#1 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Here is my latest setup
![]() Event: Road Dyno Location: Simpsonville, SC Ambient Temp: 60 Elevation: 1000 Weather: clear Track and Conditions: asphalt, clean, flat Tires: 215/45r17 summer tires Car: 07 WRX TR Tuner: Me Dyno Info: VD Transmission: 2011 STi Gear: 4rd Peak HP at RPM: 489whp @ 7351 RPM Peak Torque at RPM: 447wtq @ 4800 RPM Target Boost: 27psi tapering to 25 Target AFR: 11-11.5 Fuel: E85 Engine/Power Modifications: Wiseco forged pistons, 08+ STi rods, king bearings, BC 272 cams, stock valvetrain, Fully ported heads, FP Black IWG 9cm2, Hyperflow TMIC, Perrin headers, Perrin uppipe, Buschur Racing TBE, Hallman MBC , TGV deletes, phenolic spacers, , Walbro 460lph, Air Pump deletes Other: Low timing ![]()
#2 |
Member#: 81102
MWSOC
Looking good, bro.
#3 |
Member#: 152576
SWIC
Vehicle:2006 STI 10.8@ 129 www.Mayhemtuning.com |
finally grew some balls to post results
![]() Good stuff man! cant wait to see results! ![]() ![]() |
#4 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
How's the 6 speed?
#5 |
Member#: 108163
Vehicle:2005 STI - 10.8@129 more in the works! |
builds boost early for a turbo that size, nice!
#6 |
Member#: 132587
Vehicle:2006 JrTuned STi E85 GT3582r/10.83@126mph |
Nice, when do you think you will go to the track?
#7 |
Member#: 278519
SCIC
Vehicle:KBiz KeeganLB 30rSTI phatron tuned |
noice!!
3 pretty fast cars in these last 3 posts, lol + reno's 2 post above that juan, you should ditch those skinny stock tires with some 225-245's ![]() |
#8 | |
Member#: 133146
Thanks Carmi
... CoryI don't like the extra weight but it shifts better. The car feels like it handles way better for some reason; at least I don't have to worry about another transmission breaking ![]() Yeap! a 68lb/min turbo hitting 27psi by 3960rpm, 20psi by 3740rpm, 15psi by 3500rpm ![]() Probably next year but I will go on kill mode, I am only running right now 21.5* of timing at redline which is 7500rpm. Thanks, so far I don't have any traction issues. I will get some better tires in the future. |
#9 |
Member#: 108163
#10 |
Member#: 25768
RMIC
Vehicle:35R bugeye Awdsome |
Looks real good. Thing spools real nice.
#11 |
Member#: 177861
NWIC
Vehicle:1999 Built! RSTI FP Red, E85, IM FAST! |
looks good! Does it seem like the Red did this awhile ago? Im asking because I just got a FP Red and have seen the same numbers, just asking not talking **** or anything.
and also 225/45/17 is the stock sti tire size, why go with the 215's? |
#12 | ||
Member#: 133146
![]() thanks Quote:
The street tires that I have are hte lightest there is and it has really soft side walls, I have cut 1.6's with them and EVOs have cut 1.5's. My car is also a WRX it comes with 215s IIRC. |
#13 |
Member#: 68647
MAIC
Vehicle:07 STI Rotated 35R Jorge Tuned |
Looks great Juan! Can I ask why you havnt rotated yet? Is the boost taper on purpose or the small exhaust housing?
#14 |
Member#: 155696
Tri-State
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
God Juan, you just have power for days. Your spool makes me jealous. Thats just incredible. 27psi that early must feel amazing on the street.
#15 | ||||
Member#: 261612
Here's my plot. The shape, the peaks, the spool, etc all look pretty much the same as yours! http://www.benjohnsonphotography.com...5PvZSRL-XL.jpg It's a ton of fun on the street, but with your car being a good 400-500lbs lighter than mine I'm sure it's even more fun! |
#16 |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
Be careful with those rods Juan. Remember what I told you when I was building it
![]() If I were you, I would drop the timing at peak torque down to 8-10* to help with not snapping one of them. |
#17 | ||||
Member#: 133146
I have seen FP reds make 560whp VD dynojet, I can increase timing a lot 5-6* and is running relatively rich. It hits 10.9 AFR in the midrage and 11.5 AFR at redline... I haven't had a chance to clean up the tune . As far as boost I have 625+ custom age head studs so I think I can run 30psi easy. Also If I go EWG it should give me good gains; I think this turbo can hit close to 600whp dynojet all out, 560whp realistically Quote:
#18 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
The spool looks deceptively good because you're using 4th gear ok the 07+ gearing on the street. That's a nice tall gear that will really spool up the turbo. What are the numbers like on the mustang VD setting?
Thanks -- Ed |
#19 | |
Member#: 133146
If I dyno it in 3rd I bet it will hit 27psi by 4200rpm... which is still really good. You did a road dyno for me with your software a while back and I think it made 430-440whp. I think it makes around 430whp on the mustang dyno settings, if I crank it up to the same parameters that your run on that STi GT35 Rotated, E85 - 473whp" that you just tune, my hp numbers should be the same with better spool and not droping power up top. Thanks Ed. |
#20 | |
Member#: 165104
SCIC
Vehicle:E85 bug-i sti swap Phatron tuned |
#21 |
Member#: 26933
BAIC
About 420-430whp sounds about right. Could you do a pull in 3rd? I'm curious to see where your torque peak would end up.
No doubt you have some nice spool from the TMIC, small header and hot side, but I think those will be quite a bit of restriction it you try to push it much more. You will run into MBT much earlier from the increased back pressure. This would be better compared to the GTX3071 we built a while back that did 440whp on a TMIC at about 25psi. That car hit peak torque at 4k RPM in 4th gear on the dyno (07+ gearing). -- Ed |
#22 | ||
Member#: 133146
Agreed the hotside is the restriction right now. That GTX3071 was running a EWG which if I ever decide to get one will help a lot 15-25whp. |
#23 |
Member#: 48350
MAIC
Vehicle:04 WRX |
Juan what series block you running? 703?
#24 |
Member#: 133146
#25 |
Member#: 5591
MWSOC
Vehicle:2002 WRX EJ257 Gt35r |
Nice graph man! Looks good, LOL @ "Only" 21deg of timing!!
