal I just spent 1400 bucks to have my 06 STi serviced and fixed by a subie dealer and before I took it in it was kinda a mess leaking fuel line leaking coolant and a broken harness any who they ended up changing the whole harness and what not some hoses and fixed my fuel leak out took 3 weeks for all this so finally I get my car back and the biggest thing of all my turbo doesn't spool at all now and my bov doesn't even go off im soo frustrated and just need some answers on whats wrong now thanks and those are the two codes that popp up which bit to say the P2006 was on already before i took it in
#2 |
Member#: 150494
SCIC
Vehicle:11 WRX SWP Torqued Stg II |
Holy run on sentence, batman. Did you google these codes?
Edit: Here: http://forums.nasioc.com/forums/show....php?t=2223802 http://forums.nasioc.com/forums/showthread.php?t=216541 And that was just using a simple google search man. Not difficult. Last edited by swpshgnwgn; 11-02-2012 at 12:06 AM. Reason: I feel nice tonight. |
#3 |
Member#: 314722
SWIC
Vehicle:2006 STi |
Yea I researched that already but why wont my turbo spool or anything
#4 |
Member#: 150494
SCIC
Did it happen right after they gave you back the car? Why don't you just take it back to the dealership that you had work on it and ask them?
#5 |
Member#: 150494
SCIC
To explain the codes though, the P2006 is a TGV code. It's the valve that warms up your cat for emissions control. Pretty much a useless piece ****, but they go bad pretty often. Poorly informed opinion.
The P0245 is a wastegate low reading code. That makes sense considering you're saying you aren't boosting. It doesn't explain why though. Take it back to whoever you had work on it and ask them to take a look. Last edited by swpshgnwgn; 11-02-2012 at 01:05 AM. |
#6 |
Member#: 314722
SWIC
Vehicle:2006 STi |
Explains, a lot better thanks man and will do
#7 |
Member#: 232430
RMIC
Vehicle:555 I haz 5 Subarus GC8/GF/SG/GD sedan & wag |
OP, dont listen to this guy simply based on his explanation of what the TGV is and does. That is simply the most random b.s I have ever read.
#8 | |
Member#: 150494
SCIC
OP, check out this link: http://forums.nasioc.com/forums/show....php?t=1791412 Seems it describes your situation pretty accurately. |
#9 |
Member#: 314722
SWIC
Vehicle:2006 STi |
Yea seems id be better off going with tgv deletes and the P0245 would be an easy fix
