Old 11-05-2012, 04:06 PM   #1
Babelyy
Member#: 325946
2006 WRX, ALLBLACK
Default STi top mount to WRX
Is it just a plug an play to swap a 06 sti top mount into a 06 stock wrx? Do you have to tune that or will the sti cooler BOV cause issues?
I am just asking because my boss is selling me his like new 06 for 200$, an I was like why not.. just seeing if its a simple thing an if it will actually make that big of a difference.
Babelyy is offline   Reply With Quote
Old 11-05-2012, 04:14 PM   #2
jthatch12
Member#: 321715
03 Big 16G WRX
No you don't need to tune for it. IMO its a good upgrade. Does it come with the ypipe? If it doesn't then it's not worth it.
Old 11-05-2012, 04:35 PM   #3
Babelyy
Member#: 325946
2006 WRX, ALLBLACK
Y pipes dont cost allot though, still not worth it if I get one?
Old 11-05-2012, 05:15 PM   #4
jthatch12
Member#: 321715
03 Big 16G WRX
The ypipe is like the most important and most expensive part of the intercooler. That being said if it doesn't come with it I would not spend more that 120 on the intercooler. A decent ypipe will cost you 60+, you'll also need gaskets. I picked up an 05 sti topmount for 150 including the ypipe. So use my experience as a reference
Edit:
I have a friend who bought his intercooler for 150 without the ypipe, he ended up having to spend an extra 100 for an OEM sti ypipe off of someone on here.
Old 11-12-2012, 08:55 PM   #5
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Edit:
So your saying this:
http://www.rallysportdirect.com/Proc...ilicone-Y-Pipe
is the most expensive part of the intercooler. When the Y pipe is not even part of the intercooler. It is it's own part.
Please don't use his experience as reference!
Intercoolers are expensive to make!
I decent STI IC used goes for 200 plus BTW.
Just dropping knowledge!
Old 11-13-2012, 11:05 AM   #6
jthatch12
Member#: 321715
03 Big 16G WRX
That's truly a bunch of BS. If your buying a STi tmic, it should be expected that the OEM ypipe is included. If its not then it's not worth it IMO. You'll need to get a decent aftermarket(or OEM) ypipe for almost half the cost, not to mention gaskets.
Your link also doesn't include the actual pieces that attach the ypipe to the intercooler.... just saying.
Old 11-25-2012, 10:10 PM   #7
vicky_808
Member#: 254699
2011 STi, 05 FXT
Red, Sliver
I have a question about this..
I have a 2011 STI that I am in process of stroking out and allot of other things. I just picked up a 2005 WRX wagon and wanted to see if anyone nows of a link or have information on what parts from my STi will work on the 05 WRX
vicky_808 is offline   Reply With Quote
Old 11-26-2012, 03:36 PM   #8
Tenament
Member#: 246813
if you're in the process of "stroking out" the STi block then I don't think you should a) have a problem figuring out what/why you need stuff from the WRX drivetrain b) hijack other threads >: )
Tenament is offline   Reply With Quote
Old 11-27-2012, 06:59 AM   #9
vicky_808
Member#: 254699
2011 STi, 05 FXT
Red, Sliver
I have been looking through them but some of them are really big or deal with different years..
Old 11-28-2012, 11:19 AM   #10
kaos200
Member#: 2692
Why the heck would it be expected? So how is the STi owner supposed to bolt on their upgraded topmount IC if that is the route they went? So then THEY would have to buy an aftermarket or OE y pipe when they already have one, just so they can sell their stock cooler?
If they went FMIC then sure, you get lucky and find one with a y pipe. Otherwise, no it won't come with it. I've also bolted on several STi intercoolers to WRX's with the WRX y pipe and a new silicone connector.
Think before you post.
kaos200 is offline   Reply With Quote
Old 11-28-2012, 09:46 PM   #11
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
Haha, something tells me this person shouldn't be "stroking out" their '11 STi block either.
OP, STi intercooler will be a good upgrade for your WRX. If it comes with the y-pipe, all you'll need is a longer turbo-intercooler coupler and a 3"x2.75" throttle body coupler (check me on that measurement, off the top of my head).
Helps a lot with intake temps / heat soak, especially if you're running a slightly bigger turbo (VF43 / 18g).
scoobasaurusrex is offline   Reply With Quote
