Old 11-06-2012, 04:32 PM   #1
M45
Member#: 333446
2013 Impreza SL CVT
Default steel wheels for 2012/2013 imprezas
Has anyone bought any steel wheels that they like yet? How are the tirerack ones? Are they hub-centric or do they center on the studs? I'd like to have the wheels fit in a stock manner.
Old 11-06-2012, 05:41 PM   #2
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Loot at the required offset @tirerack and then go back in time to research Outback, Legacy, and Impreza's that have the same specifications. After you have accomplished that, go to a junk yard and buy them used - a lot less costly. The used ones can be blasted and painted and look brand new.
Old 11-07-2012, 05:59 AM   #3
M45
Member#: 333446
2013 Impreza SL CVT
not a bad idea.
Old 11-07-2012, 11:56 AM   #4
gravitylover
Member#: 334328
2013 XV Crosstrek
Khaki
I am starting to see wrecked 12's showing up in salvage yards by me already. I stopped at one the other day and he wanted $500 for wheels with tires
gravitylover is offline   Reply With Quote
Old 11-08-2012, 12:24 AM   #5
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
For the 17" gunmental sport rims with OEM Yokohama AVID S34D?
Old 11-08-2012, 08:48 AM   #6
gravitylover
Member#: 334328
2013 XV Crosstrek
Khaki
No, basic steel wheels from a base model sedan. I thought about it after I made that post and I guess with the TPMS sensors it's actually worth the price.
Old 11-08-2012, 11:59 AM   #7
Omie
Member#: 331611
2013 Wrx 5dr
i bought a set of 16" steelies and winter tires from tirerack about 2 months ago. the only thing extra i bought was extra tpms sensors for the steelies. i put my steelies on a day before day hit us in ny. i paid liek 750 shipped to my door and they were here next day. they also came with open ended lugnuts with the package as well. They mounted and installed the sensors and all i had to do was throw them on the car and reprogram the sensors
Omie is offline   Reply With Quote
Old 11-08-2012, 12:01 PM   #8
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Outback 15s work nicely.
Old 11-08-2012, 12:38 PM   #9
M45
Member#: 333446
2013 Impreza SL CVT
so $750 including wheels, snow tires, TPMS sensors?
how do you reprogram the sensors on our cars? is there a way to do it without a special tool/device?
Old 11-08-2012, 12:39 PM   #10
M45
Member#: 333446
2013 Impreza SL CVT
what year?
Old 11-08-2012, 01:23 PM   #11
Commander Keen
Member#: 319157
what year?
Mine are from a 2001.
Old 11-08-2012, 06:08 PM   #12
Jmzda
Member#: 313812
2012 Impreza 2.0i Pr
Dark Gray Metallic
Which snow tires did you pick? The steel rims w/ sensors for all 4 on tirerack is $376 w/o shipping. Are you happy with the tires you picked? Were they good in the snow?
Old 11-08-2012, 06:25 PM   #13
kenny doggins
Member#: 326540
2012 Impreza MT SP
if your tpms is the correct (subaru) frequency, it works without any programming.
kenny doggins is offline   Reply With Quote
Old 11-08-2012, 10:43 PM   #14
BajaGuy68
Member#: 127720
2012 Impreza Premium
Ice Silver Subie
I bought 16" steel rims to mount winter tires on and save the 17" factory ones for the summer. I paid $70 each from a local dealer.....no TPMS sensors, so I'll have to put up with the light on through the winter.
BajaGuy68 is offline   Reply With Quote
Old 11-09-2012, 02:00 AM   #15
Omie
Member#: 331611
2013 Wrx 5dr
yea it was everything the tires i got were the general altimax artics i had them on my last honda and they were great on a front wheel drive car. So I went with the same tires on the subaru. As far as the sensors goes, i have a buddy of mine who reprogrammed them for me but you can get them without the sensors and use your own but I just said screw it and bought new ones
Old 11-09-2012, 04:27 AM   #16
pkL
Member#: 313093
2012 Impreza 2.0i
I thought you had to go back to your dealership to get the TPMS reprogrammed?
Old 11-09-2012, 06:11 AM   #17
M45
Member#: 333446
2013 Impreza SL CVT
they don't need to be keyed to the car or anything? what if i'm driving along next to another subaru??
Old 11-09-2012, 07:17 AM   #18
Brian Vantana
Member#: 314834
2012 Impreza
Dark Metallic Grey
Are TPMS 100% necessary for steel rims? Will it just throw up and error light?
Brian Vantana is offline   Reply With Quote
Old 11-09-2012, 08:19 AM   #19
ans2k
Member#: 315631
2012 Impreza
necessary is debatable and subjective. without them you will have a "(O) " light on your dash.
Old 11-09-2012, 09:01 AM   #20
M45
Member#: 333446
2013 Impreza SL CVT
on some cars this is more annoying than others. does the impreza "ding" at you or anything or is it just the light?
Old 11-10-2012, 12:31 AM   #21
Commander Keen
Member#: 319157
There's no noise, just the light. It blinks slowly at first, then stays on.
Old 11-10-2012, 12:40 AM   #22
von Wachtstain
Member#: 52726
16 inch steel wheel from Tirerack with Bridgestone Blizzak.
von Wachtstain is offline   Reply With Quote
Old 11-10-2012, 12:40 PM   #23
BoxerSport2.0
Member#: 308400
2012 Imp Sport Pr.
Dark Gray Metallic
Default 15" Base OEM Steelies & Blizzak's
I have a '12 Imp Sport. I lucked out at a local dealership, someone had just bought a 2012 Base Impreza and chose different wheels to put the stock tires on than stock so the dealership had the steelies them laying around. I'm purchasing them for $40 a wheel then buying TPMS sensors & bought 195-65R-15's from Tire Rack. This way I don't have to worry about hubcentric rings or (O). I'd call your local dealership and see if you can get a deal.
-Brian
BoxerSport2.0 is offline   Reply With Quote
Old 11-10-2012, 02:32 PM   #24
hanta20
Member#: 320594
2012 Impreza Limited
Dark Gray Mettalic
Do you have any other images of the car with the steel wheels on taking further back (ie. so you can see the whole side profile of the car with the wheels)???
hanta20 is offline   Reply With Quote
Old 11-10-2012, 05:00 PM   #25
hanta20
Member#: 320594
Dark Gray Mettalic
any other places to buy steel wheels than tire rack that will fit 2012 impreza?
Message Board Statistics All times are GMT -4. The time now is 08:49 PM.
