Old 11-04-2012, 10:18 PM   #1
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Default 2012 Impreza 2.0i Hella Supertones Install
Here's how I installed Hella Supertones on my 2012 Impreza 2.0i.
I started with these instructions: http://forums.nasioc.com/forums/show...38&postcount=1 and
I DID use the relay. I made my own harness using AWG 14 wire, and soldered all the connections, and wrapped them with heat-shrink tubing. The battery ring terminal is stud size 3/8", and the relay ground ring terminal is 1/4".
The OEM horn connector isn't anything that I could identify --it isn't a standard 0.250" disconnect like on previous models. I wanted to avoid cutting the OEM wiring so I improvized by using a two-prong spade connector. It fit perfectly into the conducting socket of the OEM connector, and I then taped it all up and zip tied the wires together on either side of the connection to absorb any stress.
There's a threaded screw hole (M6-1.00) in the frame right next to the wiper fluid reservoir, which is where I mounted and grounded the relay:
I grounded the horns to the point where I mounted them to the frame, using 1/4" stud ring terminals (I used M6-1.00x12 hex cap screws & nuts with lock washers to mount the horns).
Final product:
With grille:
I did have to angle the horns further down when installing the grille to get the top part to fit (the part that blocks rain from entering directly into the air intake). The horn bracket is touching the rubber anti-vibration mounts that are below the holes where I mounted them, which is probably fine, though it would have been nice to mount them so that they hung straight down.
gfxguy is offline   Reply With Quote
Old 11-05-2012, 12:10 AM   #2
ans2k
Member#: 315631
2012 Impreza Sport
sir, you have inspired me to tackle this project
Old 11-05-2012, 05:47 AM   #3
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Second
Old 11-05-2012, 05:53 AM   #4
M45
Member#: 333446
2013 Impreza SL CVT
I'm not familiar with the subaru scene - why do you care to upgrade your horn?
Old 11-05-2012, 06:02 AM   #5
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Have you tried your horn?
Old 11-05-2012, 08:07 AM   #6
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I was so wrong.
auskip07 is offline   Reply With Quote
Old 11-05-2012, 09:03 AM   #7
M45
Member#: 333446
2013 Impreza SL CVT
I have. It hardly ever gets used though so I don't really care that much.
Old 11-05-2012, 10:16 AM   #8
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I get cut off all the time, I think the dgm must be difficult to see. So I want horns loud enough that people hear them and jump a little
The horn in my Buick and our jetta are much more substantial then the subaru horn
Old 11-05-2012, 11:02 AM   #9
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
That's why I got them too. Look on YouTube if you want to hear what they sound like.
Old 11-05-2012, 04:01 PM   #10
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Subscribed. I need to do this.
Old 11-06-2012, 01:45 AM   #11
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
The OEM horn is so gutless and it makes me embarrassed to use it. I will definitely do this when I have the time to order the horns and go pick them up.
Old 11-06-2012, 08:09 AM   #12
M45
Member#: 333446
2013 Impreza SL CVT
the only person that should be embarrassed is the person cutting you off for driving like an idiot.
Old 11-06-2012, 11:44 AM   #13
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I can't hear my own horn over the radio, how are others going to?
Old 11-08-2012, 12:30 AM   #14
pkL
Member#: 313093
2012 Impreza 2.0i
Cutting me off for driving like an idiot?
Old 11-08-2012, 06:35 AM   #15
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Horns ordered, should be here tomorrow. 46.04+ tax, thanks Amazon!
Old 11-08-2012, 08:56 AM   #16
myrt1987
Member#: 323103
2012 Limited 2.0i
lol i think he meant the crazy driver was the idiot.
Old 11-08-2012, 12:34 PM   #17
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
how did you remove the grill?
Old 11-08-2012, 12:39 PM   #18
myrt1987
Member#: 323103
2012 Limited 2.0i
black plastic pop-clips on top, 2 SS screws behind, push-tabs at the bottom of the grill. Youll probably need a stubby phillipshead screw driver for the screws and maybe flathead for pop-clips
Old 11-08-2012, 12:56 PM   #19
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i know i saw it posted somewhere, and i am searching, but it is slow going.
the 2 screws that are behind, are they on top or the back? i would go look but my car is currently 400 miles away from me
Old 11-08-2012, 01:32 PM   #20
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
There are four screws, on at each "corner" basically. Easy to see with a flashlight. You'll need a stubby screwdriver, or a flexible screwdriver attachment (what I use since I don't have a suitable stubby). It's got an led light on the end which makes it easy to see what you're doing.
Old 11-08-2012, 01:34 PM   #21
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
thanks
Old 11-08-2012, 02:01 PM   #22
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Btw, I'm thinking of grounding the horns straight back to the battery instead of what I described above. I didn't bother removing paint from the frame to make sure the connection is good, and while the resistance wasn't too high (~ 0.8 ohm), I'm concerned about it being unreliable. Less resistance should mean louder horns too. Going to wait until my new soldering station arrives though.
Old 11-08-2012, 03:49 PM   #23
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
There has to be some other ground nearby to use
Old 11-08-2012, 03:54 PM   #24
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
i need to find someone who has these install to hear them in person. the youtube video makes hellas and stock sound almost the same if anything.
Old 11-08-2012, 04:06 PM   #25
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Tonally they're similar to the stock horn, just much louder. Most recordings probably clip/compress the volume. My son didn't react when I was testing out the oem horn in the garage, but when I tried the supertones for the first time he shouted from the house "what was THAT?" . Testing them even with short bursts in a closed garage is borderline painfully loud.
