#1 |
Member#: 315546
Vehicle:03 wrx silver |
Im going to attempt to swap out my oil pan this week.
Can not find a decent diy on a ej20, can someone help? I've had no luck using google. Any tips for this job? I've read alot about the motor needs to be pulled/lifted to remove oil pan, is this true for the 03 wrx? How difficult & time consuming will this be? Any tips for what gasket to use?
#2 |
Member#: 309967
BAIC
Vehicle:2003 WRX PSM vf34 |
I believe all you have to do is remove the swaybar to get to the front bolts that hold it up. Subaru oem gasket would be best imo.
Shouldnt take more than 2 hours if your on your back. |
#3 |
Member#: 257818
SWIC
Vehicle:2007 STi CGM |
tip i learned from one of the local guys, if you have a heat gun, it helps soften the factory rtv so you can pry it with a paint scraper.
#4 |
Member#: 180514
E. Canada
Vehicle:2004 Sti White |
The hardest part is to get the 4 bolts between the crossmember and oil pump.
#5 |
Member#: 162174
Vehicle:05 CGM STi - SOLD 13 SWP STi - TITS |
I did it with the engine out of my car.
I would look around for a Factory Service Manual. That's what I consulted when I did mine. Also contains torque specs! Since you're tightening into aluminum, I wouldn't want to over torque! Also, may I ask why are you swapping pans? As far as gasket is concerned call your local dealer for that. I believe it is a special RTV (at least it is on my 05) that's not too expensive! Probably take .5 to 1.0 hours taking your time and cleaning all of the surfaces (if you're mechanically inclined) Good Luck! |
#6 |
Member#: 89663
Vehicle:1962 Fuji 350 cerelean blue |
ultra black rtv is good
#7 |
Member#: 138872
South East
Vehicle:2003 WRX Wagon PSM |
It's not that bad. Un-bolt the lower motor mount bolt on each side jack up the motor/tranny and stick a 1" block of wood between the frame rail and the motor mount to keep it up. Make sure you use a 1/4 ratchet with a swivel on the socket end and a extension. That will make getting the back bolts alot easier. I found it easier once you get the bolts out of the oil pan and drop it a little take off the pickup tube. Everything will come out a lot easier.
#8 | |
Member#: 281811
Vehicle:04 WRX World Rally Blue |
#9 |
Member#: 315546
man thanks for the advice guys, i've read alot on here and other sites. People mention that I need a special razor tool to remove the sealant? is this true?
I am replacing the pan because i stripped the hole for the plug on the current one... like an idoit lol Still contemplating whether i should let a mechanic break his back over this or i should spend my sunday in the garage.. |
#10 |
Member#: 204550
TXIC
Vehicle:2003 WRX wagon WRB |
i switched mine out to install equal length headers. i did not have to raise the engine to do this. i used a 1/4" ratchet, 1/4" extension, 1/4" swivel joint and 1/4" inch socket (think it was like 10mm) to get to the rear bolts on the oil pan. the 2 middle ones are a PITA but it is possible to remove them.
once the pan is unbolted, hit it with a hammer or mallet to break the rtv seal. you will need to unbolt the pickup tube to get the oil pan off so have someone hold the pan while you unbolt the pickup tube. clean the rtv left on the block. i used a knife to scrape it off. then put your rtv on your new oil pan, stick the pickup tube into the oil pan and have someone hold the pan while you bolt the pickup tube back on. raise pan into place and begin installing your bolts. do not tighten to spec yet, just enough to hold the pan in place. the rear bolts will test your patience . work quickly because if you squished rtv into the bolt hole and it dries.....you will not install that bolt and you will have a leak. i used a flashlight and an inspection mirror to see the bolt holes and have an idea of their location.its late so i may have missed something, but this gives you an idea of the process. good luck |
#11 | |
Member#: 315546
thanks for the tips man i'll let you know how it goes if i have time on sunday. |
#12 |
Member#: 175565
Vehicle:2005 STI CGM Built 351whp/368tq |
This might help a little: http://www.killerbmotorsport.com/ind...structions.htm
#13 |
Member#: 315546
xsk7 was right it worked, pan is finally loose and unattached. What do i do with the dipstick tube can it be completely pulled out from the oil pan?
#14 |
Member#: 149262
Vehicle:2003 03WRXw6sp/05FXT PSM |
yes it can
#15 |
Member#: 315546
how could i pull it out without damanging/breaking it, hard to get a grip
#16 |
Member#: 315546
so once again, the dipstick tube can be pulled out from the pan? Whats the best way to get a good grip on this?
#17 | |
Member#: 315546
#18 |
Member#: 204550
TXIC
sweet, i'm glad you got it done
#19 | |
Member#: 45076
Vehicle:2004 Stg2 Wagon 4eat Silver |
