Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 03-15-2012, 09:11 PM   #26
DarkProphet
Member#: 299707
2011 Wrx 5-Door
Originally Posted by wapam View Post
Do you have a picture of your H/U that this works on?
I think this is the unit with the 4.3" screen
DarkProphet is offline   Reply With Quote
Old 03-15-2012, 09:53 PM   #27
rickrobin
Member#: 306993
2012 Impreza Ltd.
Ice Silver Metallic
Default To WAPAM and Scoob_Noob
Wapam, see the bottom-most pic in SVXDC's reply, #13, to this post: http://forums.nasioc.com/forums/show....php?t=2298834
(Lateralis's post "2012 STi Stereo Build with OEM NAV H/U).
Scoob - The settings effect the preamp section of the HU, regardless of input source.
rickrobin is offline   Reply With Quote
Old 03-15-2012, 10:28 PM   #28
wapam
Member#: 258373
Thanks rick, I thought it was that one but hoping it was the one above!!
wapam is offline   Reply With Quote
Old 03-16-2012, 01:56 PM   #29
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Originally Posted by rickrobin View Post
(PF-3391A-A/CM631UD). Thanks very much, Rymar!
Key in ACC position, radio off: Hold preset button #6 while spinning the right adjust knob 4 or 5 notches; release button, then repeat. Now you're in the adjustable presets pages. Spinning the knob or hitting the "back" button will bring up loudness, EQ, and screen brightness settings, which can be toggled with the knob.
Here's the basic setting I arrived at that makes this thing almost sound good: Loudness and EQ both OFF. Back in the regular tone control: Bass -2, Treble +5.
The main problems with this system are that the bass is boomy, and the midrange is attenuated at some very peculiar frequencies. And the frequency where the mid tone control is set makes it useless altogether - leave it flat. As for SRS Labs, no (printable) comment. (I was a sound pro and studio musician in NYC for many years, so I might be, y'know, just tad picky!)
This setting will give the most natural balance generally, and make the mids sound as close to natural as the unit will allow, especially when you turn up the volume. Now you can adjust the bass and treble slightly as needed per tune, i.e. use the tone controls normally - assuming you've defeated the &^%$# motion lockout (see my How-to post).
It's just unbelievable what you have to go through to use your own freaking car radio, I have to say.
Just for the record, this does not work on the cm621ub, which is the premium H/U with stock tweeters. Tried a bunch of different button combinations, but to no avail. Anyone know if the lower model H/U's have this baseline EQ adjustability? I'm thinking I may have to upgrade to NAV now that I know all the ins and outs of that system from this forum, lol.
riccnick is offline   Reply With Quote
Old 03-29-2012, 01:31 AM   #30
wapam
Member#: 258373
Originally Posted by SVXdc View Post
Which HU model do you have (number printed on the front, and rear if you've looked)? I'd like to start tracking which models this works on.
That TSB mentions these 2011 HU models:
Impreza -- CZ624U1 -- 86201FG620 -- PF-3292A-A
Forester -- CP625U1 -- 86201SC620 -- PF-3297B-A
Rymar's HU with the 4.3" screen is CM631UD -- 86201FJ630 -- PF-3391A-A
riccnick's HU is CM621UB -- 86201FJ620 -- PF-3386A-A
Numbers are: Front ("discrimination code"), Subaru P/N, Clarion model #
In some cases, you can look up the FCC ID here and see interior photos and other interesting info. But some only show the Bluetooth sub-assembly and not the HU.
I'm confused, is this a list of the H/Us that allow you to turn off the factory EQ?
Old 03-29-2012, 03:49 PM   #31
Scoob_Noob
Member#: 308149
2012 WRX 5-door
WR Blue Pearl
Originally Posted by DarkProphet View Post
yeah, thats all I found along with:
press 5+6+Down Arrow and you can change the backlighting
2012 Base HU CZ624U1
I get the same results. I can't find any other submenu besides the backlighting and key one. I can't figure out how to turn off Loudness and EQ. Is that possible on the base head unit?
Scoob_Noob is offline   Reply With Quote
Old 03-29-2012, 07:25 PM   #32
FugitiveChris
Member#: 299017
2011 Impreza STi 5DR
Dark Grey Metallic
If you don't have the 4.3" screen radio then I think your beat as of right now. To my knowledge the eq/loudness menu were only discovered for that model.
FugitiveChris is offline   Reply With Quote
Old 04-03-2012, 09:08 AM   #33
masterforce
Member#: 221580
2011 WRX STI
looks like mine should work. gonna try this today. good info tho!
masterforce is offline   Reply With Quote
Old 04-04-2012, 09:27 AM   #34
scrmnws6
Member#: 287515
2011 WRX Limited
Stage I
What are the hidden menu's in the navigation model?
scrmnws6 is offline   Reply With Quote
Old 06-10-2012, 03:58 PM   #35
curbach
Member#: 321437
2012 Impreza Sport
Obsidian Black Pearl
This was very helpful. Thanks, rickrobin. With the Loudness and EQ off I still can't say the stereo actually sounds good, but it is at least not offensively ear-gratingly bad now. I'm using different tone control settings than rickrobin, but that's kind of like salting to taste (and I think he's right about the midrange tone control ) Sidenote: my car came equipped with the "upgraded" Kicker speaker set with tweeters, no subwoofer.
To be clear for those attempting this, each push of the "6" button combined with turning the right dial (note: I had to turn the dial more than I expected based on rickrobin's description, so just keep turning until something happens) puts you into a different service menu. First menu shows various settings and specs, nothing to adjust. Second menu shows Loudness on/off and if you push the right dial you will cycle through several other screens that mostly seem to be related to the screen display, and none of which seem to be adjustable. The third and final service menu contains the EQ on/off.
curbach is offline   Reply With Quote
Old 06-11-2012, 04:01 PM   #36
killeraxemannic
Member#: 322111
2012 Base WRX
Dark Grey
I have the CZ624U1 in my 2012 WRX and I would agree it sounds awful. I got the Kicker trunk sub with the crossover for the speakers and I don't think it helped at all.
I was hoping this would work for my unit but it did not. As someone else stated the only menu I found on it is the one pressing 5+6 and text to get firmware versions and pressing 5+6 and the up key to get the menu that says "key" on the screen but does not seem to have any additional functions.
killeraxemannic is offline   Reply With Quote
Old 11-06-2012, 02:38 PM   #37
wondras
Member#: 337076
2013 XV Crosstrek
Post Success! Loudness and EQ disabled on CM621UB
YES, WE CAN!
I just picked up a 2013 Crosstrek with the CM621UB HU. (Do I get partial credit for having most of an Impreza?) By piecing together info from various posts here, the service manual, and documents filed with the FCC, I figured out that it *is* possible to disable both the loudness and fixed EQ.
To turn loudness on or off:
With the unit ON, press and hold 1, 6, and TUNE (right knob.) The display shows LOUD OFF or LOUD ON.
To disable fixed EQ:
With the unit OFF, press one of these combinations of buttons:
1 + 2 + TUNE for SEDAN
1 + 3 + TUNE for WAGON
1 + 4 + TUNE for THROUGH MODE
With these "features" disabled, it sounds significantly less awful, especially at lower volume levels. This should make it a much better candidate for use with upgraded speakers, or a line out converter and amps. From the schematics, I think it would be fairly easy to add proper RCA line outputs as well.
I don't know if these keys will work on earlier models, but hopefully they do.
Fantastic forum you've got here!
wondras is offline   Reply With Quote
Old 11-06-2012, 05:03 PM   #38
jandree22
Member#: 100800
This works on the CZ624U1!!! Thank you!
jandree22 is offline   Reply With Quote
Old 11-06-2012, 05:55 PM   #39
JohnNevets
Member#: 331193
2012 Impreza
Camellia Red Pearl
This got me curious, so I thought I'd put my 80's arcade fighting game skills to work and mash some buttons too. Here is what I found on my CM621UB.
I can confirm what has been said before by Wondras, and add a few more. Most do nothing, but I thought it would be worth documenting.
2+4+cd= mic test (mic plays out speakers, I'm guessing this is a diagnostic tool to verify it is working)
3+6+cd= time chk (I'm clueless, and I could not get it to change anything)
3+6+text+text=USA (Guess what country I bought this car in.)
4+6+cd+cd=59m Jump (Once again, I have no clue, maybe something to do with the CD player?)
I was also able to get into what I assume is the EQ through a different combination.
3+4+Tune=Sedan, 3+5+Tune=Wagon, 3+6+Tune=Through Mode (Through this combination I only seemed to get to Through Mode after I had "Sedan" on the screen, but I'd like someone else to confirm that)
Well, that's it for me, hope others can take the lateral and run a bit further with it, or at least give some insight into some of what I found.
The one thing I thought of as I was writing this, is that I didn't mash the steering wheel buttons when testing this out, there may be more hidden under those.
Have Fun,
John
Last edited by JohnNevets; 11-06-2012 at 05:56 PM. Reason: Need to proffread before posting.
JohnNevets is offline   Reply With Quote
Old 11-06-2012, 06:14 PM   #40
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Did you find a way to change the default hands free volume? With the amp I added, level 6 is way too loud.
I have a hu from a forester now, but I'm going to try this tonight! through mode =eq off?
Old 11-06-2012, 06:22 PM   #41
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
wondras and JohnNevets, you guys are awesome!
lymphomaniac is offline   Reply With Quote
Old 11-06-2012, 07:13 PM   #42
dsn112
Member#: 332561
2015 GTI Autobahn
I have this issue too, super annoying
Old 11-06-2012, 09:14 PM   #43
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Definitely like the eq off, undecided on loudness.
Old 11-06-2012, 09:41 PM   #44
Ultimateone
Member#: 48025
24 FL5 CTR
Champ White
of course this happens after I bought a new head unit, lol damn it
Ultimateone is offline   Reply With Quote
Old 11-06-2012, 10:03 PM   #45
redline23
Member#: 285799
2012 WRX 5-Door
This is much better. Thank you so much. I would buy you guys a beer if I could
redline23 is offline   Reply With Quote
Old 11-06-2012, 10:35 PM   #46
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I am leaving loudness on.
I am running the forester hu (looks identical, but has satellite), kicker tweets, stock speakers, alpine ktp445u, eq off, loudness on, bass +5, mid +2, treb + 6 and I am pretty happy with the results.
Might not even put in New speakers now. Mids are not nearly as muffled, and bass isn't as boomy.
Old 11-07-2012, 09:08 AM   #47
TravisM
Member#: 295506
2011 Impreza 2.5i Pr
Dark Gray Metallic
Track up or down on steering wheel controls while in a call.
TravisM is offline   Reply With Quote
Old 11-07-2012, 09:13 AM   #48
Angelus911
Member#: 89967
2020 Volvo S60
Gray
thanks for this, can't wait to try this on my Sport Premium today!
Old 11-07-2012, 09:19 AM   #49
claythrow
Member#: 283663
2004 STI
Root Beer
RickRobin, what EQ frequencies does it give you and where do you live. Ideally you would use a combination of eq and afterwards B/M/T to get the right sound. I have an RTA and live in MA and would he happy to get together and adjust it for you but I have no idea where you live. Probably HI lol
claythrow is offline   Reply With Quote
Old 11-07-2012, 11:11 AM   #50
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have an amp, level 6 which is default when it rings distorts the crap out of my speakers.
Level 2 is perfect
2011+ Impreza head unit into 2009? codingparadox Car Audio, Video & Security 6 12-31-2011 12:48 AM
2011 Stock Head Unit Audio Playlist Options cheezmunky Car Audio, Video & Security 2 12-02-2011 10:09 AM
WTB : WTB - non-navi 2011+ OEM Head Unit with Bluetooth. ofspunk7 Private 'Wanted' Classifieds 2 10-25-2011 12:40 PM
2011 STi head unit w/o nav RCA PORTS? sk8dc10 Car Audio, Video & Security 5 11-06-2010 10:01 PM
2011 stock head unit wiring question subiebosch Car Audio, Video & Security 10 10-08-2010 09:21 AM
