#1 |
Member#: 305043
Event: dyno pull
Location: Mach V Motorsports for dyno pull Sterling, VA Ambient Temp: 80.96 degrees Fahrenheit Elevation: 300ft Weather: cloudy, 29.64 in-HG, 27% Relative Humidity, SAE 1.0 Tires: Dunlop SP Sport 600 245/40R18 Car: 2012 STI Tuner: Dan, Mach V http://forums.nasioc.com/forums/member.php?u=12029 http://fastwrx.com/ Dyno Info: Dynojet Research Transmission: 6spd stock gearset Gear: 4th Peak HP at RPM: 358.29 @ 6500rpm Peak Torque at RPM: 360.77 @ 3750 Baseline hp/tq for a stock on same dyno: 243.86hp @ 6300, 245.21tq @ 3000 Target Boost: Max boost 21 psi, tapers to 20 psi. Target AFR: AFRs are in the mid-11's. Around 11.1-11.2 at redline Fuel: 93 octane Engine/Power Modifications: AEM Cold Air Intake for 08+ WRX/STi Cobb Downpipe, fiberglass wrapped Cobb Accessport, Mach V custom tune SPT Catback 3" exhaust from factory Invidia WRX/Sti Header, large tube, fiberglass wrapped ETS top mount intercooler Denso Iridium spark plugs, 1 range colder Fuku Works turbo inlet pipe Mach V 3-Port Boost Control Solenoid Blouch 20G-XTR Turbo Upgrade Ceramic Coated Deatschwerks Top-Feed Injectors 750cc Grimmspeed Ported and Polished TGV Bypass, ceramic coated Grimmspeed PNP Throttle Body, ceramic coated Grimmspeed PNP intake manifold, ceramic coated Grimmspeed 3mm phenolic spacers Driveline Modifications: Suspension Modifications: Cartboy pitch stopper cartboy short shifter and shift bearings STI Type N Engine Mounts Other Modifications: Attachments: ![]()
#2 |
Member#: 177891
Tri-State
Vehicle:06 wrx wagon child seat/tow hitch cgm |
#3 |
Member#: 239638
MAIC
Vehicle:2007 WRX TR UGM 02 MR2 EGM |
^Yeah I'd say so.
Did you ask for a "high number" tune? Because that graph looks like it. Haven't seen a lot of 20g-XTR graphs so maybe I'm wrong.. but I'd assume you could get a flatter torque curve. |
#4 |
Member#: 305043
#5 | |
Member#: 68647
MAIC
Vehicle:07 STI Rotated 35R Jorge Tuned |
Congrats OP! And great job Dan!! 11 sec street car making peak torque under 4k.
I think the torque drop is an illusion due to the RPM's on the chart being so close together. Horsepower doesn't start to drop until 6500rpm which tells me the torque is fairly flat. Perhaps the high peak torque is due to an initial boost spike? |
#6 |
Member#: 239638
MAIC
I wasn't refering to the correction factor or the number's being 'high'. Just that the graph shows high peak numbers vs a tune with less peak power but more usable power.
Maybe it's just how the turbo performs, I don't know. I'd like to see the boost plot. |
#7 | |
Member#: 305043
#8 |
Member#: 329811
Sounding good
#9 |
Member#: 241953
MAIC
Vehicle:02 hybrid/6speed 01 2.5 RS sedan |
Nice setup man. i just got tuned with a 20gxt by dan and also had almost identical numbers as you.
i bet its fun.! |
#10 |
Member#: 335135
NWIC
Vehicle:2002 Forester S Blue Ridge Pearl |
Congrats on the power, nice chunk over stock! What inlet size and hotside does that XTR have?
#11 | |
Member#: 133597
SCIC
Nice setup OP. Looks like stock spool until 3500rpm and then it just takes off! Great street setup IMO. This thing would wail on e85. ![]() |
#12 | |
Member#: 305043
#13 | ||
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
8cm is the hot side. The inlet is either stock (2.4") or 3". I think turbo is usually a 2.4" inlet. |
#14 |
Member#: 265665
I'm no subbie guy, but sense when does peak tq at 3750 equate to a "high numbers tune"? Tq curve looks pretty grunty to me. I'm sure it drives like a beast of a DD.
