Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 09-28-2012, 02:34 PM   #1
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
Default RUTROW, No 5v to crank/cam on a 20k
So she just died, on the road( v4 ej20k swap). Got it back to the garage, no wave pattern from crank/cam sensor. No 5v from ECU pin 9 connector b136. I think the ecu went sizzles, but want to check if anyone else here had this problem?
wrxr4ti is offline   Reply With Quote
Old 09-28-2012, 04:22 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
both the cam and crank have nothing?
Old 09-28-2012, 04:37 PM   #3
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
yep nothing out of the ecu, and about .1 ohms from the sensor 5v and signal back to the ecu. I know im screwed. Just seeing if anyone has seen something funny like this. Or had any luck robbing 5v from another sensor to power up the cam/crank
Old 09-28-2012, 04:38 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
you may have a loose ground on the intake or a cut somewhere, I wouldn't freak out so quick
Old 09-28-2012, 05:50 PM   #5
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
Update. pulled maf off......revs up now...and the quest for a JDM part happens again. Does anyone know of a Nissan model that uses the same maf?
Old 09-28-2012, 05:55 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
none directly.
buy an esl board for your ecu and either ditch the maf or use another unit, like a z32 or q45
Old 09-29-2012, 10:57 AM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can order a new orange EJ20k maf from any US subaru dealer, the part number is 22680aa271, it's a little over $300. You can find them used on ebay uk or yahoo japan auctions. I'd do new, who knows how long used will last, they aren't that reliable to begin with.
Old 10-02-2012, 05:23 PM   #8
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
just ordered a new on from The dealer, thanks everyone'
Old 10-09-2012, 08:17 PM   #9
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
so Still having problem. can I get someone with a 20k to verify for me the b136 pin needs to have 5 volts to the cam and crank sensors with key on engine off or just tell me what you have out at the cam sensor for voltages?
Old 10-09-2012, 08:56 PM   #10
pmugabi
Member#: 280926
I don't have a K anymore. However when I was re-wiring it to use an EJ20G ECU, I made a spreadsheet of all the ECU pins to assist in the pin re-assignment. The cam and crank +ve 5V is as below, so you're checking the wrong pin. If the car has an immobiliser, the cam and crank +ve are swapped around. The signals are only generated when the engine is on/cranking.
Cam PS +ve B136-8
Crank/Cam -ve B136-9
Crank PS Sig +ve B136-10
pmugabi is offline   Reply With Quote
Old 11-06-2012, 03:15 PM   #11
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
"over night parts from Japan if we need them....." Well not to over night but a Brand new V4 MAF did the trick.
