Old 10-18-2012, 10:11 AM   #1
sureshot007
Member#: 142405
#716 G2 OBS
Default FXT map from LGT?
I've been trying to find a stage 2 map for an 04 FXT, but no luck so far. I've read that you can't just copy wrx maps, because something is different. Does the same hold true for LGT maps? Can I copy the tables from an LGT stage 2 map and use that as a good starting point?
sureshot007 is offline   Reply With Quote
Old 10-18-2012, 11:50 PM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Sounds reasonable as long as the tables are the same size. I have no idea whether they are or not. If they're not you can still use the tables, it just won't be a simple copy.
Also make sure the column and row header values are the same, you might need to copy those as well as the cells in the tables.
Old 10-28-2012, 08:46 PM   #3
myk
Member#: 223143
2001 2.5rs Sedan
Brack
I made an FXT map from a wrx map since the 06FXT engine was pretty much the same as the 06 wrx. Probably a good place to start off from.
myk is offline   Reply With Quote
Old 10-29-2012, 08:42 AM   #4
sureshot007
Member#: 142405
#716 G2 OBS
How well did that work? Were all the tables the same? Did you have to make any major changes?
Old 10-29-2012, 04:53 PM   #5
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
I would start with a 06 wrx map since they come with the same turbo the td04. The legacy comes with a vf41 and stage 2 would be totaly different then the td04 on your fxt.
nate_fisher is offline   Reply With Quote
Old 11-02-2012, 02:20 PM   #6
bmx045
Member#: 262684
2015 Impreza Sport
ISM
05-06 lgt have a vf40, 07-09 vf46
bmx045 is offline   Reply With Quote
