Old 11-06-2012, 10:49 PM   #3676
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by 2011rex18 View Post
All the different exhausts you go through, can I have one lol! Ill be sure to test it out thoroughly for you
Haha! I don't pile them all up. They're all traded or sold prior to getting a new one. I have a stock one that I swap back to. I honestly think I've probably spent close to $0 on exhausts since the first one. I just stay on the lookout for deals and trades.
Old 11-06-2012, 11:07 PM   #3677
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My project for the night:
Old 11-06-2012, 11:12 PM   #3678
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
Haha replaced the digitizer. I manage a Smart Phone Repair Shop so I do this all day long. Mainly iPhones and iPhone color conversions though. Fun work haha.
thatsilverwrx is offline   Reply With Quote
Old 11-06-2012, 11:21 PM   #3679
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, it wasn't too bad, but I redid it 4 times to try and get rid of all the dust. I used a microfiber cloth and a rocket blower, but there always seemed to be a few small particles. I was using a flashlight to spot the dust, but there always seemed to be a few. I felt like I needed a clean room to do it. Maybe just a humidifier or something would have helped.
Old 11-06-2012, 11:24 PM   #3680
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
Yeah it's tough to get zero dust you have to do it quick and it helps to use a can of air/air compressor and a few clean micro wipes with you. sometimes windex helps too.
Old 11-06-2012, 11:27 PM   #3681
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I suppose I could have tried canned air. I usually avoid that and stick to the Rocket blower for my photography stuff, so I didn't even think of it. But after 4 tries it's pretty much perfect. I did notice a slight "defect" in the lamination of the screen (bottom left corner of the last photo), but I suppose that's what you get with a cheap Chinese knock off.
Old 11-06-2012, 11:39 PM   #3682
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
Ahh, yeah. Our shop buys real replacements. it's better to have a satisfied customer that's not going to need to come back because the knock off eBay part stopped working -__-
Old 11-07-2012, 07:03 AM   #3683
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
I have T-Mobile but I'd still trade my crappy broken hand-me-downed G1 for anything >_>
Navendra94 is offline   Reply With Quote
Old 11-07-2012, 08:05 AM   #3684
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I used some 2mm wide, double sided tape to hold the screen on and it's not sealing the whole way around. I can already see dust get back in. I just ordered some pre-cut adhesive and I'll have to redo it once it arrives. I didn't realize you could buy the pre-cut stuff, most of the things I read just said to use the tape. A good screen would probably come with the adhesive already attached.
http://www.ebay.com/itm/US-NEW-Adhes...-/350629966558
Old 11-07-2012, 08:41 AM   #3685
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Things are getting slow with the car huh, lol. Well done sir.
INKMAN is offline   Reply With Quote
Old 11-07-2012, 11:40 AM   #3686
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
For most droids the screens do come with the adhesive so they slap on. we also use plastic clamps and heat up the edges slightly to form a real solid seal. if your ordering strips, use 3M.
Old 11-07-2012, 11:44 AM   #3687
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'll try not to let it go more than a week or two without doing anything...
Ah, well I must have just bought a crappy screen then. The thin tape I bought was 3M, but it was hard to work with simply due to the small size. The lack of a good seal was purely due to my installation not getting full coverage on the tape. I ordered that adhesive in the eBay link, so hopefully it's not crap.
Old 11-07-2012, 12:49 PM   #3688
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
Shouldn't be too bad. After you apply the tape though, try letting something heavy sit on the top the press the glass into the frame for a bit, maybe 15 minutes or so. Use a hair dryer to really melt the new glue and then put pressure on it (I use plastic clamps) It'll really seal the glass into the plastic and stop anything from coming in. But seriously, make your car faster or something, it must be getting boring . Kidding tho, but back to the car. Do you think your turbo is one of the best quick spool, stock locations, easy to set up turbos there are? I have a while to go before I do a bigger turbo, but it's always nice to have an idea. I'm always back and forth between yours and rsuttons turbo.
Old 11-07-2012, 12:52 PM   #3689
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
Don't they both have the same turbo?
Old 11-07-2012, 01:24 PM   #3690
thatsilverwrx
Member#: 307725
2012 WRX
Now 2015 WRX
No, xluben has the 20G-XT-R and rsutton has the Dom 1.5.
Old 11-07-2012, 01:54 PM   #3691
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This is correct. They are very similar turbo's. The difference is a 68mm compressor vs a 71mm compressor.
They're both really good options. I'd probably go with the Dom1.5 XTR though. It seems to spool about the same, but it can make a little more on the top end if you really push it.
Heat and pressure were two things that I definitely did not use when I put it together. The real trick for me is trying to avoid the dust during assembly...
Old 11-07-2012, 04:14 PM   #3692
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
Hey X, My trans is currently at andrewtech getting buillt with the PAR straight cut gears. How are they holding up? If you could shoot me a txt @ 757-619-0931 so i can ask you some questions.
Cheers
wrxtuner13 is offline   Reply With Quote
Old 11-07-2012, 04:36 PM   #3693
climbhigh09
Member#: 254163
2011 WRX 20GXTR
Hah... I have 4 exhausts sitting in my garage right now, if you count the one on the car. You looked into the Fujitsubo catback exhaust?
climbhigh09 is offline   Reply With Quote
Old 11-07-2012, 09:21 PM   #3694
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Cheers
Are you going with 1-4 straight cut? I only have 1-2 straight. They're a little noisy, but I like them.
Input shaft (with straight cut 1st and 2nd), 2nd gear, and 3rd gear synchro cone from PAR.
Gears assembled into the case. Didn't take any photos of the synchros before install.
Case halves assembled. 5th gear is exposed. Ready to close it up.
Which ones do you have? Thoughts on each? I haven't looked into that on much. Overall the design looks very similar to the Greddy SP Elite, but the tips aren't as pretty.
Old 11-07-2012, 10:25 PM   #3695
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
So siiiick! Can't wait for my set!
07wrx84 is offline   Reply With Quote
Old 11-08-2012, 07:01 AM   #3696
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
I bought the straight cut 1-4. Yeah, I'm ready for the noise
Old 11-08-2012, 09:56 AM   #3697
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That should be fun
My straight cut 1 and 2 don't seem as loud as PPG's, so maybe the PAR 3 and 4 won't be too loud...
Old 11-08-2012, 11:20 AM   #3698
climbhigh09
Member#: 254163
2011 WRX 20GXTR
Run of the mill stuff. Stock, SPT, Q300, Nameless. Going to have the Fuji by next week it sounds like.
Stock is too quiet, Nameless and Q300 are too loud on the highway, SPT is going on tonight. Have to cut the Fuji to ship it reasonably, so that sucks. I'm going to weld flanges on to make it easier to trade.
Old 11-08-2012, 11:24 AM   #3699
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Which version of the Nameless? How does it compare to the SPT?
That is really lame that you have to cut the Fuji. Just get a big box!
Old 11-08-2012, 11:27 AM   #3700
low-n-slow
Member#: 313818
2002 wrx hybrid
In my opinion, its hard to beat the whine of helical/straight cut gears
low-n-slow is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
