Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 06-06-2012, 01:09 AM   #801
arthurtoo
Member#: 268250
tinywrex's website seems to be down. anyone here has the patch for A4TE002B?
thanks!
arthurtoo is offline   Reply With Quote
Old 06-10-2012, 02:06 PM   #802
jnich69
Member#: 242484
2003 18g'ed wrx
sunset orange metallic
My rom id is A4TC300L. Does anyone know if the patch for the A4TC400L will work? Or does he just not have a patch for that particular rom id?
jnich69 is offline   Reply With Quote
Old 06-11-2012, 07:09 PM   #803
jnich69
Member#: 242484
2003 18g'ed wrx
For anyone with the same rom id as me (A4TC300L) looking for a launch control patch. You can use the A4TC400L patch provided you do what I list below.
1. First you MUST MUST go to http://www.scoobypedia.co.uk/index.p...ilityList#toc2 and download the A4TC400L base map.
2. Make sure you have the rom that is on your car now saved somewhere or else you're going to be screwed in a minute. Once you download the A4TC400L basemap, go try and flash it to your car.
3. If it flashes to your to your car with out any error's, great, you can now use this map and the patch for it. The only pain about this is transferring all of your old map data to the new A4TC400L map. It really doesn't take that long.
4. After verifying it flashes and transferring all of your old map data to the A4TC400L map you can now patch it with tinywrexs patch and flash it!
I am not responsible if you mess anything on your car/ecu up.
Old 06-11-2012, 09:36 PM   #804
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Man that wiki is odd.. The file name for the AH580 is "07 Outlander" which is a Mitsubishi SUV?
I love the mechanic's notes on my ECU install:
Its a bit of a problem, because we originally flashed his car with MSah591UT, but that doesn't work on his car at all, then we flashed with ah581, which had bugs, so we ended up with ah580.
... Makes me really wonder what ECU/ROM combo I've got.. ;p
420WRX is offline   Reply With Quote
Old 08-11-2012, 12:27 AM   #805
candamo
Member#: 288732
2003 JDM STi
Had been fighting with the LC all afternoon. In the end it was the Speed Limiting (Fuel cut). If all the values are the same the LC wont work lol.
candamo is offline   Reply With Quote
Old 09-10-2012, 02:23 PM   #806
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Having some qualms with the Tinywrx patch. I set the MPH to 5 and my deltra rpm to 2300, that would put me around 5k with the stock rev limit. Flashed the map and it doesn't engage. Any ideas?
Subian is offline   Reply With Quote
Old 10-15-2012, 06:45 PM   #807
ShinjiML
Member#: 257231
2011 STI
Ok, after searching on multiple forums, including NASIOC, I can't seem to find much information about the error I'm getting.
So, I've renamed my ROM as A4SGC00C.hex and converted it 192kb, but when I try to apply the patch, it gives me the error:
ERROR: Source file is corrupt at byte 0x1fef0 (0xff expected, 0x3b found)!!
I've checked the ROM ID in ECUFlash and it matches (A4SGC001), the rom had previously been tuned by Vishnu, but it does not seem to be locked because I can still edit values.
The file can be opened in ECUFlash without a problem, but when I try to open it in RomRaider, I get the error: "Error - Data Mismatch Table: Catalyst Readiness Threshold Fix B Table editing has been disabled".
I suspect this may be the cause of the error, in which case does anyone know a way around it? Would it be ok to flash a stock rom and simply change all of the values over? Thanks.
ShinjiML is offline   Reply With Quote
Old 10-15-2012, 06:49 PM   #808
the suicidal eggroll
Member#: 51961
2005 STi
That's what I would do.
Old 10-15-2012, 07:18 PM   #809
420WRX
Member#: 27752
First hit on a Google search:
http://forums.nasioc.com/forums/show....php?t=2090393
And yeah they mention going with a stock and pasting over it with the tuner values.
Old 10-15-2012, 08:23 PM   #810
ShinjiML
Member#: 257231
2011 STI
Yeah I read that thread earlier today, but it didn't offer a more direct solution, looks like redoing the map is the only way. I was hoping I can just unlock the disabled tables for the catalyst threasholds.
Old 11-05-2012, 06:30 PM   #811
ShinjiML
Member#: 257231
2011 STI
For anyone else experiencing a similar problem, copying the tables over to a stock rom is the way to go. Stock roms for each ECU ID is available on the RomRaider forum.
Use the "Compare Roms" option in RomRaider to check which tables are different, copy all of the values over to the stock ROM and then save the rom. Use "Compare Roms" again to make sure you copied everything over correctly.
It might just be my imagination, but it seems like after adding LC, the car's low end response has improved, even when I'm just easing off from a stop.
Old 11-05-2012, 06:50 PM   #812
420WRX
Member#: 27752
Ahhh people notice motor changes from the most unrelated tweaks, it's nothing to get too concerned over as long as you know what the LC changed and that it's actually impossible for it to alter the responsiveness.
This isn't the thread to point this out in but your mileage with 'Stage II' as a description of your car mods might not be that ideal on these forums.
Either people will assume you've done more than you have, assume you've done less than you have, or just outright think you've done something wrong since you're still listing your mods as 'stages'.
Best to list your key mods in a blurb or save them for the dyno plot posts.
Old 04-26-2013, 02:56 AM   #813
GuilleSTI
Member#: 331237
2005 STI UK EJ207
Hello Friends NASIOC, I have a Subaru Impreza USDM WRX which I am looking to charge my ecu the Launch Control 16 Bit.
I use the Tactrix 2.0 with Ecuflash, The steps still do not know very well but if you know some tutorial would serve me a great help.
I'm making a map for Stage 2, but still can not find the Launch Control to patch it to my ecuflash.
Engine: EJ205AW3B9
ECU: A4SG900C
If you know any website where I can download?.
Thank you.
Best regards.
GuilleSTI is offline   Reply With Quote
Old 04-26-2013, 03:34 AM   #814
420WRX
Member#: 27752
Originally Posted by GuilleSTI View Post
Hello Friends NASIOC,....n download?.
Thank you.
Best regards.
I put that into Google translate and got:
'The thread is too many pages for the value of the info. If someone could spell it out for me so I don't have to read/learn that would be great.'
No disrespect, clearly this forum isn't your primary language, and it's a lot of reading for anyone, but this thread/forum has most of your answers.
This may help too: http://www.ecu-mods.com/LC_instructions.zip
Old 04-26-2013, 06:44 AM   #815
GuilleSTI
Member#: 331237
2005 STI UK EJ207
Because I'm from Spain and it makes it difficult to respond very well English so excuse me I translate. I will express myself better to facilitate the words.
Old 05-13-2013, 04:13 PM   #816
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
I patched it in to a stock 05wrx map and then used compare maps and copied everything from my tune over and then saved it as a new file.
Was simple and easy.
Edit. Also i kept my file at 160kb and everything works as it should. I set it to 4500rpm but may bump it up to 5k rpm
cosseywrx is offline   Reply With Quote
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
