Old 10-14-2012, 02:08 AM   #4876
BeefCurtains64
Member#: 251257
12 WRX
I have a 2012 subaru wrx. i want to have suspension and I would like to look for stock-ish ride height and something firm. Any recommendation ?? thanks
-Ty
BeefCurtains64 is offline   Reply With Quote
Old 10-14-2012, 02:38 AM   #4877
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
RCE yellows for something noticeably stiffer, but not too harsh. Blacks for a slightly stiffer than stock, but highly streetable ride.
flat4LGT is offline   Reply With Quote
Old 10-14-2012, 03:50 PM   #4878
Dratsum
Member#: 268562
2004 Wrx wagon
I was considering going with Racecomp Lowering Springs Subaru on my 2004 WRX Wagon with Koni inserts... Anybody use this set up? Like them / hate them?
Dratsum is offline   Reply With Quote
Old 10-14-2012, 04:24 PM   #4879
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
That is what I run and I love it . Don't get me wrong its firm but I normaly run the Koni's a little soft. It only has a hint of bounce over slow speed bumps like large speed bumps. If you do it from scratch I would also do the d Rex strut extenders .that is the only thing I regret is not doing that.
R-
labcoat is offline   Reply With Quote
Old 10-14-2012, 06:25 PM   #4880
Dratsum
Member#: 268562
2004 Wrx wagon
R-
Cool labcoat - Did the install go ok? I'm not clear on if I need to install anything else to make it work - chamber plates or what not.
Old 10-14-2012, 06:51 PM   #4881
Dratsum
Member#: 268562
2004 Wrx wagon
Or - there's this - I could just drop $500 and be done with struts and springs. (too bad I already put a bid in on the Koni's on eBay)
How's the drop / install on the wagon on the JDM v7 STi Shocks / Struts?
http://forums.nasioc.com/forums/show....php?t=2419740
Old 10-14-2012, 07:48 PM   #4882
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
I had help from a local guy and I wanted to keep things as simple as i could
Need is subjective. When I did my install I got whieline Com C front top hats new conical washers, and fresh rubber spring perches(the [art that goes between the strut and spring. Similar on the rear with group N and saggy butt spacers.
To we pre assembled the spring and struts and then putt it all in so we didnt' have to disassemble the stock set up to pull parts off.
Getting the fully assembled set up will make you like eraser but you will proab get 0.5" of drop just guessing.
The are are sedan struts so you will need to do something to get back some of the lost negative camber.
R-
Old 10-15-2012, 06:49 AM   #4883
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, UGM
Rotated EFR 6758
I can't find a definitive answer anywhere else, so I'm asking here.
Would STi lateral links and trailing arms work on my WRX? AFAIK the only difference would be the endlink connection which could be fixed by using a STi sway/endlinks?
Krang is offline   Reply With Quote
Old 10-16-2012, 10:19 AM   #4884
my name is joe
Member#: 171412
Any stu setups?
Kw v1coils
22mm sway bar frnt and rear
Cusco camber plates 2.2 camber 4.0 toe
White line endlinks.
Starspecs.
Not much more I can do before it becomes illegal
I feel like the rear needs to be bigger. Its still understeering a bit. But I'm scared that if I adjust it it'll spin me out. Anyone else have this problem?
my name is joe is offline   Reply With Quote
Old 10-16-2012, 12:34 PM   #4885
paukert11
Member#: 327666
02 slow psmwagon
02 bugeye wagon
spt suspension
white line 2point 22mm sways.
white line KLC31 kit
car handles great.
paukert11 is offline   Reply With Quote
Old 10-16-2012, 12:50 PM   #4886
oh_crap_its_him
Member#: 205434
2009 Toyota
MGM
03 TS Wagon:
Swift Wagon Springs
KYB AGX struts
Eibach camber bolts front and rear
KYB OEM replacement top hats
WRX rear sway bar
Whiteline end links
Whiteline steering rack bushings
DIY rear subframe mod
I need to replace the balljoints and outer tie rod ends next, but otherwise car rides and handles great for having 182k miles on it. The new suspension really tightened things up, and being able to adjust the struts for roadtrips when the car is loaded down really helps. The previous stock suspension was completely shot.
oh_crap_its_him is offline   Reply With Quote
Old 10-16-2012, 04:46 PM   #4887
draco159
Member#: 204121
2005 WRX Wagon
^tire size?
draco159 is offline   Reply With Quote
Old 10-17-2012, 02:40 PM   #4888
oh_crap_its_him
Member#: 205434
2009 Toyota
MGM
Originally Posted by draco159 View Post
^tire size?
Cooper Zeon RS3-A, 215/45r17's.
Old 10-17-2012, 03:07 PM   #4889
sd_wagon_07
Member#: 139820
2007 WRX Wagon Ltd
Clark Turner Tuned
R-
I run this setup as well and love it. I installed the dRex extenders too. These make the Koni insert sit lower in the strut housing so you'll need to cut the struts down a bit lower. For the rears, the lower spring perch gets in the way so you need to be a little creative with your cutting, but nothing that my Dremel couldn't handle. The factory top hats will still work but I upgraded the rears to GroupN and put RCE lowering plates up front for added camber and little more rake. My camber settings are -1.7 front / -1.4 rear and my Koni's are set to 1 turn up front and 1/2 turn in the rear (or something close to that).
sd_wagon_07 is offline   Reply With Quote
Old 10-21-2012, 07:56 PM   #4890
jhayesvw
Member#: 326502
2003 WRX Wagon
I know the saggy butt spacers will raise the rear of my car a bit to level out the suspension, BUT is there anything I can do to just drop the front about 1cm?
I like the height of the rear.
With the older VWs you can get what is called "lowering caps". they are the upper spring cap with a shorter center section that rides on the strut tower bushing.
is there anything like this for subaru? I havent even seen the top perches so Im not sure this is even possible.
I really like how my car rides but want it a little lower in the front.
Are there camber plates that drop the front a little? anything?
Thanks everyone.
jhayesvw is offline   Reply With Quote
Old 10-21-2012, 08:05 PM   #4891
BIGSKYWRX
Member#: 7958
09 GH B+
RCE camber plates would lower the front- in addition to more neg camber (and positive caster if you can't them)
BIGSKYWRX is offline   Reply With Quote
Old 10-23-2012, 02:04 AM   #4892
othon
Member#: 18440
2004 WRX Wagon
Always need moar grip!
Originally Posted by Beard_Of_Moses View Post
Hey, a bit of a suspension noob here with a 2004 wrx wagon. My current setup is what I bought the car with, stock struts and some brutal lowering springs. Long story short my stock struts are toast and the springs are way too low but still somehow soft enough to bottom out everywhere, I can only fit one finger between the tire and the fender and I scrape everywhere.
My priorities are having a higher car (slightly lower that stock preferably) but still be stiff for spirited driving/occasional track use. Coilovers are out due to road conditions here. What would the ideal setup be? OEM or aftermarket struts? what springs? Budget is $1100ish.
(also am planning on getting things like swaybars and strut tower bars in the future as money becomes available if that needs to be taken into consideration.)
Thanks for any help.
Edit:sorry if I'm unclear but I'm asking for both springs AND struts.
1.) Koni "yellows" Sport struts.
2.) Group N top mounts
3.) Camber bolts front and back
Or adjustable plates for more camber tuning. (prefered, but will add an extra bit of harshness/firmness)
4.) 500lbs (9kg) Front spring Max
5.) 550lbs (10kg) Rear Spring (yes I'm suggesting more then the fronts )
{{You dont need to run that heavy a spring, but its nice. just as long as you are either even or 50 / 100 lbs more in the rear then what ever rate you choose in the front}}
6.) I would normally suggest Swift, just not sure if they can make some up, Which I only say since they have done so for coil/race set-ups)
7.) Sway bars either stock or 21mm front and 24 - 27mm rear adjustable.
8.) All the whiteline bushings you can buy!! (not needed but will help a good deal!)
Do -2.5 front camber & -2 rear camber
0 toe all 4 corners
This a is a proven stable set up for nice windy mountain passes or technical courses that gives a driver a feeling of the back end slightly walking around or a bit of over-steer as most would know.
If you want it more neutral then dial down the rear sway bar a bit or down size it. Dont think the rear springs are too much because the wagon is a tad heavier in the ass. So with tuning the rear sway bar you can slightly adjust the extra spring weight with an adjustable bar or completely swap it out to a size smaller, if it feels like it really needs it.
Oh and Tire, Tires, Tires!!!
...and I can guaranty (relative to your style and driving ability of course) a fun time in your wagon!
othon is offline   Reply With Quote
Old 10-23-2012, 04:30 AM   #4893
wrx surfwagon
Member#: 262719
02 WRX
PSM with rust accents
9 and 10k?? He said he has bad roads, that stiffness is way more than average coilovers that he thinks are already too stiff
wrx surfwagon is offline   Reply With Quote
Old 10-23-2012, 09:37 AM   #4894
BIGSKYWRX
Member#: 7958
09 GH B+
your not going to find springs in those rates unless you go to a coilover setup- the firmest springs I'm aware of in a oe config are the STi Tarmac springs (which I ran w/ Konis on my 04 wagon)- they were 350/300-ish and actually not too bad w/ the Koni's daily driving
500# springs would be nice on a dedicated autox (or track) car, not for a daily driver
Old 10-23-2012, 10:10 AM   #4895
othon
Member#: 18440
2004 WRX Wagon
Your right your not going to find any spring that heavy in a OEM strut style. The set up that ran those springs where using a coilover kit like ground control and yes was more suited for the track and did extremely well compared to other cars funning $4000+ suspension.
Over all I wanted to share a general "big picture" view of a setup that works pretty damn well and when you consider that you could run lower spring rates (Like I mentioned ) as long as you run heavier in the rear and play around with sway bars a bit, it will be fun even for weathered roads / daily driver / occasional AutoX
Old 11-04-2012, 11:02 PM   #4896
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Looking to upgrade from an 18x8.5 on a 235/35 tire to an 18x9 with a 245/35 tire. Any suggestions on an offset and camber to run to stay as low as I am now without rubbing? I'm already at -2 degrees in the rear and -1.75 in the front.
Basically I want a wider wheel and a properly fitting tire while still being low.
Here's the current stance on BC coilovers.
Old 11-05-2012, 10:13 PM   #4897
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
With a lot of reading (largely the work of Big Sky-- thanks, Mike!) and gathering parts slowly over time I just finished up the suspension on my 02 wagon. It's completely rebuilt except for the rear wheel bearings
My threads aren't in-depth installs because I never get enough pictures along the way and most of us know the nuts and bolts by now, but I tried to cover the interesting parts and the results.
  • Koni yellow struts
  • RCE Wagon springs
  • Strut extenders
  • Com C front upper mounts and Group-N rear upper mounts
clicky for thread
  • GC STi aluminum front control arms
  • Energy Suspension front control arm bushing kit
  • Hotchkis hollow front swaybar and endlinks
  • Whiteline Roll Center Kit
Clicky for thread
Not shown in the threads above:
  • Hotchkis rear adjustable swaybar
  • Hotchkis rear endlinks
  • TiC/MSI rear lateral links
  • TiC trailing arm bushings (both ends)
Dentt42 is offline   Reply With Quote
Old 11-05-2012, 10:40 PM   #4898
BIGSKYWRX
Member#: 7958
09 GH B+
looks like a solid setup what did you end up for alignment #'s (if you've had it aligned yet)?
Old 11-06-2012, 07:16 AM   #4899
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Mostly stock .
About 1.2 degrees of camber on the front, and everything else is back to factory spec. I was running too much camber on the front for too long (ricer mistake! Bad monkey!), and have nearly ruined two tires.
So, because I have a long commute every day, I had the shop go all stock for now until I save up for new tires. I do have the Com-C front strut mounts set for max caster, though.
Old 11-06-2012, 08:17 AM   #4900
BIGSKYWRX
Member#: 7958
09 GH B+
-1.2 isn't too shabby if you have the caster dialed up
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 671 09-15-2016 09:50 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
