Old 11-07-2012, 07:35 PM   #1
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Default 07 WRX FP black... now PTE 6466...
Here is my latest setup
Event: Road Dyno
Ambient Temp: 60
Elevation: 1000
Weather: clear
Track and Conditions: asphalt, clean, flat
Tires: 215/45r17 summer tires
Car: 07 WRX TR
Tuner: Me
Dyno Info: VD
Transmission: 2011 STi
Gear: 4rd
Peak HP at RPM: 489whp @ 7351 RPM
Peak Torque at RPM: 447wtq @ 4800 RPM
Target Boost: 27psi tapering to 25
Target AFR: 11-11.5
Fuel: E85
Engine/Power Modifications: Wiseco forged pistons, 08+ STi rods, king bearings, BC 272 cams, stock valvetrain, Fully ported heads, FP Black IWG 9cm2, Hyperflow TMIC, Perrin headers, Perrin uppipe, Buschur Racing TBE, Hallman MBC , TGV deletes, phenolic spacers, , Walbro 460lph, Air Pump deletes
Other: Low timing
Old 11-07-2012, 07:51 PM   #2
CatfaceType-R
Member#: 81102
Looking good, bro.
Old 11-07-2012, 07:59 PM   #3
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
finally grew some balls to post results
Good stuff man! cant wait to see results!
Old 11-07-2012, 09:11 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
How's the 6 speed?
Old 11-07-2012, 09:21 PM   #5
Juks
Member#: 108163
2015 WRX, 2005 STI
builds boost early for a turbo that size, nice!
Juks is offline   Reply With Quote
Old 11-07-2012, 09:33 PM   #6
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Nice, when do you think you will go to the track?
C J is offline   Reply With Quote
Old 11-07-2012, 10:00 PM   #7
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
noice!!
3 pretty fast cars in these last 3 posts, lol + reno's 2 post above that
juan, you should ditch those skinny stock tires with some 225-245's
Old 11-07-2012, 10:22 PM   #8
juanmedina
Member#: 133146
Originally Posted by CatfaceType-R View Post
Looking good, bro.
Thanks Carmi
... Cory
How's the 6 speed?
I don't like the extra weight but it shifts better. The car feels like it handles way better for some reason; at least I don't have to worry about another transmission breaking
Yeap! a 68lb/min turbo hitting 27psi by 3960rpm, 20psi by 3740rpm, 15psi by 3500rpm
Probably next year but I will go on kill mode, I am only running right now 21.5* of timing at redline which is 7500rpm.
Originally Posted by Irv Weissmanhowerton View Post
noice!!
Thanks, so far I don't have any traction issues. I will get some better tires in the future.
Old 11-07-2012, 10:28 PM   #9
Juks
Member#: 108163
2015 WRX, 2005 STI
Oh comon' Juan, a couple more degrees timing can't hurt anything!
jk, gotta be a blast to drive. Are you concerned about your rods?
Old 11-08-2012, 12:12 AM   #10
stu
Member#: 25768
35R bugeye
Slowbaru
Looks real good. Thing spools real nice.
stu is offline   Reply With Quote
Old 11-08-2012, 12:18 AM   #11
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
looks good! Does it seem like the Red did this awhile ago? Im asking because I just got a FP Red and have seen the same numbers, just asking not talking **** or anything.
and also 225/45/17 is the stock sti tire size, why go with the 215's?
20wrx05 is offline   Reply With Quote
Old 11-08-2012, 07:07 AM   #12
juanmedina
Member#: 133146
I was running 26* with my green... and I think thats what you all are running
thanks
The FP black is only 3lb/min bigger than the red so power output is about the same. The black has a billet HTA wheel from the HTA35r/HTA82 and you can see that the black spools really good. I don't think you can find a FP red setup that will out spool mine.
The street tires that I have are hte lightest there is and it has really soft side walls, I have cut 1.6's with them and EVOs have cut 1.5's. My car is also a WRX it comes with 215s IIRC.
Old 11-08-2012, 08:24 AM   #13
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Looks great Juan! Can I ask why you havnt rotated yet? Is the boost taper on purpose or the small exhaust housing?
Old 11-08-2012, 09:07 AM   #14
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
God Juan, you just have power for days. Your spool makes me jealous. Thats just incredible. 27psi that early must feel amazing on the street.
Slimsti is offline   Reply With Quote
Old 11-08-2012, 10:13 AM   #15
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
http://i110.photobucket.com/albums/n104/juanmedina/FPBLACK1.jpg
Yeah, this spool looks incredible for a turbo of this size. Looking at it a little more, the Virtual Dyno plot looks nearly identical to my recent ones, and your turbo flows 20lb/min more! That is amazing response for such a big turbo! What do you think it would make all out? How much would you increase the boost?
Here's my plot. The shape, the peaks, the spool, etc all look pretty much the same as yours!
http://www.benjohnsonphotography.com...5PvZSRL-XL.jpg
It's a ton of fun on the street, but with your car being a good 400-500lbs lighter than mine I'm sure it's even more fun!
Old 11-08-2012, 10:33 AM   #16
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
Be careful with those rods Juan. Remember what I told you when I was building it
If I were you, I would drop the timing at peak torque down to 8-10* to help with not snapping one of them.
Crystal_Imprezav is offline   Reply With Quote
Old 11-08-2012, 11:01 AM   #17
juanmedina
Member#: 133146
I haven't go rotated because I been trying to keep my setup simple stupid and I don't like to change a ton of stuff at the same time. The boost taper is not on purpose is just the normal taper for a IWG turbo; I wish I was able to hold boost all the way to redline.
thanks it feels really good
Thanks. I think my setup is so responsive because I am running a TMIC and the Perrin uppipe and headers have small ID diameter tubing and they are also ceramic coated.
I have seen FP reds make 560whp VD dynojet, I can increase timing a lot 5-6* and is running relatively rich. It hits 10.9 AFR in the midrage and 11.5 AFR at redline... I haven't had a chance to clean up the tune . As far as boost I have 625+ custom age head studs so I think I can run 30psi easy. Also If I go EWG it should give me good gains; I think this turbo can hit close to 600whp dynojet all out, 560whp realistically
yeap I am trying to keep torque down, I think timing at peak torque is set at 13-14* right now. I got another set of pistons and a case, I just need a good set of rods and it may go your way so you can built me another amazing short block .
Old 11-08-2012, 11:15 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
The spool looks deceptively good because you're using 4th gear ok the 07+ gearing on the street. That's a nice tall gear that will really spool up the turbo. What are the numbers like on the mustang VD setting?
-- Ed
Old 11-08-2012, 11:30 AM   #19
juanmedina
Member#: 133146
-- Ed
Compared to my 5-speed at the same speed it spools faster because of gearing....
If I dyno it in 3rd I bet it will hit 27psi by 4200rpm... which is still really good.
You did a road dyno for me with your software a while back and I think it made 430-440whp. I think it makes around 430whp on the mustang dyno settings, if I crank it up to the same parameters that your run on that STi GT35 Rotated, E85 - 473whp" that you just tune, my hp numbers should be the same with better spool and not droping power up top.
Thanks Ed.
Old 11-08-2012, 11:42 AM   #20
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
"juanmedina"
Agreed. Are you seeing any limitations with the tmic at this point? E85 helps. I'm sure you get asked this a lot and apologize a head of time. Looking good
wrxsubiemod is offline   Reply With Quote
Old 11-08-2012, 11:43 AM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
About 420-430whp sounds about right. Could you do a pull in 3rd? I'm curious to see where your torque peak would end up.
No doubt you have some nice spool from the TMIC, small header and hot side, but I think those will be quite a bit of restriction it you try to push it much more. You will run into MBT much earlier from the increased back pressure.
This would be better compared to the GTX3071 we built a while back that did 440whp on a TMIC at about 25psi. That car hit peak torque at 4k RPM in 4th gear on the dyno (07+ gearing).
-- Ed
Old 11-08-2012, 11:57 AM   #22
juanmedina
Member#: 133146
As far as I know no! although I wan't to replace the TMIC with ETS core because my hyperflow TMIC fits like crap. Np
-- Ed
Yeah I can get a 3rd gear plot, either tomorrow aftenoon or friday.
Agreed the hotside is the restriction right now. That GTX3071 was running a EWG which if I ever decide to get one will help a lot 15-25whp.
Old 11-08-2012, 12:20 PM   #23
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Juan what series block you running? 703?
slowgenius is offline   Reply With Quote
Old 11-08-2012, 12:49 PM   #24
juanmedina
Member#: 133146
Is the same block that came with my 07 WRX, I imagine it is a 703
Old 11-08-2012, 05:20 PM   #25
SW00P_G
Member#: 5591
EJ257 Gt35r
Nice graph man! Looks good, LOL @ "Only" 21deg of timing!!
SW00P_G is offline   Reply With Quote
