#2301 | ||
Member#: 316658
Vehicle:2012 Impreza limited 5dr silver |
Think about it, ALL models of Impreza with CVT get identical MPG rating. Doesn't that seem suspicious? The hacth and sedan have different cd (hatch has 0.33cd, sedan has 0.31cd) they both get the same MPG. There are 3 different tire/wheel sizes used on the impreza...they all give the same MPG? How about the sport model, they have the roof rails that adds extra drag...no MPG difference? How about the Limited sport model, it weighs 176 lb more than the base hatch model...no MPG difference. Doesn't it make you wonder how all these different impreza models are getting the exact same MPG? Is there not the slightest possibility that Subaru might have tested improperly, or made similar errors that Hyundai did? My understanding is that Hyundai made mistakes on feeding in data on cd, weight, rolling/coasting resistance data that's used to simulate real driving condition in a EPA testing environment on dynamos. Are you so confident that Subaru did everything correct?
#2302 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
Edit: stupid swype Last edited by flyboy1100; 11-04-2012 at 09:29 AM. |
#2303 | |
Member#: 316658
I don't think there was any claim that the little stub completely offsets the mpg cost of the adding the rails. Anyway, maybe all these things are within margin of error, or they are all fractions of mpg numbers so the don't ever show up when you look at each of these individually. But if you look at all the things I mentioned, the sum of all these difference has to amount to some MPG difference, yet we see NO DIFFERENCE. |
#2304 |
Member#: 299286
Vehicle:2012 Sport 5MT Green/Silver |
Do you think the EPA regrets moving from this label:
![]() to this one (generic version of the 2013 EPA label): http://www.fueleconomy.gov/feg/Find.do?action=bt1 |
#2305 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
Why would the EPA have regrets? How is the new label bad for the EPA?
#2306 | |
Member#: 299286
It deemphasizes that how you drive affects what you see, though this is in the small print of the new label (as it was before): "Actual results will vary for many reasons, including driving conditions and how you drive..." Some buyers seem to think the numbers on the EPA label are guarantees. They are not, they are guidelines. I think the older sticker was clearer. Ultimately it does not matter, Subaru neither gets to call the shots about how the car is tested for the EPA numbers, nor gets to decide what to print on the label as the EPA numbers. That all falls under the auspices of the EPA. |
#2307 | |
Member#: 314216
#2308 | |
Member#: 329526
SWIC
Vehicle:2013 Impreza Spt cvt Silver |
Excellent points.
#2309 |
Member#: 329526
SWIC
Thanks Flyboy. I just ordered a dozen vortex generators. Maybe I can get my usage down to zero.
*for Zeeper: ![]() |
#2310 | |
Member#: 301213
South East
Vehicle:2012 Imp. Sp. Ltd. Blue/Silver |
So based on the different wheels, roof racks, weight etc., let's say the most efficient version of Impreza gets 36.49 mpg in an EPA test and the least efficient gets 35.51. Rounding says they both get 36. If consumers really cared, it would be awesome to have actual road tests in addition to the calculated tests currently in place. Something like a "go around the Consumer Reports test track using 1 full tank of gas." In the end though, we're talking about maybe 10% +/- on MPG in the real world across most manufacturers. Honda is generally slightly above EPA while Subaru is below. Even if Subaru did fudge some numbers (intentional or accident) they sold thousands of cars and the vast majority of purchasers are happy. |
#2311 | |
Member#: 316658
The 2012 label has city thand Hwy both big, but manufacturer only advertise the hwy number. People only remember the hwy number and get dissapointed when they don't get it. |
#2312 | |
Member#: 315470
Vehicle:2012 Impreza LTD Marine Blue Pearl |
#2313 | |
Member#: 314216
#2314 |
Member#: 328414
Vehicle:2012 Impreza SP 5MT obsidian pearl black |
I drove up through North Jersey this weekend, and seeing those lines for gas, I am glad I get 400 miles to a tank. That being said, I averaged 33 mpg on that trip. This was mostly driving long stretches of country road at 50-55 mph.
The EPA tests are based on the old tests to deal with Los Angeles smog. "City" is to recreate driving through LA streets, averaging 20 mph. "Highway" is an average drive on the 405 freeway (back when you could drive on it) at 50 mph. These tests were adopted into the CAFE laws, and as such do not represent real life for most people. If you drive like the test, you will see these numbers. |
#2315 |
Member#: 329526
SWIC
Lots of BS ricocheting around here - more than I've ever seen in a forum. Plants (?) Not that everyone who posts inaccurate info is a plant, there's just a lot of not checking out info - mostly posted by people who repetitively spew nonsense.
flyboy1100: http://www.fueleconomy.gov/feg/Find.do?action=bt1 "The Combined City/Highway estimate is the most prominent to allow quick and easy comparison to other vehicles" foghelmut: What makes you think the EPA tests from post 2008 are bason no the old tests to "deal with Los Angeles smog"? I don't follow that. Got a link to prove it? Last edited by stevehnm; 11-06-2012 at 06:48 AM. |
#2316 | |
Member#: 314216
http://forums.nasioc.com/forums/show....php?t=2427586 |
#2317 | |
Member#: 329526
SWIC
#2318 |
Member#: 442
Vehicle:2013 Crosstrek XV 00 Honda S2000 |
You CVT drivers, what RPM is the engine at doing 70? 75?
Thanks. --kC |
#2319 | |
Member#: 323103
Vehicle:2012 Limited 2.0i Dreamy Gray Mistress |
Enough he said/she said please. Who argues on election day?
![]() Quote:
Average MPH: 38-40 Trim: Limited |
#2320 | |
Member#: 328414
I read it on another forum, no direct source. |
#2321 | |
Member#: 318301
Vehicle:2012 CVT Sport Prem Ice Silver Metalic |
Average MPG: Right around 34.5mpg calculated lifetime average (highest was 37.x lowest was 32.x) Average MPH: 38 to 42 depending on traffic conditions Sport Premium with CVT. IF I could drive speed limit my commute looks somthing like this: 1 mile @30mph with 3 stop signs and a stop light 10 miles @65mph 22 miles @60mph 2 miles @30mph 1 stop light and 1 stop sign. So you could say 90% highway, BUT that 22 miles @60mph has lots of stop-n-go traffic and road construction. So I'd call it closer to 65% highway. I'm looking forward to no road construction in about 2 years. Yes there are 3 different tire sizes, but the outter circumfrence is nearly identical on all of them. Last edited by jd_24; 11-06-2012 at 02:31 PM. Reason: typo |
#2322 | |
Member#: 318301
I didn't get a chance to try 75mph. Approx. values are: 60mph = 1850rpm 65mph = 2000rpm 70mph = 2200rpm All were on the flatest roads I could find with little to no wind. I tried to keep the speed and accelerator constant. A slight push of the accelerator or a slight incline can cause the values to increase 1 to 2 hundred or so. 2012 Sport Premium with CVT. Everything is stock. |
#2323 |
Member#: 103208
Vehicle:2011 Outback Azurite Blue |
i don't get why our last impreza was rated at 28 mpg, and my wife averaged about 29. but with the new '12 rated at 36mpg highway, she averages about 33mpg.
edit: so i guess ours is normal. just doesn't seem right though |
#2324 | |
Member#: 316776
Vehicle:2012 Impreza hatch Silver |
#2325 |
Member#: 315631
Vehicle:2012 Impreza |
today i was in a rush to get home. the only time i had ever speed in this car. i usually hyper mile and get 36-40 mpg. but today was a whole other story. anyways, at 85-95 mph i average 25-28 mpg. am i surprised? no, not really. i know i was reckless, but it was the first and only time. i have over 15K in 6 months so i drive alot, it was just this one time.
on a related note, the car still felt there was some power left at 95 mph. but i am usually the guy people pass on the freeway doing 60 mph while the speed limit is 70. |
| Thread Tools | |
| Display Modes | |
| New Impreza owner, low mpg? | stuffedcabbage | Newbies & FAQs | 34 | 09-25-2012 10:10 PM |
| 2012 Impreza Reviewed - Whytecliff to Seymour | brendan_mac | Vancouver Impreza Club Forum -- VIC | 16 | 12-23-2011 01:12 PM |
| NJ Impreza owners - sighting | Dan G | General Forum Archive | 76 | 10-06-2000 12:24 AM |
| Md or Va Impreza owners - I have an Impreza related question. | Snoopy | General Forum Archive | 1 | 06-05-2000 08:08 AM |
